Old 12-22-2007, 04:39 PM   #1
Riles
Member#: 121154
2002 Impreza WRX PSM
Stage 47, Romraided
Default Kernel?
I'm trying to get ECUFlash to hook up with my 02WRX and when trying to connect I get a No Kernel found error. How do I get around this?
Riles is offline   Reply With Quote
Old 12-22-2007, 07:27 PM   #2
Tea cups
Member#: 103136
Read this:
http://www.scoobypedia.co.uk/index.p...shingFAQ#toc11
and the next question has troubleshooting steps.
Possible issues:
1. You are not in test mode (green connectors under driver's side dash)
2. You are not using a tactrix cable.
3. Your ECU has been flashed by Ecutek
4. You do not have the ignition turned on (engine off)
5. Don't turn the ignition on until prompted to do so and when you do, immediately hit OK to start reading. Do not wait or read will fail.
6. You have driver issue due to installing a newer version of Ecuflash over an older one.
Tea cups is offline   Reply With Quote
Old 12-24-2007, 05:32 PM   #3
Riles
Member#: 121154
Stage 47, Romraided
I got it now, it was your number 5. We already had the ignition on when we started the program but we followed your advice and now its good to go. Thanks man
kernel get version? alphagoose Commercial ECU Reflashes 6 09-24-2007 03:03 PM
so I inhaled a corn kernel (lawl) Protege Menace Off-Topic 3 09-17-2004 02:30 AM
kernel 2.6.8-1 :) is out linux>windows Off-Topic 16 08-15-2004 01:54 PM
