Old 10-16-2007, 07:40 PM   #26
PERRINJeff
NASIOC Manufacturer
Member#: 74110
To Shed some light on the 2008, this is something we have been putting together. Lots of good pics of the 2008 and how the 2008 is different.
CLICK HERE TO READ BUILD UP!
PERRINJeff is offline   Reply With Quote
Old 10-17-2007, 03:35 PM   #27
ringe
Member#: 49998
2007 WRX CT Stg 2
Looks like great work Jeff.
I was interested by the V-band flanges...great idea. Also nice was the idea of making your tailpipe or midpipe flanges match with the OEM, allowing more individual choice in exhaust system setup.
ringe is offline   Reply With Quote
Old 10-17-2007, 07:19 PM   #28
PERRINJeff
NASIOC Manufacturer
Member#: 74110
That is the idea, more choices for everyone. Also the V-band is a cool thing, and our solution to this normally very expensive connection is very good. The price our systems(current ones) isn't going to change when this occurs, and the 2008 WRX will come with them.
Old 10-22-2007, 02:53 PM   #29
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
good info Jeff!
Has anyone tried to put the legacy SPT intake on it yet? I had the parts guy at my dealer xref the PN for the 08 stock parts with the legacy stock parts, the numbers aren't the same, but I'm still curious!
Old 10-23-2007, 01:27 PM   #30
2fst4u2c
Member#: 57589
A Blu Hue
Originally Posted by z&cobb View Post
It was an option. Prodrive P7s. I have four sets of wheels. Two came with the car. I picked up another 17" and another 16" set. One of the 16" sets is loaned out for use on an Impreza L (it's not for go, but it shows nice).
Was in a hurry when i posted . . . sorry I purchased a set of aftermarket 17" wheels for my 02 and I wanted people to know the bolt pattern did not change and the wheels fit great!
2fst4u2c is offline   Reply With Quote
Old 10-29-2007, 02:02 PM   #31
samagon
Member#: 26859
of TXIC
Jeff,
I was digging in my trunk earlier, the sedans don't have the charcoal canister inside, I can take pics for you, if you like, but I guess that's another difference!
Old 10-30-2007, 01:45 PM   #32
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Jeff,
In the Hatch, they are all under the steel flooring in the trunk. So its not exposed with out pulling those parts off. I didn't take apart our sedan too far, but it has the same steel cover. It all should be there??? I will take a look later today.
Old 11-01-2007, 09:50 AM   #33
pehon
Member#: 163183
Just a quick question. Anyone here knows whats the model of the turbo that the 2008 wrx uses? is it the VF series?
pehon is offline   Reply With Quote
Old 11-01-2007, 10:45 AM   #34
samagon
Member#: 26859
of TXIC
ahh, I didn't pull out any steel covers, but I have had to get to the spare, and didn't see anything that looked like the shot from the hatch.
Old 11-01-2007, 11:59 PM   #35
jmhai
Member#: 162632
2008 WRX sedan
Pearl White
When will the exhaust system for the sedan be avaliable and price?? I guess this will be the only difference when it comes to performance upgrades and parts for the 2008 WRX's sedan/wagon?
jmhai is offline   Reply With Quote
Old 11-02-2007, 01:32 AM   #36
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Cobbs parts listed have actually been test fitted, I know this.
parker/slc/gc8fan is offline   Reply With Quote
Old 11-04-2007, 01:48 AM   #37
turbobuick6
Member#: 162994
1 07 sti 08 wrx
turbo should be a vf40, when i bought mine its identical to a legacys gt motor, looks like they just went legacy to wrx. i just need to figure out how to turn the boost up to the 13 psi the legacy gets, then ill have the 250hp as the legacy has. any one have stock dyno numbers on these cars.
turbobuick6 is offline   Reply With Quote
Old 11-05-2007, 05:48 PM   #38
samagon
Member#: 26859
of TXIC
every indication I've read says it is the good ole' td04 with a modified inlet housing to mount to the legacy TMIC.
none the less, it looks tiny as hell.
