Brakes & Suspension Forum sponsored by The Tire Rack |
12-16-2007, 03:26 PM | #1 | ||
Street's closed, pizza boy
Member#: 17301
MAIC
Vehicle:2018 Focus RS 2006 Evo #17 STU |
The long awaited Coilover FAQ!
Well, this is about a trillion years late, but people keep buying Subarus, so it's still worth doing.
Suspension upgrades are quite popular. This FAQ is meant to cover one of those upgrades - coilover kits. As with all aftermarket parts, they may or may not make sense for your particular application. This guide should help you determine the answer to that question. Please, please, please: first read the Lowering Spring FAQ as it covers a lot of important suspension related issues. THEN please read Turn in Concept's "Regarding Coilovers" post: http://forums.nasioc.com/forums/show....php?t=1701132 That should summarize how most of the regulars in here feel about coilovers But naturally I highly recommend you read on... What is a coilover? There are two answers - the correct one and the "common usage" one. The correct one: http://www.norcalcrx.org/tyson/coilover.html Quote:
[insert pic] For the purposes of this document, it's the common usage Why would I want coilovers? Borrowing from the Lowering Spring FAQ: Quote:
The main benefit that a full coilover kit offers is adjustibility. What does that mean? First let's get one bit of terminology out of the way: I see coilovers that say they're one/two/three way adjustable, but these Megan Racing coilovers are 32 way adjustable! That means they are 32 times better, right? Not exactly. "adjustable" means a lot of things. When it's a really small number, it's usually on this scale: Non-adjustable: height adjustment only (Tein Basic, KW V1. Sometimes referred to as one way adjustable) 1 way: height adjustment and one of the following: rebound adjustment, compression adjustment, OR a single knob that changes both compression and rebound (Tein Flex, JIC FLTA2, KW V2) 2 way: height adjustment and separate rebound and compression adjustments (RCE T2, KW V3) 3 way: height adjustment, rebound adjustment, and separate low speed and high speed compression adjustment (AST Raceline) 4 way: height adjustment, low speed and high speed rebound, low speed and high speed compression adjustment. (Motons) When you see "32 way adjustable" it means that you can adjust the shock to 32 different positions, usually via "clicks" in an adjuster knob. This is either rebound, compression, or some combination of both. Most coilovers meeting that description are two-way adjustable, NOT 32-way adjustable. Why would I want adjustable shocks? The main benefit of an adjustable shock is the ability to change your shocks for different setups. You may buy a set of Konis, run them with stock springs for a while, and then swap out the stock springs for 400 lb/in springs later and need to run the shocks stiffer to effectively manage the stiffer spring. Or run softer for daily use. Or run softer for inclement weather. Or run harder for track use. etc etc. It's important to note though, that you do not NEED an adjustable shock to have a good handling car. If you have good shocks already or if you upgrade to good non-adjustable shocks you may find it less necessary to "upgrade". But since there are very few strut options for our cars that aren't adjustable, you'll likely end up with adjustability even if you're not explicitly seeking it. Also - you may find after having adjustable shocks that you aren't adjusting them that much. For me, my "street" setting and my "race" setting are the same - just happened to work out that way. Why do I need height adjustment? I just want my car to be slammed. The main benefit to having height adjustment is the ability to corner-balance the car. For more information about corner balancing, visit here: http://www.nsxprime.com/FAQ/Performa...nerbalance.htm Even if you don't get your car corner balanced, having a height adjustable suspension will still allow you to change the car's rake (the front being higher than the rear, or vice versa). Like alignment or swaybar sizing, rake is one tool you have at your disposal to change your car's balance. But if you just want your car to be slammed, you can do that too. Just understand that most folks around here are "function over form" and will discourage you from doing this. Other benefits to height adjustment: * You can change the car's rake forward or back. This is one tool you can use to adjust the car's balance, or get downforce, or whatever. * You can lower the car's center of gravity. This is, as a general rule, a good thing, but with a MacPherson strut car like the Impreza, there is a point where you can lower the car too far. Unfortunately, that point is where far, far too many people lower their cars to Why do you keep trying to discourage me from slamming my car? I just want it to look good! Please, don't slam your Subaru. It's not meant to be slammed. The automotive gods have cursed us with a MacPherson strut suspension with a very unfortunate camber curve. For more details on why slamming your Impreza is bad, check out the Tein S-tech FAQ. It discusses the S-techs, but also discusses why lowering too much is bad: http://forums.nasioc.com/forums/show....php?t=1267918 So, in other words, my car is going to suck unless I have coilovers? This guy from SCIC said "go coilover or go home"! No! There is nothing magical about coilovers. They