Old 12-31-2007, 08:37 PM   #1
hsnt
Member#: 160874
Default CANBUS flashing/tuning
Any news on its delevelopment yet?
hsnt is offline   Reply With Quote
Old 01-01-2008, 02:32 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Is anyone actively working on this?
What avenues are being explored?
Old 01-01-2008, 03:01 AM   #3
hsnt
Member#: 160874
Last I have heard was in Enginuity forum that a new cable was being developed.
Old 01-01-2008, 11:27 PM   #4
gabedude
Member#: 10108
07 STI
25G build in progress
Last I heard is that Colby is working on it. He didn't need help on it (reuires new pinout on cable is all I believe, I looked at some of the specs). I'll try and get some status to see if he needs any help. I may have access to a canbus car soon, so this is something I could help with. I just hate disassembly. The CAN protocol is industry standard (API and sample code is available) and I can write a driver to trace Suabru's CAN flash so we can write the bits in the correct order and any quirks like the voltage spike the older models neeed when flashing a new page. I am sure this is what Colby is doing, and working out bugs.
Gabe
gabedude is offline   Reply With Quote
Old 01-02-2008, 06:30 AM   #5
hsnt
Member#: 160874
Thanks for the update.
Will Enginuity support?
Old 01-02-2008, 01:21 PM   #6
gabedude
Member#: 10108
07 STI
The plan is to add command line arguments to ECUFlash so you can edit the ROMS (CANFlash or older Flash Methods) in enginuity, press a button and ECUFlash loads and writes the ECU.
As far as the ROM is concerned, it is only the interface that has changed. Once we have a copy of the ROM, the same disasembly will be used (by teacups (merchgod) and anyone else who helps)). The method of flashing the ECU is what has changed (the protocol). It is good because it is industry standard and very easy to reverse engineer the flash method as we have a copy of the Subaru CAN reflash CD which works with any CAN compatible industry standard cable. Those cables are expensive however (like 300 dollars). The FTDI chip probably can still be used so the price of the new Tactrix does not go up. Since it is an industry standard interface (CAN), this opens the door to even more applications. This is all because of USA emission laws enacted in 2007. Dealerships are required to sell flashing CDs for their maps that work with this industry standard for shops that are not owned by a dealership. It really is good news and has potential to expand the project into pretty much every car.
Gabe
Old 01-02-2008, 05:21 PM   #7
hsnt
Member#: 160874
Great news!
Hope all things work out well with Colby and the rest of the team working on this (as well as the Enginuity team).
Old 01-02-2008, 05:22 PM   #8
hsnt
Member#: 160874
Last edited by hsnt; 01-02-2008 at 06:02 PM. Reason: sorry...double post ...my pc is slow
Old 01-02-2008, 05:22 PM   #9
hsnt
Member#: 160874
Last edited by hsnt; 01-02-2008 at 06:03 PM. Reason: sorry....double post....my pc is slow
Oklahoma City Dyno Flash Tuning Day - Jan 31 - special rates Dyno Flash TXIC Vendor Classifieds 0 01-23-2007 07:22 PM
Subaru flash tuning on the Buschur Racing Dyno - 10.13.06 - special rates Dyno Flash MWSOC Vendor Classifieds 0 10-08-2006 12:06 AM
Dyno Flashed Ecutek flash tuning - introductory specials Dyno Flash Tri-State Area Vendor Classifieds 4 01-28-2005 06:58 PM
Message Board Statistics All times are GMT -4. The time now is 07:04 AM.