Old 11-20-2007, 06:15 PM   #39
samagon
Member#: 26859
of TXIC
So by xreffing the Parts for the LGT DP and the 08 WRX DP we can see that it is indeed the same part.
524202 Subaru WRX 2008 ; MT
524202 Subaru Legacy GT/Outback XT 2005-08 ; MT
and therefore, any DP for the LGT will work for the 08 WRX?
cause, I liked my stromung shorty dp on my 04 WRX.
Old 11-21-2007, 01:30 PM   #40
Ltrain
Member#: 16012
94 SE-R
Super Black w/ SR20VE
According to a Perrin online sales rep, one other thing that the 2008 WRX does NOT share with the LGT is that the '08 WRX has a NON-catted uppipe like the '06-'07's did. Just thought I'd share that here.
-L
Ltrain is offline   Reply With Quote
Old 11-21-2007, 01:42 PM   #41
PERRIN
NASIOC Manufacturer
Member#: 6776
TRUE! No cat. BUT you can legally replace the OEM catless Up-pipe with a PERRIN version and it works to make more power! We have done it here on our shop cars. There is improvement across the RPM band in both torque and HP. Jeff has some dyno results some place to share here I am sure as well. I believe the gains were 7 trq and 10 HP.
If I can help any clients, just let me know!
ADam@perrinperformance.com
PERRIN is offline   Reply With Quote
Old 11-21-2007, 03:20 PM   #42
turbobuick6
Member#: 162994
1 07 sti 08 wrx
whats needed to replace the downpipe on these cars with a catless
will i get a cel on or do they make sims for the o2 yet,
Old 11-23-2007, 02:22 AM   #43
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Get that dyno sheet and make a thread about it. I guarantee there are a lot of people that will be interested in finding this out.
Defiant Autospeed is offline   Reply With Quote
Old 11-23-2007, 02:24 AM   #44
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
The mechanical o2 sensor fix is just 2 spark plug anti foulers screwed together with one drilled open a bit to fit the o2 sensor in it. As such it doesnt matter what year/make/engine you use.
As for the downpipe, until there is engine management out, you dont want to do a downpipe or you risk blowing the motor. Im not being overdramatic there.
Old 11-23-2007, 12:06 PM   #45
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes you are ...
if it had a vf-39 it might be a problem but with a td04 it won't
Old 11-24-2007, 06:34 PM   #46
unclemat
Member#: 114530
2005 LGT 6MT wagon
-L
07+ LGT has non-catted up as well.
unclemat is offline   Reply With Quote
Old 11-26-2007, 02:36 PM   #47
samagon
Member#: 26859
of TXIC
Originally Posted by Jaxx View Post
yes you are ...
this is contrary to pretty much everything ever stated or written about an 04+ subaru.
Old 11-26-2007, 07:12 PM   #48
shadowhax
Member#: 164614
08 WRX 2.5i turbo
i just picked up a 08 blue WRX sedan.....i was looking on ebay at the perring legacy GT mufflers, not the cat back but just the mufflers, they look like they will bolt right up to the 08's dual exhaust.
shadowhax is offline   Reply With Quote
Old 11-26-2007, 11:40 PM   #49
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
Traded in my 06' for an 08' sedan. So far so good, feels a little sluggish around top end but it definetly spools faster. The clutch will take some getting used to, i stalled it twice while test driving it. The release point is so much lower than the 06'. Does anyone know what the black plastic latch looking things on the exterior of the car between the doors and roof are?
dtpebs is offline   Reply With Quote
Old 11-27-2007, 12:56 AM   #50
shadowhax
Member#: 164614
08 WRX 2.5i turbo
I think thats if you wanted to get the rack added, but doont quote me
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 09:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 10:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 01:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 08:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 10:51 AM
