#1 | ||
Member Sales Rating: (1)
Member#: 110247
Well all, after all the great things I've read about the Process West TMIC design and arguments made for efficient airflow and optimal core thickness design, I decided to plunk down the $1086 shipped from MastroWRX for both the TMIC and air splitter.
A note about my application: I have an '06 STi with a Cobb TBE and AP V2. I have in hand a part list including an FP Green turbo (ported, 2.4" inlet, 7cm exhaust, internally wastegated), 850 cc deatschwerks fuel injectors, 255 lph Walbro fuel pump, Buschur Racing CAI, and Buschur Racing uppipe. I wanted to run a a mid-high 11s daily driven street car with a stealthy top mount. What really appealed to me about the PW TMIC design was the thought process involved and efficiency arguments. I really appreciated the way they considered airflow and heat exchange and weren't about to just cram the largest chunk of aluminum they could squeeze under the hood. The pictures on the website and other forums show a very impressive improvement over the WRX with substantial core size increase and truly impressive matching airsplitter designs, which truly are a very nice upgrade for a WRX. Dyno curves were supplied showing improvements and part of the promised testing was supposed to be a direct comparison of a stock STi TMIC with the PW TMIC. I am not able to find these test results. Anyway, I approved of the methodology and decided to go for it anyway. I called Mastro to ask about the TMIC and was told that it really was a substantial TMIC and would be a good upgrade for an STi. SOLD! So, I received the PW TMIC and splitter on 12/17/2007. The following are photos comparing the stock STi components with the PW components: TMIC comparison.... At first glance, I am hard pressed to tell any real size difference at all between the two. Sure, the internals may flow differently, but it's nowhere near as obvious an improvement as over the WRX TMIC. So I get out a measuring tape. Along the cooling fins, there is no measureable difference along the short direction and thickness that I can tell, and the PW is about 2 cm larger in the long direction. Also note that the stock TMIC has about 34 columns of fins compared to about 27 on the PW TMIC. In terms of heat exchange, the STi TMIC appears to have MORE surface area as more fins are packed into the same area/volume. The cooling fins on the stock TMIC are also connected by a wing shape as opposed to a block shape on the PW TMIC. The implication being that air would flow with less turbulence through the stock TMIC design. Of course, I cannot compare the internals. So this is my own external inspection. ***1/1/2008***More careful inspection of the stock STi TMIC shows there is a recess on the bottom that is 'hiding' the real stock thickness as Kevin points out, PW is 90 mm (or 3.5") and the stock is 60 mm (I measured ~65 mm /2.6"). This would give a core volume increase of about 35%. However, this neglects differences in fin density as the STi appears to have about 20% more. Therefore it is still unclear to me (although much less so) which would have superior heat exchange capabilities. Though the PW TMIC does appear to have the advantage. If the PW had the same fin density, there would be no reason for discussion, it would win hands down. Top view: Side view: Again, externally there appears to be little difference. ***1/1/2008***Again, PW TMIC IS thicker by about 0.9" or 25mm. I show a more careful analysis and outline the estimated stock core then transfer it to the PW so you can get a feel for the difference. Of course there is some degree of error due to the angle of the photo, but you get the idea. One major difference between the two TMIC's that I think is very clever of the stock STi TMIC is the lip which is actually designed to mate to the stock air splitter like a sleeve. I will show how this comes into play later. Now I will directly compare the air splitters. I unbolted the stock STi air splitter and you are looking at the bottom of both of them (or the side that mates to the the intercooler). What is immediately striking is that the PW TMIC opening appears to be very similar to the stock STi air splitter. Actually the PW splitter is a bit larger and would sit on top of the PW TMIC or on top of the lip on the stock STi TMIC where the stock STi splitter is slightly smaller and designed to fit inside the lip. Another obvious thing is that the PW splitter does appear to provide far superior cooling to the turbo as seen on the left side of the picture. I should also note that I did not apply the seal that was included with the PW splitter as I was keeping the parts in mint condition for my inspection. Another air splitter comparison. Now shown is the PW air splitter on top of the stock STi TMIC for placement purposes. What is shocking to me is that after all the arguments about channeling max air flow through the TMIC that the design is reliant upon a seal resting in place. To me this seems inferior to the sleeve type design of the stock STi splitter/TMIC interface. It does not matter that the PW splitter is on the STi TMIC and not the PW TMIC. Its going to be press fit either way and the top of the PW TMIC actually angles DOWN away from the center of the TMIC. This design would be more prone to air leaking out than the stock design. PW splitter shown on top of stock STi TMIC: Stock STi splitter shown on on top of stock STi TMIC: For fun, I took a side photo comparison of the two. Pretend that there is no lip and the seal is in place on the