Old 12-03-2007, 09:46 AM   #176
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
also...nhluhr has some Aero Data...Search his name and Aero
Scooby South is offline   Reply With Quote
Old 12-03-2007, 09:55 AM   #177
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I think mine has at least 20 pounds of down force, or at least as much as it weighs
WRX 2002 is offline   Reply With Quote
Old 12-03-2007, 11:31 AM   #178
stark22
Member#: 88404
2006 Sti
If someone can get me a good 2d or 3d model of the car, I can tell you theoretically how much lifting force (both positive and negative) is acting on all surfaces of the car.
stark22 is offline   Reply With Quote
Old 12-03-2007, 01:12 PM   #179
crazy owen
Member#: 96259
1987 RX7wLS1v8
turd
taco bell added 20 pounds of downforce to my rear end last weekend and it was brutal.
hehehehehe...
no wing on my sti and its fine. you wont see me taking any long sweepers above 100mph though. definitely not.
almost any aftermarket wing that is a quality piece will be much more beneficial and adjustable if you are serious into track use.
crazy owen is offline   Reply With Quote
Old 12-03-2007, 02:10 PM   #180
Cejpat
Member#: 145776
2006 STI
OB
with the lower lip and stock wing, my 06 STi is incredibly stable at 120-140 ... with an added STi Rubber Skirt Lip, Rallispec says even more wind-cheating. Looking at the competition during track time, the track-dedicated 911s have monster wings that make the STi's look 1/2 as small ... i wonder, if a larger wing, like on the AMS Evo, is that much better for dedicated track use?
Cejpat is offline   Reply With Quote
Old 12-03-2007, 04:00 PM   #181
stark22
Member#: 88404
2006 Sti
i can save us all the time of speculation if I could get an accurate 2d or 3d model to run in CFD.
Increasing area does increase lift production, but also drag. It should be noted that wing should be put in "clean air" wich often results in a raised height over the roof. However, if put in proximaty of the rear diffuser, overall rear lift (downforce) production can be enhanced. Probably need a boundary layer energizing device to put the wing in "clean air" if location is below the roof.
You also have to remember that aerodynamic forces with affect the dynamic weight distribution of your vehicle as your speed changes. Your also changing your moment coefficient about your cg which will affect weight transfer at speed. This will greatly affect your vehicles characteristics in a corner it can either help or hurt your the lateral acceleration your vehicle can obtain ie can induce oversteer, understeer or promote nuetrual steer.
Old 12-04-2007, 01:13 AM   #182
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
HBspeed, Autopower, KW
My set up is competitive enough for now, time wise, but will have KW V3s by next season. Now on Swifts, -2.7/-2.5 cambers (even though on this day rear was set to -3 for the high speed Speedway banking). Still, cold and moist conditions on Hoosier R6s really made the rear felt too 'light' at 130-140 mph, at California Speedway.
I do have the sharp-lipped v-limited replica which actually work keeping the front end down, but seems to need a bit more rear downforce.
on the Roval banking at just over 130 mph
MaxSTi05 is offline   Reply With Quote
Old 12-04-2007, 01:26 AM   #183
sperry7
Member#: 110079
06 WRX
Black on Black
Nice pics.
You should get the roof vane from the 06-07 STI that will help make your wing more effective. You could also look at getting the SYMS (or replica) STI wing insert that you can adjust the angle of the top part to increase more downforce. You might want to add the rubber skirt on your V-LTD because more downforce on the rear acts as a lever and your front end will see more lift.
sperry7 is offline   Reply With Quote
Old 12-04-2007, 08:16 AM   #184
Mechie3
Member#: 120152
The v-limited lips don't provide downforce as much as they reduce lift by limiting underbody flow. You need a splitter, canards, or an aggressive front lip to create downforce.
To clarify, creating downforce does not equal reducing lift. They can have the same end effect, but a mathematical analogy would be:
creating downforce: 3 (lift) -2 (downforce) =1
Reducing lift: 1 (lift) -0 (no downforce) =1
they have the same net effect, except the sum of "creating downforce" can become negative, while lift reducing elements can only go to zero, and not negative.