are comprised of components that you can buy separately. A good strut/spring combination can be just as fast. http://forums.nasioc.com/forums/show....php?t=1378003 And remember, each method of adjustibility you have is another way you can screw up your suspension. You can set the shocks wrong, you can set the height wrong, you can set the alignment wrong... A good strut/spring combination is a lot more likely to be easy to work with out of the box. And I don't know why everyone in Southern California thinks you need coilovers. Maybe it's something in the water. Maybe it's a plot to stick it to the rest of the country because they are jealous of our 93 octane and the fact that we don't have the CARB. Who knows. Just ignore it when it happens. I see these $150 coilovers on eBay all the time. Why would I pay $3000 for coilovers?? $150 will get you a no-name spring, typically of unknown spring rate, and a no-name adjustable spring perch. These may or may not match the valving of your shocks, may or may not sag, etc etc. You usually have no idea what you're getting. These kits are not "full coilover kits" as they only contain the spring/perch and not the strut body, shock absorber, camber plates, etc etc. What is a Ground Control coilover setup? A Ground Control setup (for instance, this one) typically contains the threaded spring perch and a 2.5" inner diameter coilover spring, but does not come with shocks/struts. You use these in combination with your factory struts and tophats. You adjust the ride height by moving the spring perch up and down. The Ground Control kits generally come with Eibach ERS race springs. The tradeoff with these kits is that you cannot adjust preload independent of ride height. This is what the eBay kits usually try to knock off. What are the best coilovers? Something JDM, right? Or maybe some 7-way adjustable Penskes? The suspension rules sticky covers this, but just for emphasis: There is no best ANYTHING. There is only best for your application. And there may not even be a "best" - there may be several good options. Do not ask what the best is. This will get you nowhere. Repeat after me, there is no best coilover. There is no best coilover. Write it on the chalkboard 100 times, like Bart Simpson. In the "early" days (circa 2001-2003) the JDM brands (Tein, JIC, HKS, Cusco, etc) were heavily worshipped. This is less true today as more and better options have hit the market. I'm trying to decide between Brand X and Brand Y. Which one should I pick? These posts do drive me a little nuts 1. Search. 2. If you're going to rule out 90% of the market you should have a reason. Please explain why you are focusing on these two. 3. Read the suspension rules sticky and tell us your goals. I just installed my coilovers and they're really bouncy. 1) Contact the manufacturer to tell them the problems you're having. 2) Try adjusting the stuff you have. a. Tire pressures. In some cases, going higher may help as it eliminates some of the bounce from the tires. b. If you have adjustable shocks, try making them harder, AND try making them softer. Full soft might be nauseating (hit a bump and keep bouncing). Full hard might be just too damned stiff (headaches, sore kidneys, etc). Find something in between. c. Preload. Some manufacturers have recommendations for how snug the spring should be. d. Ride height. If you are too low you are going to be much more likely to be riding your bumpstops - bad for handling and for ride quality. 3) You can try going with softer springs. Please note that on a lot of the cheaper coilover setups this won't do a damn thing as all the harshness is in the shock. 4) If all else fails, buy something else. No one should put up with a suspension they don't like. I bought coilovers, but I want to change out my springs. What are my options? Since most coilovers use a 2.5" inner diameter coilover spring it's pretty easy to interchange them. Coilovers known not to use 2.5" springs: -DMS -KW V3: 60mm (adapter available for 2.5") -RaceComp Engineering Tarmac2: 60mm (adapter available for 2.5") -Turn In Concepts AST Coilovers: 60mm -Cusco Zero2R: 73mm (Swift sells 70mm springs) -Bilstein / H&R: See kfoote's note in post 26 -Tein MonoFlex: 70mm (wrx wagone, PM) (If anyone knows of a coilover setup that does not use 2.5" ID, let me know so I can add it.) Probably the three most well known brands of 2.5" springs (that aren't included in an off the shelf "full coilover" kit): -Eibach ERS -Swift -Hyperco Eibach and Swift both post the spring specifications on their website. Hyperco just introduced a new line of springs ("OBD") and as of November they said they intended to publish the specifications for those springs as well. Why would I change to different springs on my coilovers? 1. Ride quality. Shocks are typically valved to work with springs in a certain range, and going towards the softer edge of that range may help (or may not help at all, as described above). 