Old 01-02-2008, 05:09 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default What Is Required To Raise Rev Limit
OK, so I want to raise the rev limit on the car I'm working on right now. Stock redline is 6200RPM. Obviously, just raising the Rev Limit Fuel Cut table values would allow the car to rev higher. However, I suspect that's not all that should be done to raise the rev limit correctly/safely.
The fueling and timing tables go to 6400RPM with an average step size of 400RPM. Does this mean the rev limit can be raised to 6800RPM (or even 7k) without needing to re-scale RPM rows of the tables, or does there always need to be a row above redline for these tables?
Feedback Correction Range (RPM) currently Disables above 6300 RPM. Should this be raised to new_redline+100RPM to keep the same relationship as stock?
The CL Delay Maximum Engine Speed A table (Above) Clear CL Delay is set to 6200RPM. Should this be raised to the new redline even though I currently have the CL Delays set to 0?
Per Cylinder Timing Comp also tops out at 6400RPM, does this need changed too?
Are there any other subtleties I'm overlooking?
Old 01-02-2008, 05:41 PM   #2
Tea cups
Member#: 103136
The ECU will only interpolate between the minimum and maximum axis value. Outside of that, it will continue to use the last value in the last row or column. It is not required to rescale an RPM axis to the rev limit, unless the values in the last row (ex. timing) are not appropriate for your tune between the largest RPM and the rev limit.
Old 01-03-2008, 02:52 PM   #3
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Did you raise your rev limiter yet?
Soon2BturbodRS is offline   Reply With Quote
Old 01-03-2008, 02:57 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Nope, without anyone giving any insight on what else needs changes (knock tables, etc) I don't feel comfortable doing it.
Old 01-03-2008, 03:12 PM   #5
Tea cups
Member#: 103136
I would at least extend the feedback correction RPM range and per cylinder max rpm (since it is already extended to current redline) to the new rev limit. CL delay Maximum engine speed doesn't need to be changed. As far as rescaling the fuel/timing RPM axis, I don't think that would be necessary in this case. I would guess that raising the rev limit on a stock 05 RS isn't going to make a difference in acceleration, though I could be wrong.
What is required to reach 500 whp on pump+meth with a gt35r? scutzi128 Built Motor Discussion 32 04-27-2008 04:14 AM
how to raise rev limiter dbs_Rs25 Engine Management & Tuning 4 10-02-2005 11:02 PM
What is required to set up a rally track? RightyTighty North West Impreza Club Forum -- NWIC 7 05-21-2004 03:47 PM
Piggy-back way to raise rev-limit? skidplatez Normally Aspirated Powertrain 4 06-22-2001 02:45 PM
What is required to run TEIN HA without PBM? SKiDaZZLe Technical Forum Archive 7 06-22-2000 07:09 PM
