Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 11-19-2007, 01:03 AM   #1
Bruce Wayne
Member#: 122361
05 Tumbler STi
Default How long does it take for your ECU to learn after a AP Flash?
I flashed the AP Stage 1 map onto my ECU today. I was just driving around easy today for a couple miles, but it seems to hesitate a little when I tried to get on full throttle so I let off. Does it usually take a certain amount of time for your ECU to learn the new map/flash?
Bruce Wayne is offline   Reply With Quote
Old 11-19-2007, 01:31 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
short answer is yes, any time the ecu is reset
there is a couple of parameters it needs to relearn
a6n6d6y is offline   Reply With Quote
Old 11-19-2007, 11:07 AM   #3
Bruce Wayne
Member#: 122361
05 Tumbler STi
A little update:
So I fired up the car this morning, the car idles fine, but I tried getting on the throttle again in 3rd gear and it still does definitely hesitate a little bit around 3200-3500rpms so I let off again. Starting to think something else might be wrong?
Old 11-19-2007, 01:19 PM   #4
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
What kind of boost psi is the map giving you? There are a few other maps available from cobb that may take care of the problem if that is the issue. Which map did you download from cobb as well?
Sinister redlines is offline   Reply With Quote
Old 11-19-2007, 01:44 PM   #5
R & H Garage
Member#: 139767
what is your setup? Please be specific.
-Dominic
R & H Garage is offline   Reply With Quote
Old 11-19-2007, 03:27 PM   #6
Bruce Wayne
Member#: 122361
05 Tumbler STi
Default I feel like such an idiot
So I never really questioned buying my car from a dealer that if it had aftermarket components on it it would be obvious or the dealer would let me know before I buy it. So today, I went and dug around a little in my engine bay looking for loose hoses or tighteners and what not, and I see a "TRUST" rubber housing, which made me think maybe this isn't even a factory VF39 turbo, and sure enough it has a Forced Performance turbocharger ( I have no idea what model), so that is probably why my car isn't running right? I am running the Cobb AP Stage 1 91oct map. Could this be why my car is hesitating when I try to get on the throttle a bit? I am an idiot!!!
Old 11-19-2007, 03:31 PM   #7
lokies
Member#: 51554
2004 psm wrx
Now with 2 car seats...!
try stage 2, you might be better off running stage 2...whats your mod list? with an after market turbo, Stage I might not be the accurate flash for your car...You'll probably, most likely need a tune...
lokies is offline   Reply With Quote
Old 11-19-2007, 04:00 PM   #8
Bruce Wayne
Member#: 122361
05 Tumbler STi
I really dont have any mods. Stock 05 STi with a K&N drop in filter.
Old 11-19-2007, 04:03 PM   #9
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Now that's a score.
Now take a look at your injectors and fuelpump. If the previous owner was too lazy to swap out the turbo, I doubt he did the injectors and fp too. If it's all there then just get it tuned.
Btw, if it's a fpgreen and you don't want it pm me. I've been looking for a used one.
scrappydoo is offline   Reply With Quote
Old 11-19-2007, 04:26 PM   #10
lokies
Member#: 51554
2004 psm wrx
FP turbo charger is not "stock"....you should try to find out what else you dont know that was left in the car...
Old 11-19-2007, 04:49 PM   #11
Bruce Wayne
Member#: 122361
05 Tumbler STi
My bad. So far, as far as I'm concerned my car "looks" stock except the newly discovered FP turbo and the K&N drop in filter. Gotta go investigate some more to see if the injectors and fuel pump have been modified also.
I guess this is a lesson learned for not probing around more under my hood. I've never driven any other STi's, but have driven other cars of this caliber or faster, and I thought my car was ridiculously fast for some reason, but I found a good deal on a AP so I thought why not. So this ultimately means I flashed over a perfectly well tuned ECU. Bummer
Old 11-19-2007, 04:50 PM   #12
scrappydoo
Member#: 23630
97 v4 STi RA
I wonder if you can unmarry the ap and not lose the previous tune?
Old 11-19-2007, 05:22 PM   #13
lokies
Member#: 51554
2004 psm wrx
^^^ possibly, or like the other person had mention, unmarry the AP from your car. Just curious as to what kind of mods you have? from the sounds of it, you got yourself a pretty modified STi...
Old 11-19-2007, 05:29 PM   #14
icanbrkurhrt
Member#: 144725
2004 wrx wagon
what are the odds?!
i think you should just go with the flow.
its already modded obviously so i think you should just buy a dp and exhaust.
then get a protune.
you'll be happy.
icanbrkurhrt is offline   Reply With Quote
Old 11-19-2007, 05:39 PM   #15
Bruce Wayne
Member#: 122361
05 Tumbler STi
So when you unmarry the AP it's supposed to set it back to how it was previously? Does the AP store the old information when you first marry it? I was under the impression that it just flashes the stock map from cobb onto your ecu before it umarries. I guess I could try unmarrying it.
Old 11-19-2007, 06:13 PM   #16
lokies
Member#: 51554
2004 psm wrx
for sure Cobb OTS map is not designed for your FP turbo...best thing for you to do now until you know exactly what you have is to unmarry the AP from your car... my .02....
Old 11-19-2007, 08:12 PM   #17
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
if it's ap v2 unmarry it and you'll be back to where you were
v1 ap goes back to a ots stock map
Old 11-19-2007, 08:51 PM   #18
gi2005
Member#: 150531
2002 VF39 WRX
MPB
**** man let me know what the turbo is!! i got a vf39 on my 02 wrx im down to switch depends on the turbo u got =D
gi2005 is offline   Reply With Quote
Old 11-19-2007, 09:18 PM   #19
Bruce Wayne
Member#: 122361
05 Tumbler STi
So after looking over a bunch of FP turbos I am pretty sure it is a FP Green turbocharger. I also threw a CEL code P0172 on the way home from work, so it is running too rich, or something else is causing it to throw that code. Now its idling rough after I start it, and died once when I tried to start it the first time This is a pain in the arse. Does anyone know any good tuning shops near seattle with a great tuner? Thanks
Old 11-19-2007, 10:14 PM   #20
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
If you have a version 2 accesport, then unmarry it from the car. This should give you the map that was on there when you bought it. See if it runs any better that way.
Old 11-20-2007, 11:05 AM   #21
Bruce Wayne
Member#: 122361
05 Tumbler STi
Unfortunately I have the original version of AP, so it will just set it back to a stock STi map if i unmarry it.
Old 11-20-2007, 11:05 AM   #22
Bruce Wayne
Member#: 122361
05 Tumbler STi
Old 11-20-2007, 12:07 PM   #23
scrappydoo
Member#: 23630
97 v4 STi RA
Do you have all the supporting mods to go with that turbo? You should have a turboback exhaust, injectors, and a fuelpump. I'm not sure but that turbo may be big enough to need a bigmaf too.
To get it tuned I'd go to Dom, or PIA and have Tim tune it when he's in town.
New construction homeowners- how long does it take for your address to show up? WRXVT Off-Topic 20 10-13-2008 05:32 PM
How long does it take for a bearing to spin after the damge starts? BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-30-2007 05:08 PM
how long does it take for money order to get to the seller? MadDogSTi General Community 15 05-02-2006 01:47 PM
OT Exotic Bird Gurus: How long does it take for a tail to grow back? Thursday Off-Topic 11 03-03-2005 11:12 PM
After shaving how long does it take for your beard to grow back? wrxfx Off-Topic 33 08-12-2004 03:28 PM