PW TMIC. To me it seems obvious that the sleeve type design is better. Nevermind that there does not appear to be any substantial gains in surface area to be had by the PW splitter. As for the PW air splitter itself, I wasn't overly impressed with the craftmanship of the piece that I received. There were several warped areas in the metal. It just wasn't a quality piece like the PW TMIC. The PW TMIC was a very nice piece and the assembly work was top notch. Here are some photos of the PW air splitter that I received. The item was packaged poorly and there was a ding where it poked through the box and maybe you could attribute one slight bend to that. However, there were several unacceptable flaws in the construction. I spent a lot of money on my car and the PW product. It should be a nice flush finish without any bending required. So, I felt like I had purchased a TMIC with quality construction. However, all of the air flow arguments no longer made sense to me and it was not clear in any way to me that this WAS in fact an upgrade for an STi. I looked around for a while and still can not find a single dyno plot where a stock STi TMIC was compared with a PW TMIC. I decided to ask Kevin at PW about it. I PM'ed Process West at NASIOC and again emailed at the process west website. I wanted to give them a chance to make me feel good about my purchase and explain technically why this was an upgrade for an STi as I truly cannot readily see for myself. I sent the following on 12/17/2007. Quote:
Funny enough, Manny at Mastro told me that he had the PW on his STi and did not see any power gains at all, but it 'ran cooler'. Well, being the empirical engineer that I am, that's not good enough for me. I asked to send the items back. Manny told me he'd check with management since he wasn't authorized to make that call and that they don't take performance parts back, but he'd have the manager call me back on 12/26/2007 since he wasn't in. Instead of a call, I got the following email on 12/26/2007: Quote:
To make a long story short, I believe the PW TMIC is a high quality piece and a very excellent upgrade for a WRX. I feel the PW air splitter is also a very good upgrade for a WRX, but the craftmanship of the piece I received was poor. Do I think it's worth $1086? Not really, probably you can get the same results for a lot less with the stock STi TMIC and air splitter. You can also drill your own holes in the stock splitter for better turbo cooling. However, I do not think that this product should be marketed as an upgrade for the STi until there is testing that shows a definite quanitfiable improvement. If there is testing showing this, then I apologize profusely, but this information should be readily available and shown very publicly. ***1/1/2008*** After receiving Kevin's input, I now understand that that PW air splitter was never meant to replace the STi air splitter, though that is how it is advertised on the Mastro website. I also can say that the PW TMIC has a ~35% core volume increase over the stock STi TMIC but a ~20% decrease in fin density. The net heat exchange advantage is 27/34 (fins) * 90mm/65mm = 1.10 or ~ 10% in favor of the PW TMIC compared to the STi TMIC. For the money spent on a PW TMIC, it would be nice to see just how much of a performance advantage is expected. Is it a very modest gain or not? Thanks for reading, and I apologize for my hasty and incorrect original thickness comparison.
#3 |
Member Sales Rating: (7)
Member#: 98689
MAIC
Vehicle:2005 Impreza WRX STi Crystal Gray Metallic |
This was the TMIC I was going to buy for my STi. Thank you very much for this thread, you saved me over a grand.
#6 |
Member#: 142663
Vehicle:2007 STI Obsidian Black Pearl |
Shoot, knocks that one off my list. I guess the stealthiest it's going to get is a black FMIC with a grillcraft grill.....
OP, thanks for this, what are you looking at next for cooling? |
#7 | |
Vendor
Vendor Sales Rating: (0)
Member#: 71459
Vehicle:2008 STi Silver R Spec |
Im sorry to read this. I didnt recieve a PM from you..(untill I had a look in my inbox now) .I dont visit here every day and I also dont recieve email notification when I get a new PM (dont know why). Also didnt recieve a email. 1. If you have an STi you should NOT have been sold a splitter...you dont need it..use the factory splitter. If fact you will go backwards using my splitter with the STi hood scoop. My splitter is designed to suit the internal shape of a WRX hood scoop and hence you will have a large gap between the top of the splitter and your hood scoop. 2. My intercooler is much thicker than the Sti intercooler. My intercooler is 90mm thick....the Sti intercooler is 60mm thick....measure the actual core...not the plates on the side of the intercooler which are much thicker than the actual core. 3. Do some intercooler outlet temperature measurements and you will see the difference...especially for pro-longed periods..(like a circuit)...the difference is night and day. Kevin Last edited by Process West; 01-01-2008 at 07:23 AM. |
#8 | ||||
Member#: 110247
I will edit my original post to show the corrected thickness information. I think the concern is buying one of the most expensive TMICs on the market without being able to see testing showing real performance gains. Thanks for reading. |
#12 |
Member#: 176026
"I will edit my original post to show the corrected thickness information. I think the concern is buying one of the most expensive TMICs on the market without being able to see testing showing real performance gains."
