Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 11-07-2007, 04:56 PM   #1
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
Default Wider = Better?
I am getting some new wheels they are gonna be rotas (not sure what model yet) and I have decided on either 18x7.5 or 18x8, What offset should I run? I know that a wider tire gives you more surface area and that equals more grip, what I was wondering is should I go 245's in rear? How wide can I go on a 7.5" wheel? What size tires should I go in front? The same? Thanks.
-Justin
xxxjuhstenxxx is offline   Reply With Quote
Old 11-07-2007, 05:21 PM   #2
lethal.adv
Member#: 95652
'12 Outback 2.5i
'10 Legacy 2.5i ltd.
when I shopped for my wheels at tirerack.com they have a range of what you can use.
I would use same size tires for both front and rear.
lethal.adv is offline   Reply With Quote
Old 11-07-2007, 05:31 PM   #3
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Offset on ROTA's seems to be around +48 normally, which is fine. On 18x8 wheels, you can run 235/40/18 without any problems, even 245/40/18 will work but is close to the "fender rolling" size....this is the exact setup I have on my ROTA's with tires (which are for sale by the way if you're interested in the ROTA P1 in Hyperblack).
REXtard04 is offline   Reply With Quote
Old 11-07-2007, 06:02 PM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
You can't run different tire sizes front and rear.
waktasz is offline   Reply With Quote
Old 11-07-2007, 06:46 PM   #5
ein86
Member#: 67817
FRS DeVinci Troy
Smith&Nephew Genesis II
yes you can. quite a few people do it for auto-x and track days (wider front tires), which im betting the OP wouldnt be doing it for these reasons though. if i remember, subaru recommends that there not be more than .25" difference in circumfrence between the front and rear tires? why is that, OP? cause you'll mess up your center diff. so generally speaking, yes, get the same size tires....unless you know what you're doing.
ein86 is offline   Reply With Quote
Old 11-08-2007, 09:53 AM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Show me an example of such nonsense. Different size wheels, yes, but different tires, even of the same diameter, I've never seen anyone do.
Old 11-08-2007, 12:45 PM   #7
Howl
Member#: 57830
-Justin
Wider is better for traction on smooth paved surfaces, but there is always a trade-off.
1. Your fuel economy will drop.
2. Your car is more likely to tramline (makes nice leisurely drives rather stressful)
3. It will be harder to maneuver at low speeds.
4. On gravel, snow or even rough pavement you are more likely to roll over the loose surface material rather than dig down into the firm stuff (i.e. don't plan on driving fast on gravel roads).
5. Your unsprung weight will increase.
If you can live with these trade-offs then wider tires are a good way to go.
Howl is offline   Reply With Quote
Old 11-08-2007, 01:38 PM   #8
ein86
Member#: 67817
FRS DeVinci Troy
sure, just let me dig through all of my interwebs...
different size wheels, yes, and i didnt mention that though its a lot more common. but yeah, if i stumble upon where i read what i was talking about again, you'll be the 2nd to know...
Which will be better? light weight or wider? chimchimm5 Tire & Wheel 12 01-27-2007 01:55 AM
New Wheels + Wax :: Wider=Better (2) drbiggieg Member's Car Gallery 43 07-21-2006 07:14 PM
My new Wider=Better STI drbiggieg Member's Car Gallery 50 06-10-2006 03:45 AM
Wider is better? scubypoo Brakes, Steering & Suspension 0 07-08-2001 08:19 AM
Wider is better-- fender flares? shiv Technical Forum Archive 25 07-14-2000 02:55 AM
