Old 12-21-2007, 02:53 AM   #1
legav05
Member#: 51287
2005 LGT AVO380
2011 E90 M3 ZCP
Default flash limit?
Has anyone run into an ecu that would refuse to take flashes from too much tuning? Just wondering if this was Cobb FUD all along, 100 reflashes always didn't smell right.
legav05 is offline   Reply With Quote
Old 12-21-2007, 03:05 AM   #2
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
i believe there is no real limit
nhat is offline   Reply With Quote
Old 12-21-2007, 03:07 AM   #3
dynamix
Member#: 122603
I have done well past that amount.
dynamix is offline   Reply With Quote
Old 12-21-2007, 05:33 AM   #4
veightkiller
Member#: 78967
2011 335i
there are no limits..
veightkiller is online now   Reply With Quote
Old 12-21-2007, 05:54 AM   #5
drkramm
Member#: 159156
2007 wrx
wrb
well there is limits but nothing we'll see
when you keep reflashing a chip you can get "sticky bits" bits of data that won't change even though you tell them to
drkramm is offline   Reply With Quote
Old 12-21-2007, 10:21 AM   #6
NJ2.5RS
Member#: 110353
2006 WRX
black
its like when you keep deleting and putting new stuff on your hard drive and not defragging it. Eventually the programs start to get their files spread over the whole drive instead of just one spot.
NJ2.5RS is offline   Reply With Quote
Old 12-21-2007, 07:49 PM   #7
legav05
Member#: 51287
2005 LGT AVO380
2011 E90 M3 ZCP
We wish. No the same bits keep getting flipped. _someday_ it will not work, just wonder how far away that day is.
Old 12-21-2007, 08:58 PM   #8
hurricane123
Member#: 121116
2004 WRX
v7 w/VF30
I'm up to ~150 flashes and still going strong ... the day it gives out I'll just pick up another ECU.
Jeff
hurricane123 is offline   Reply With Quote
Old 12-21-2007, 09:43 PM   #9
legav05
Member#: 51287
2005 LGT AVO380
2011 E90 M3 ZCP
Jeff
It would cost less just to get a cobb solution and tune by ram.
Old 12-21-2007, 11:16 PM   #10
hurricane123
Member#: 121116
2004 WRX
v7 w/VF30
~$200 used WRX ECU off eBay != $700 Accessport + $200 Street Tuner
Jeff
Old 12-22-2007, 12:00 AM   #11
legav05
Member#: 51287
2005 LGT AVO380
2011 E90 M3 ZCP
because when my ECU blows up I'm sure there will just happen to be a $200 ecu on ebay. riiiiiight.
Old 12-22-2007, 12:06 AM   #12
Tea cups
Member#: 103136
There's a theoretical limit, but no one has reached it. There's been no ECU failure that I've ever heard of from flashing in the Subaru world and there are some extreme examples of guys with over 1,000 flashes. So, while possible, it is highly unlikely this would happen for the average user.
Tea cups is offline   Reply With Quote
Old 12-22-2007, 01:26 AM   #13
Freon
Member#: 88322
2009 BMW 135i
I have at least 100 on my main ECU now. Never seen anyone claim, let alone be proven that someone flashed an ECU too many times to the point of failure.
Freon is offline   Reply With Quote
Old 12-22-2007, 02:16 AM   #14
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Umm... there are literally dozens listed in the junk yard database www.car-part.com.
The problem is really for cars with the immobilizer. Even if we acquired a used ecu, we would have to bring it to the dealer.
Non-immobilizer ecus can be purchased from the junk yard.
mickeyd2005 is offline   Reply With Quote
Old 12-22-2007, 02:41 AM   #15
hurricane123
Member#: 121116
2004 WRX
v7 w/VF30
Found 2 that I could have next day with a 20 second search ..... although you were correct, they weren't on eBay.
Jeff
Old 12-22-2007, 04:02 AM   #16
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Looks like someone's been sippin' on some Cobb Coolaid.
Don't kid yourself.
I'd much rather have a $80 dollar tuning solution that is constantly developing, has decent support, and doesn't hide stuff from the end user. I doubt anyone will over flash an ecu before opensource goes to ram.
ExpO is offline   Reply With Quote
Old 12-22-2007, 09:57 AM   #17
gabedude
Member#: 10108
07 STI
25G build in progress
I have reflahsed mine about 165 times now at the least.
gabedude is offline   Reply With Quote
CEL flashing off launch limiter/2 step? RideZX-6R UTEC 8 04-16-2008 02:46 AM
Limits of ECU Flashing (Enginuity) Sko Commercial ECU Reflashes 13 09-26-2007 02:57 AM
Limited number of ECU flashes? bdon22 Commercial ECU Reflashes 7 04-02-2007 11:57 AM
Let me be the first: 07 STI Limited CEL & Flashing cruise coil222 Factory 2.5L Turbo Powertrain 65 11-11-2006 01:23 AM
Re-flashing flashed ECU (ecutek) wRxbeater11 Engine Management & Tuning 12 03-01-2003 01:03 AM
Message Board Statistics All times are GMT -4. The time now is 08:37 PM.
