Old 11-03-2007, 04:12 AM   #1
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
Default 18x8 45offset..8mm spacer ok?
i have rims that are 18x8 45offset...i wanna put 8mm spacers on it...can i still use my stock studs? or do i gotta go longer?
thanks in advance
I DID DO A SEARCH
NVSPRELUDE is offline   Reply With Quote
Old 11-03-2007, 10:07 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
With stock studs the generally accepted limit is 3mm.
Why do you want to use spacers, anyway? I would think an 18x8" +45mm would already fill the wheels out completely.
Old 11-03-2007, 04:21 PM   #3
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
no it didnt...i want it FLUSH!
i had super advans in 17 and the offset was 37....
Old 11-03-2007, 05:42 PM   #4
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
i've heard of dudes running 10mm spacers with stock studs no problem. i've always been told 10 is as far as you want to go on stock studs.
vtecTHIS is offline   Reply With Quote
Old 11-03-2007, 07:19 PM   #5
waktasz
Member#: 86356
2015 s1000r
wheelie monster
On a Subaru?
Word on the street is 3mm is max, although I've done 5mm and that's as far as I'd go. 10mm is a ton, no way I'd do that.
waktasz is offline   Reply With Quote
Old 11-03-2007, 07:53 PM   #6
ovedrivex
Member#: 116774
1997 Project GC8
with 10mm spacers you only have a quarter inch or a little less than a quarter inch of bolt to stud. soooo yeeah.. if you really feel thats safe more power to you. 8mm are a little better but i wouldn't call it safe. 8mm might be too much anyways. id go 5mm and you should safe. just make sure you check the torque after a 100miles or after a really long non stop drive
ovedrivex is offline   Reply With Quote
Old 11-03-2007, 07:53 PM   #7
[D.I.]WRX
Member#: 116314
Hey Ruel. I use 5mm spacers daily on my rims. From what I remember...5mm is pushing the limit but like vtecTHIS I've seen some guys do a 10mm. There's a rule of thumb somewhere as to how many turns the lugnut should go on just to be safe.
[D.I.]WRX is offline   Reply With Quote
Old 11-03-2007, 08:07 PM   #8
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I've seen people using 20mm spacers, but they were'n on the stock studs. Don't go higher than 5mm on the stock studs or you may end up like that red RX-7 on youtube.
Old 11-03-2007, 10:52 PM   #9
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
mav1c is online now   Reply With Quote
Old 11-03-2007, 11:09 PM   #10
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
well guys i found that one of my friends has adapter spacers from his old celica...they are 25mm! its cool ill live on the darkside......
so i put them on and man I LOVE THE WAY IT LOOKS!! ill take pics asap!
Old 11-03-2007, 11:17 PM   #11
...post the pics in the members car gallery where they will make the other kiddies all hot and wet
Old 11-03-2007, 11:39 PM   #12
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
ok well it not as aggressive as i thought it would be...ill post better pics in the member gallery but here are some quick one of the front tire and a night for the heck of it...imma try to get better ones in the day tom....
Old 11-03-2007, 11:44 PM   #13
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
these are just temps i wanna sell this and get the real stuff....but for now...lovin them
Old 11-04-2007, 01:34 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
and get the ish....
Would it harsh your mellow if you didn't get the ish?
Old 11-04-2007, 03:18 AM   #15
Evan
Member#: 11218
2005 Legacy GT Wagon
99 Miata, 91 Miata turbo
If my memory is correct, you want the lugs to get 3 full turns, at a MINIMUM.
The last thing I want to think about when taking a hard turn is if my wheel is going to stay attached to the car, make sure you've got long enough studs! 25mm is a full inch, I can't imagine you lug nuts are holding on to a whole lot.
Evan is offline   Reply With Quote
Old 11-04-2007, 05:44 AM   #16
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
oh well i got adapter so i gots plenty of turns....
Old 11-04-2007, 08:04 AM   #17
mav1c
Hoodbridge!
Member#: 560
Hello tire rub!
Old 11-04-2007, 08:23 AM   #18
Daishi00
Member#: 78952
2005 WRX
I was thinking the same thing. I hope you don't weigh much, have any passengers ever or carry anything in your car, like a pack of gum or a CD 'cause the weight is going to cause major rubbing action on any sort of turn or bump.
Daishi00 is offline   Reply With Quote
Old 11-04-2007, 10:30 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
3?! Yikes! That's not even remotely enough. Based on which engineering guidelines you look at, the recommendations of minimum thread engagement range for a fastener loaded in tension are generally in the 3/4 of the thread size to 1-1/2 the thread size. So for a 12mm wheel stud you're looking at 9mm - 18mm of thread engagement. (I don't think even the stock bits would give 18mm, so that's probably a bit high for our application.) So, at the low end of the range, 9mm divided by the 1.25 thread pitch gives 7.2 turns. There's not a chance in hell I'd trust 3 turns on my lugnuts!!
Originally Posted by mav1c View Post
Hello tire rub!
And hello outside shoulder wear because of 0 camber!
Old 11-04-2007, 08:38 PM   #20
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
HA! just dropped in more and NO RUBBING WHAT SO EVER!!! i took hard turn and no rubbing!! i think i wanna lower it more! what u think?
Old 11-04-2007, 08:45 PM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I think your idea of a "hard turn" is different than mine. And I think you need an alignment.
Old 11-04-2007, 08:48 PM   #22
Evan
Member#: 11218
Thanks for the correction. McGard has a similar recommendation: "minimum thread engagement must be equal to the thread diameter of the wheel stud."
http://www.mcgard.com/custserv/tech_support.asp
So, that would equate to 9.6 turns. I thought 3 sounded pretty small, hence my caps on the MINIMUM part.
Old 11-04-2007, 08:50 PM   #23
Evan
Member#: 11218
He just purchased H&R coilovers from me (450lb front, 400lb rear) yesterday, so I'm sure you're correct about the alignment.
With those spring rates, he should encounter rubbing much later than he would on typical lowering springs.
Old 11-04-2007, 09:02 PM   #24
mav1c
Hoodbridge!
Member#: 560
Pulling into a parking space does not count as a "hard turn". If you think you're never going to rub with the tires STICKING out of the wheel well, you are delusional.
Old 11-04-2007, 09:16 PM   #25
NVSPRELUDE
Member#: 25523
2003 suby wrx
psm
no actually i took a freeway off ramp pretty hard and took it over bumps around my work...yes i do need an alignment and i will....
Safe to run 8mm spacers on factory lugs? Cusson Tire & Wheel 3 08-11-2008 07:48 PM
FS: Universal 5 lug 8mm spacers grippy monkey SCIC Private Classifieds 7 06-09-2008 02:20 PM
intrest: trade rims...18x8 45offset work xd-9 NVSPRELUDE SCIC Private Classifieds 29 11-27-2007 08:13 PM
fs/ft:work bronze xd-9 18x8 45offset NVSPRELUDE Wheels/Tires 0 11-13-2007 09:06 PM
FS: Downpipe Gasket, Copper Header Gasket, Genuine Subaru Wheel locks, 8mm spacers ComTekAuto SCIC Private Classifieds 17 08-28-2007 02:14 PM