2. Suspension tuning. You may take tire temperatures and realize that you need less body roll, and might decide to make your springs stiffer instead of going with bigger swaybars. You might decide you want a stiffer spring in the rear / softer spring in the front to make the car more biased to oversteer. Etc, etc. 3. Suspension travel / coil bind. It's possible that your springs are stacking up before the shock has run out of travel. Stretch has a great thread about it here: http://www.iwsti.com/forums/suspensi...revisited.html Your solution may be to run a longer spring, or to switch brands to something that has more travel before bind. 4. If you have a setup where the springs are rubbing on the adjustable spring perches, you can find a "barrel spring" (Eibach makes some I believe) that will be wider in the middle so that it does not contact the perches. These springs are not available in many spring rates, including most of the higher ones. I snugged up my springs, but now my car rides like a monster truck. What gives? If you are running a Ground Control or similar setup, you don't have the ability to adjust ride height and preload independently. In other words, the only mechanism you have for changing ride height is the spring perch. Base your ride height on what the car is when it's settled - NOT what is happening when the car is in the air. The spring does not need to be fully snugged at full droop, as long as the end result works out okay. Trying to snug the springs at full droop may give you monster-truck ride height. My springs *aren't* snug at full droop and I want to make sure they're snug all the time. What can I do, other than monster trucking? Buy helper springs (so that the helper will stay constantly snug). Or learn to deal with it What's a helper spring? What's a tender spring? They're the same thing, right? They're not the same thing. A helper spring is typically something like 2-3" tall, and contributes no meaningful spring rate. At normal ride height, the spring should be fully compressed. A tender spring is typically about the same height, but it does have a meaningful spring rate. This can make suspension tuning quite tricky. For a full explanation including pictures: http://e30m3performance.com/tech_art...ings/index.htm
12-16-2007, 03:27 PM | #2 | |
Member#: 17301
MAIC
"OK, quit dancing around my question. I have money burning a hole in my pocket and I really want to buy coilovers because that's what it seems like everyone has and I want my car to handle really well!"
Zero - remember the rules above. Know what you need them for. Don't listen to anyone. When in doubt, search. First - if you have to ask, you probably don't need coilovers. This is the Rule of Biggly (tm). Second - you need to figure out whether you need and want coilovers. They are not always "maintainance free". Some will require intermittent rebuilds, especially if you are driving them on crappy roads. Certain coilovers are marketed as being more daily driving friendly. You may end up pissing off your significant other if the ride is too harsh. You might look silly if your car is bouncing down the highway. Etc etc. Third - You need to figure out your budget. There are plenty of options in every price range. Remember too that dropping $3K on a set of coilovers can't save you if you don't know how to drive. Spending money on seat time (autox, track etc) is ALWAYS the best bang for buck on how to make the car faster. Would you rather be the guy in the cheap car driving fast or the guy in the fancy car who doesn't have a clue how to use what they have? Fourth - you need to figure out how much adjustability you need. If you just want "better handling" with nothing specific in mind, you might not need 16-way adjustable dampers. There are plenty of good strut/spring combinations out there, like -STi takeoffs (type RA, spec C, whatever) -Konis + Prodrive springs -Konis + Ground Control -KYB AGX + whatever springs, etc etc. A lot of the popular strut/shock replacements offer adjustable damping as well. You should seriously consider these. Don't jump on the coilover bandwagon just to say you have coilovers. You can have a car with excellent handling without coilovers - camber plates, a good spring/strut combo, a good alignment and some swaybars is a good way to do this. Fifth - if you just want the car lowered so you have less wheel gap, you can get by with just "lowering springs". If this is your only goal, well, this and "aggressive street driving" (), you can save the money you were going to spend on coilovers and put it into your car insurance. I have searched once or twice. I know about the dangers of putting slam-tastic springs on the stock struts. It sounds like if I want to have my car really, really slammed, without compromising handling or ride quality, I need to buy coilovers, right? Buying coilovers does not change the rules completely. You still can't completely slam your car to the ground, even with coilovers. As Jon Bogert points out: Quote:
Short version: you should absolutely not be that low. http://forums.nasioc.com/forums/show....php?t=1377606 All feedback appreciated. This is just the first pass. If I kept trying to make it perfect it would never get done. john Last edited by Butt Dyno; 12-16-2007 at 03:46 PM. |
12-16-2007, 03:27 PM | #3 | |
Member#: 17301
MAIC
Knee-jerk "buy coilovers y0" thread hall of shame:
http://forums.nasioc.com/forums/show...highlight=scic Quote:
Testimonial of people who have bought coilovers and regretted it went coilovers, feels like being beat up in car. http://forums.nasioc.com/forums/show....php?t=1691373 Last edited by Butt Dyno; 02-03-2009 at 08:02 PM. |
12-16-2007, 05:50 PM | #4 |
Member#: 78952
MAIC
Vehicle:2005 WRX CGM |
I thought "xx-way" was simply in relation to compression/rebound in terms of high speed or low speed?