Thanks for reading.[/quote] hi, sorry for digging up an old tread. so is there any update on how much better is this PW TMIC compare to STI TMIC?? and how much whp can this PW TMIC support comfortably???? am thinking of getting it too. hope to hear some reply from u guys or even better, from Process West many tks |
#15 |
Member Sales Rating: (6)
Member#: 143149
Tri-State
Vehicle:2006 Evo IX RS used to be 07 wrx 6speed |
You have said that twice now. I dont see the spearco data flying at me.
#17 | |
Member#: 110247
I firmly believe this is an outstanding upgrade for the WRX intercooler and the craftsmanship was superb on the piece. However, unless I see a test proving otherwise, I do not believe that there are large gains to be had simply from running this intercooler. The upgrade from the stock WRX intercooler was well documented at each step with dyno data. It would be very easy to do the same with the STi intercooler. The testing that I saw stopped short of actually testing the STi intercooler to compare: http://www.rexnet.com.au/forum/index...howtopic=67143 Last edited by scoobienoobienoo; 02-02-2009 at 04:22 AM. |
#18 |
Member Sales Rating: (36)
Member#: 46135
Tri-State
Vehicle:02 WRX Powered by Sti V9 Spec C |
Also, for intercoolers, the touch test may not actually show anything.
A hot to the touch intercooler is an intercooler that exchanges a lot of the heat with the air. It gets hot and cools down the air passing through. A cold to the touch intercooler is more "insulated" to the air passing through, exchanges less heat, remains cooler and leaves the air passing through hotter. |
#19 | |
Member#: 176026
hmmm....or maybe the materials dissipite heat faster? thats why its cold to touch, hmmmm..... |
#20 | |
Member Sales Rating: (12)
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
#21 |
Member#: 46135
Tri-State
Let's see, so you're saying that:
The intercooler is designed to soak up the heat from inside the engine bay and then does what with it? Tell us more... Anyway, here's some more "misinformation" being spread. An intercooler is a heat exchanger. Our intercoolers are air-to-air heat exchangers. They are traversed by the air coming out hot from the compressor outlet. A heat exchange takes place, the air cooling down and the intercooler heating up. They are traversed by the air stream from the environment, via hood scoop and car forward motion and a second heat exchange takes place, the stream heating up and the intercooler cooling down. If after running your car at high loads, you immediately stop, open the hood and feel the intercooler hot, this means that most likely, it's doing it's job. Heat transfer can take place in 3 ways: -convection -radiation -conduction The first and second heat transfer take place through convection although to an extent radiation could be present. An intercooler that is cold to the touch after the first exchange, does not do... any exchange... It is possible for an intercooler to cool down, in the interval between you quickly coming to a stop, opening the hood and checking the touch. What would cool it off though? There is no air passing through, to form the second convection/transfer... So, to the extent to which there is radiation, yes, it will radiate some heat off, any maybe cool off a bit. Although I don't have calculations and formulae to back this up, I don't see an Intercooler radiating its way down to environment temperature in 2-3 minutes. I'm not saying it's impossible, though. |
| Thread Tools | |
| Display Modes | |
| FS: Process West Hood Scoop Air Splitter WRX STI 04-07 | wrx_limited | Engine/Power/Exhaust | 9 | 10-10-2009 06:28 PM |
| WTB: STI tmic and air splitter | ishmehb3n | Private 'Wanted' Classifieds | 4 | 04-30-2009 01:15 AM |
| Process West TMIC and APS TMIC comparison | maramaralula | Factory 2.5L Turbo Powertrain | 7 | 06-01-2007 03:30 PM |
| 2006 STi TMIC and air splitter. | Dynasty336 | MAIC Private Classifieds | 13 | 01-24-2007 11:57 PM |
| Wanted: JDM STI TMIC v7, Air Splitter, 02/03 STI JDM Hoodscoop | pcauwels | Private 'Wanted' Classifieds | 4 | 09-04-2005 12:17 PM |
