Old 12-22-2007, 04:28 PM   #1
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Default log help. IAM 11
Not sure what is going on. IAM 11 is not good. I compared my current map to another stage 2 map from osecuroms and my base timing is way lower than the base timing map from osecuroms. I have ny KC normalized at 10.9. The gas I use is good.
Any advice would be greatly appreciated. If my ROM needs to be posted, let me know.
Mods: Decatted DP, Catless UP and thats pretty much it for the exhaust except for an STi axel-back
Brock31 is offline   Reply With Quote
Old 12-22-2007, 05:42 PM   #2
Tea cups
Member#: 103136
Did you change your base timing when you normalized the advance map so you ended up with the same overall timing? Really no reason to normalize the advance map anyway. In fact, depending on how you did it, you can cause the IAM to be more erratic at low loads. This is because there is a minimum advance map threshold for rough correction learning of ~3.9 degrees and if the entire advance map is set to 10.9 degrees you increase the chance of rough correction learning (IAM) at low loads (when false knock is a greater possibility and where advance map value would be 0 or less than 3.9 degrees normally). You can also log 'feedback knock correction' and 'fine learning knock correction', so it is not necessary to normalize the map to determine correction due to knock.
Old 12-22-2007, 09:46 PM   #3
controler
Member#: 100271
What kind of fuel are you running? I've found Shell takes the IAM down pretty quickly on my car.
It looks as though your IAM has been at 11 for a while? Did you start it at 8 or 16? Could be working it's way up still. However looking at your overall timing, it doesn't look too bad. Knock correction is going down a bit, that can happen but it's usually because of knock or false knock. Now if your IAM was 16 then dropped to 11, you'd need to work on the map some more. Need more logs.
controler is offline   Reply With Quote
Old 12-23-2007, 02:50 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Is this true for the 32bit NAs as well?
Old 12-23-2007, 03:09 AM   #5
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
This is one of the reasons I stopped flattening the KC table. low amounts of knock at partial throttle can cause huge downfalls in IAM.
You could be experiencing the effects of winter fuel too. Get in contact with me and I'll transfer your map into a new one without flattened KC.
Master2192 is offline   Reply With Quote
Old 12-23-2007, 03:23 AM   #6
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
EDIT: Whoops. I thought you had a RS rom like williaty.
mickeyd2005 is offline   Reply With Quote
Old 12-23-2007, 05:42 AM   #7
Tea cups
Member#: 103136
Yes, although the minimum value may vary. The parameter is 'Rough Correction Minimum Timing Advance Map Value' in Enginuity/Ecuflash with the latest defs.
Old 12-23-2007, 03:13 PM   #8
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Thanks for all the feedback guys!
That would make sense what Teacups said. Would this have anything to do with the fact that I tune a particular map based on WOT runs and higher loads? My wife drives the car daily and is MUCH more conservative with the "go fast" pedal. Could the fact that the car stays in a low load/rpm state affect IAM as much as high/rpm and load?
When I normalized that KC map, I did alter my base timing to make the total timing the same. I did that just so it would be easier for me to see timing being pulled in logs.
Master--I'll get in touch with you.
Hope everyone is having a great holiday and stay safe
thanks--Brock
Problems while logging.. Help! Eskram Engine Management & Tuning 8 04-24-2007 08:51 PM
Help - IAM is at 3. Detonation? Rick Schu Factory 2.0L Turbo Powertrain 128 09-12-2005 05:35 AM
A quick Utec log help WRX1 Engine Management & Tuning 1 05-29-2003 11:50 PM
First Data Logging - HELP nekard Engine Management & Tuning 4 03-11-2003 10:06 AM
need data logging help Jerry Seagreaves Southern California Impreza Club Forum -- SCIC 2 01-31-2003 01:19 AM
Message Board Statistics All times are GMT -4. The time now is 07:26 AM.