That would explain why Moton's and whatnot are 4-way adjustable as they do rebound/compression for both fast and slow speeds... Or is this something that varies by manufacturer as to what "adjustment" is what? |
12-16-2007, 05:56 PM | #5 |
Member#: 78952
MAIC
And possibly the difference between linear and progressive springs. Maybe you already have that in the Spring FAQ???
12-16-2007, 06:07 PM | #6 |
Top Scoob 009
Member#: 68273
MAIC
Vehicle:2012 WRX GD Race Car |
As Alex was saying, I think that for our purposes it's easier to refer to the level of adjustability in this way:
Non-adjustable-height adjustment only 1 way-height and rebound or damping adjustment 2 way-height, rebound, and damping adjustment 3 way-height, rebound, low speed and high speed damping adjustment 4 way-height, low speed and high speed rebound, low speed and high speed damping adjustment. It just keeps everything consistent, and when talking about coilovers it's assumed that they are all height adjustable. Other than that, this is a great writeup |
12-16-2007, 06:43 PM | #7 | |
Member#: 17301
MAIC
Would you mind if I switched "damping" to "compression" and used it? john |
12-16-2007, 08:25 PM | #8 |
Member#: 156932
MAIC
Vehicle:2006 WRX Black Pearl |
Great job John!
12-16-2007, 09:24 PM | #9 |
Member#: 78952
MAIC
Oh, sorry didn't say good job earlier I give you guys that right these FAQs big props as it takes a ton of time and energy.
Thanks for putting that into better terms Dan. I agree that it'll help keep confusion down especially when we have to talk about 32 way adjustable coilovers from BC (that's sarcasm if somebody doesn't understand right away). |
12-16-2007, 09:39 PM | #10 | |
Member#: 54202
MAIC
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Good job john!
I think TiC's new coilovers use 60mm springs too. Those are the only ones I know of....I think just about everything else is 2.5'' ID. - Andrew |
12-16-2007, 10:19 PM | #11 | |
Top Scoob 009
Member#: 68273
MAIC
12-17-2007, 12:00 AM | #12 | |
Member#: 31002
Vehicle:2002 WRX Blue |
Bill |
12-17-2007, 09:10 AM | #13 | |
Member#: 93646
MWSOC
Vehicle:Many Track Records Let us help you go fast! |
12-17-2007, 12:45 PM | #14 |
Member#: 6034
BAIC
Vehicle:2002 WRX It's Soo-BAH-roo |
The front springs for the Cusco Zero2R (GDA application) are 73mm ID. With a little machining on the bottom spring perch, a slightly more common 70mm ID spring can be used. Swift makes 70mm springs.
12-17-2007, 08:53 PM | #15 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Replace the word "shocks" with "dampers" or "struts" everywhere. We don't have shocks.
Other than that, looks good. |
12-18-2007, 04:47 PM | #16 | |
Member#: 17301
MAIC
http://en.wikipedia.org/wiki/MacPherson_strut That's how I interpret it at least. I'm certainly open to changing it but I thought it made sense the way it was used. john |
12-18-2007, 05:03 PM | #17 |
Member#: 17301
MAIC
Updated the 1-way, 0-way etc part after feedback
Added list of non-2.5" coilovers Added a note about barrel springs Added something to post #2 (feel free to submit candidates ) |
12-19-2007, 03:15 AM | #18 | |
Member#: 120
AKIC
But then again, Wikipedia is always right, so... |
12-19-2007, 07:04 AM | #19 |
Member#: 78952
MAIC
When I think shocks I think the tubes that sit next to the springs on off road trucks personally (Hey, Xtreme 4x4 was actually good for something ).
12-19-2007, 05:32 PM | #20 |
Member#: 144707
Vehicle:1996 Legacy LSi green |
so I am curious...if I want my car to be higher off the ground instead of lower....am i going to have to get much more expensive coilovers?
