12-05-2007, 10:13 PM | #1 |
Member#: 138915
SWIC
Vehicle:2003 WRB WRX Vf48 Tuned @ FAT by Snail Perf |
Question to you guys up in Flag and cold weather.
Do your cars run rough during the snowy winter months? While I was up there and at the Grand Canyon there was a constant high-pitch sound coming from my engine at idle. I was worried that it could be my belts or my radiator but now that I'm back in Phoenix it sounds completely normal. Ideas?
Edit: Not just at idle either, also at higher RPMs.
12-05-2007, 10:31 PM | #2 |
Member#: 134248
SWIC
Vehicle:2007 STi-Stage2 -RIP "Desert Sand on White" |
Flag is just like Connecticut is now - Cold... Very... Very...Cold... (wonder why I moved?)
First question is why type of Oil are you using? I have noticed that if I didn't change over to the 5w30 from the 10w30 I was using, then my engine did seem a bit rough. (not that it should hurt anything, but it was noticeable.) Could be many other things I know, but that is my 1st thought.. my 2 cents if you will. Side note- when I changed over to 5w30 for these few 'cooler' months here in the valley, I noticed my car was acting Diff... so - who knows.... |
12-05-2007, 10:40 PM | #3 |
Member#: 138915
SWIC
Oil weight stayed the same 10w-30 Castrol Syn. However, I've made trips up to Flag when I was running Mobil 1 10w-30 and there wasn't anything wrong. I hope the oil isn't the culprit...
12-06-2007, 11:17 AM | #4 |
Member#: 154343
SWIC
My car feels a tad ropey in the mornings after being left out overnight...
The gear shift is very notchy and the engine feels tight... I just put it down to it being a lot colder recently and the oil not being sloshed around the gearbox until it's turned a few times - by the end of the road all is normal... come to think o fit - I feel ropey most mornings too |
12-06-2007, 11:21 AM | #5 | |
Member#: 87015
12-06-2007, 11:22 AM | #6 |
Member#: 60976
SWIC
Vehicle:1969 LGT FATURBO |
raise the flag in cold weather?
12-06-2007, 03:02 PM | #7 |
Member#: 138915
SWIC
All of the things that you guys are mentioning happened. However, it was the engine in particular. Dunno, if it wasn't a Sunday I would have taken it to the Subaru dealership up there or something, but nobody was open.
12-06-2007, 03:06 PM | #8 |
Member#: 108547
SWIC
Vehicle:2017 Tundra 1794 Lifted, Armored, Muddy AF |
I had the same problem last christmas, then on the way home I lost my header to uppipe gasket
Most likely not your problem. My car is always weird when I go to Flagstaff even if its in the summer (I go once a month and stay the weekend) |
12-06-2007, 05:28 PM | #9 |
Member#: 82168
SWIC
Vehicle:07 dyno-comp'd CGM WRX Wagon |
12-07-2007, 01:51 PM | #10 |
Member#: 154343
SWIC
12-07-2007, 06:07 PM | #11 |
Member#: 45757
SWIC
Vehicle:2005 WRX STi CGM/Silver |
My car runs just fine when it's cold up here in Flag. In fact it runs much better then it does when it's hot out, just don't run super heavy oil especially if you park it outside. Flag doesn't get very cold though.
12-07-2007, 07:38 PM | #12 |
Member#: 121051
SWIC
Vehicle:08 8k RPM Vtak HoNdUh |
Justin you dont know what you are talking about Have you been out side today???
I have to leave the FXTS out side over night and when i first start it it sounds rough and the first few times i put it into gear it doesnt feel too lovely. It just needs to warm up for a bit. by the time i am a mile from my house it feels fine again |
12-07-2007, 09:56 PM | #13 |
Member#: 121184
RMIC
Vehicle:2004 WRX WRB |
Ya my car runs a little rougher during the winter months, and first gear is nearly impossible to get into if im even rolling 2 mph lol...
Similar Threads | ||||
2.5i Idle and Cold Weather Questions. | kruga225 | Normally Aspirated Powertrain | 10 | 11-08-2007 03:53 PM |
Question to all those with Modded injectors and cold starting? | 2002WRXSTi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 12-23-2004 12:57 AM |
TXS stage 4 and cold weather.... | carpetsloth | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-26-2002 10:29 AM |
Perf Tires and Cold Weather | kpratte | Brakes, Steering & Suspension | 1 | 06-29-2001 09:41 AM |
Turbos and cold weather -> special measures? | Mr. Jones | Technical Forum Archive | 5 | 09-06-2000 09:32 PM |