Old 12-04-2007, 09:32 AM   #185
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
I agree on that. Before I installed the lip spoiler, at the same track, the front end would push when rounding the banked oval. And, on the front straight, where I pegged at ~145 before the banking, the front end felt less planted, more nervous. The v-lip definitely stabilized the front end. I just think I need slight adjustments at the rear wing (increase angle of attack - APR, SYMS?) to give me a little more downforce.
Butt dyno is a pucker one when track surface is slick I don't want to kiss the wall at those speeds.
Old 12-04-2007, 10:22 AM   #186
stark22
Member#: 88404
2006 Sti
I generated a 2d model.
I will attempt to run in a CFD software by the end of the week and possibly post some static pressure plots over the car.
If you want to reduce lift in the front, louvres (fish gills) on the hood will help.
Old 12-04-2007, 12:49 PM   #187
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I have the Syms replica rear wing and I can confirm that it does work, and the angle does make a difference. I had it set in the middle setting (it has 3), and after turning it to the steepest setting the car was noticably more planted in high speed corners and under braking at the end of high speed straights. This was most noticable at VIR going up the Esses, and braking into 14 after the long back straight. I definitely need to get a front lip of some sort. I REALLY like the new APR, bit it's pricey for something that's going to get beat on.
mav1c is offline   Reply With Quote
Old 12-04-2007, 02:36 PM   #188
Grintch
Member#: 53750
2004 WRX STi (WRB)
CMC 7 (Blue/Silver)
See attached numbers from FoilSim based on the wing geometry.
Street STi wing
http://img.photobucket.com/albums/v3.../STiWing-2.jpg
Rough estimate of WRC wing (no first hand wing to get geometry from)
http://img.photobucket.com/albums/v3...TiWing-WRC.jpg
Note this is just for the wings themselves with no consideration of the lift and turbulence from the body.
Grintch is offline   Reply With Quote
Old 12-04-2007, 02:43 PM   #189
1SIKWRX4U2NV
Member#: 24358
I miss boost...
my butt-o-meter definitely noticed a difference...i ran 130-ish with and without the wing and i'm surprised how much better planted it feels, even on a simple straight away.
*I know this isn't cold hard evidence, but I definately noticed a difference at somewhat faster than normal freeway speed.
1SIKWRX4U2NV is offline   Reply With Quote
Old 12-04-2007, 02:54 PM   #190
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
Street STi wing
So, we're looking at appx 50 lbs and 90 lbs of downforce at 100 and 150 mph, respectively. I'm assuming factory rake on the wing. Not bad. Does anyone have numbers from the SYMS or APR at their different angles?
Old 12-04-2007, 06:45 PM   #191
stark22
Member#: 88404
2006 Sti
If anyone wants to host some pics later tonight, ill have some 2d flow analysis over a 2004 STI.
Let me know.
Also for the calculations above, they don't predict stall and the rear wind is not in "clean" air. Also due to 3d affects the wing is not as efficient. But it is a good place to start.
Old 12-04-2007, 07:46 PM   #192
DriftIt
Member#: 137388
'05 WRX
Street STi wing
Wow! Now I can see why those vertical supports are so important on the WRC wings. .... 400+lbs at 100mph.
A way you could really tune your front end downforce would be to go with v-limited and put a CF splitter underneath that. Even with 1/2 to 3/4" protruding underneath the lip you would be adding a good amount of down-force (plus the splitter is adjustable) and add a small rubber skirt to the bottom of the CF splitter to further minimize airflow under the car depending on how much clearance you have. Getting the sides covered up will also help keep air away from the underside of the car and reduce lift. As far as planting the rear end, IMO go with the SYMS or you could at some vortex generators to the back end of the roof so your stock spoiler can get more "clean" air.
DriftIt is offline   Reply With Quote
Old 12-04-2007, 08:15 PM   #193
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
I know this isn't cold hard evidence - but as some of the other said, I think the Syms wing works better too. When I first drove my MY07 STi at 120 I was amazed at how much more smooth it was at that speed than my MY04 STi.