12-19-2007, 06:20 PM | #21 | |
Member#: 815
Vehicle:2013 Boss 302 White 2008 S2000 CR ABP |
First off, a KONI shock/damper insert is not a strut. Is is, however a damper that was designed for a strut application. The primary design difference is that it can take side loads, whereas a non-strut damper cannot. The most visible difference is the diameter of the shock shaft, which is about 22mm in a KONI insert and similar is most other non-inverted dampers for strut applications. A strut is the structure that bolts to the upright/hub, and contains a damper. In most cases that damper is a "wet" setup where the internals of the damper are not self contained in another structure, but in the case of the KONI "insert" the opposite is true. It's self-contained. The combination of the KONI insert and the surrounding strut housing is often simply referred to as a "strut", which is fine, because functionally it is. the point here is that a KONI insert itself, is not a strut. It needs the surrounding application-specific strut housing to make it functional. Last edited by zzyzx; 12-19-2007 at 06:37 PM. |
12-19-2007, 06:32 PM | #22 | |
Member#: 815
It seems the issue revolves around considering the damper and strut as a single entity. I think this is an incorrect approach. Damper: Single adjustable: Rebound or compression or both adjust together and are not independent. In the case of KONI, a single adjustable damper adjusts rebound. Some adjust both in some predefined ratio. Double adjustable: Rebound and compression can both be adjusted independently of one another. Some shock designs have some "crosstalk", so that adjustment is not truly independent. Triple adjustable: Rebound and compression can both be adjusted independently, and either rebound OR compression is separated into independent "low" and 'high" speed adjustments. It's invariably bump that has high and low speed adjustments on a triple adjustable damper. What velocity constitutes high and low speed is manufacturer dependent. 4-way adjustable: Rebound and compression can both be adjusted independently, and rebound AND compression are separated into independent "low" and 'high" speed adjustments. A lot of low-buck Asian coilovers refer to their adjustments as "32-way". This refers to the number of detents on their (invariably needle valve) adjusters and almost all of these are single adjustable dampers. Strut: There are two possible adjustments for a strut: The lower spring perch. This is what the spring seats into. Often referred to as "spring preload". Some would call this "single or 1-way height adjustment". The lower flange. This is the application specific component that bolts to the upright/hub on the suspension of your car. Some would call this "2-way height adjustment". Last edited by zzyzx; 12-19-2007 at 06:42 PM. |
12-19-2007, 11:30 PM | #23 |
Member#: 126130
South East
Vehicle:06 Subaru STi WRB |
I thought it was a good write up. SO you used shock. Everyone knows what you mean. If they are so nit picky to call you out on that. I hope they never take the time to research and the time to write up a DIY thread or anything for that matter. I would think you guys would say thank you. I learned something that will help me out when I decide to change my suspension.
This is directed at the nit pickers. No one else. Keep up the good work. Thanks Jeff |
01-03-2008, 06:11 PM | #24 |
Member#: 62182
NWIC
Vehicle:2005 STI White |
Tein Flex uses 70mm ID springs.
Also, longer springs will not eliminate spring slack in droop. It'll just make you move the lower spring perch down. -Mike |
01-17-2008, 08:17 PM | #25 | |
Member#: 103776
SCIC
Vehicle:2006 STI silver |
Q: To adjust your corner balance %, is it better to adjust the pre-load on the spring (adjusting the perch) or by changing the overall length of the coilover (adjusting the ride height)? This assumes that relocating weight is not an option. SPRING: Some CO's only have spring adjustment so you have to do it with spring adjustment on these. But, what happens if you run out of adjustment or if you end up with drasticaly different settings? RIDE HT: This tends to have more influence on cross percentages (turn for turn) than adjusting the springs. Unfortunately, this can upset the loading of the chassis and can effect the geometry. PROBLEM: What happens if 2 diagonal springs need 4 turns of preload while the other 2 need zero turns of preload to get an ideal 50% cross? Should you adjust the CO lengths to get the springs back to equal preload all around or do you run with the springs that far off from one-another? Or, do you split the difference like 1 turn on one set of diag springs and 3 turns on the other and THEN adjust the CO's to get your desired cross%. Bottom line: do you ajdust just the spring preload, CO length, or both. For bonus points, explain why.... |
Similar Threads | ||||
The long awaited pics of the new AMS facility! | AMS | Member's Car Gallery | 54 | 10-04-2007 09:09 PM |
El Camino Productions now presents the long awaited sequel... | El Camino | Off-Topic | 81 | 07-03-2006 03:02 PM |
The long awaited selling RS thread... | Fido | Tri-State Area Forum | 1 | 10-23-2002 05:15 PM |
the long awaited pics.... | Bill.B | South West Impreza Club Forum -- SWIC | 5 | 02-13-2001 08:52 PM |