I later added a Syms wing and at highest setting it felt almost identical to the OEM wing at speed (this is all straights with no cornering) - I basically couldn't tell difference. When adjusted to lowest setting causing most downforce I noticeably could tell at speed. It felt even more planted at 100+. Would love to add the APR front lip to further increase stability at speed...
I would be curious to see results if you could run the Syms wing through the same model above.
SilverSurfer04STi is offline   Reply With Quote
Old 12-04-2007, 08:27 PM   #194
stark22
Member#: 88404
2006 Sti
heres a quick snap shot. Itll be done hopefully tomorrow if the solution converges. No Wing, no rolling road, no wheels. Just to show static pressure over the body. This is not the final solution...just a snap shot of a iteration. Ill try and post the final results tomorrow night.
If time permits I will validate with another code to see if these results are "accurate". I would really need to compare to empirical results.
Then you can put in any splitter, wing.....and have numerical results and know what exactly your aero mods are doing.
Old 12-04-2007, 11:21 PM   #195
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Speeds are 60 and 90 mph? Can't remember.
Wow. If I understand this correctly, both cars show obscene front lift. Would love to see the same data for the new Sti. Subaru says it has zero lift. That would mean quite a lot compared to 500 pounds of front lift! I hope they don't mean "net lift" as in the sum of front and rear lift/downforces. That would basically mean the new car is potentially just as lopsided as the old car and Subaru is just summing them. That would be pretty lame...
Frank
Frank A is offline   Reply With Quote
Old 12-05-2007, 01:45 AM   #196
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Stark, this is awesome!
Which CFD package is this? I'm in the process of getting a license from NASA (no, I'm not joking you ninnies) for TetrUSS to try to do exactly this same thing for my 05 wagon. How did you come up with a profile of the car? How much does simplifying the profile to a flat bottom matter? How much does not having flow into the grille and hoodscoop matter?
Old 12-05-2007, 07:59 AM   #197
stark22
Member#: 88404
2006 Sti
I'm actually not at liberty to say which CFD package this is. Sorry.
I came up with the profile by loading a picture of the car into a sketch plane into my CAD software. Then I put points at specific locations. Then I ran a spline curve and adjusted to points to best fit the body contours. This is not the most accurate method but it works for now.
Simplifying the underside of the car actually increases negative lifting effeciency. The underside is behaving like a diffusor. There are no oil pans, a-arms or exhaust to distrupt/distrub the flow.
Flow into the girl should not matter that much, i believe. The stagnation pressure should be in the same location however, slightly lower due to some flow through the grill.
Hood scoop as well will have less static pressure. Also no flow through the scoop will affect how well the flow stays attached to the body aft of it.
Old 12-05-2007, 08:19 AM   #198
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
for us non-aero types...can you explain the different colors....I assume they are high and low pressure areas...and what the effect of those pressure areas do...
Bill
Old 12-05-2007, 08:48 AM   #199
Mechie3
Member#: 120152
It's not 500 lbs, not sure what the units are. The article was in Japanese. It's just useful to show relative forces.
Nice work Stark. It'd be interesting too to see how the 06 and 08 profiles do with your CFD program.
Old 12-05-2007, 10:02 AM   #200
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
Have you used anything like TetrUSS before? Have you taken boundary layer courses? Do you have serious hardware to run it on?
We use TetrUSS and have needed years of experience to get a solution that mimics reality.
Just want to make sure you know what you're getting into.
maxQ is offline   Reply With Quote
reminds me of spooling at 12 mph and crashing into house NJSwamplands Off-Topic 19 08-20-2016 09:24 PM
Mercury Cougar's (???) spooled at 12 mph and... Mr_Blastman Off-Topic 28 12-14-2009 09:35 PM
Whining noise at 30 mph and above? Old_Lady_Driver Newbies & FAQs 5 10-04-2009 11:48 PM
STI Drive by at 145 MPH MrTransAm Off-Topic 71 02-08-2005 08:18 AM
STI Drive By at 145 MPH MrTransAm Off-Topic 12 02-07-2005 12:53 PM
