Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-01-2008, 10:49 PM   #26
Tea cups
Member#: 103136
Originally Posted by Brock31 View Post
Basically, I'm not getting all the parameters I want to log, mainly fine and rough knock correction,feedback knock, knock learning and a couple of others. According to everything I've read, solving this is as easy as downloading the latest logger defs. and loading them into enginuity. Well, I did that and still the same logger parameters as before.
Post the ecu id shown in the lower right hand corner when you are connected with the logger and I can check and see if your ROM revision is supported or not. For extended parameter support (such as feedback knock correction, etc.), I have to have a copy of the ROM (extracted with EcuFlash) in order to define them. Likely no one has uploaded yours before, especially since it is an AT. If it is not supported, then you'll have to pull it with Ecuflash and a tactrix cable and send it to me and I can add logger as well as tuning support.
Old 01-02-2008, 12:38 AM   #27
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Hopefully I can get working with Colby on making ECUFlash work in Linux as it does in OSX already (easy port). I had an enginuity thread where I used an old laptop with enginuity for logging/editting running Gentoo Linux. If I had it for a reference I could make a writeup.
The FTDI drivers have been in the 2.6 kernel for almost a year now.
This would open a door for running Enginuity and ECUFlash on a small handheld mountable programmer that could be dash mounted, or a good car PC.
gabedude is offline   Reply With Quote
Old 01-02-2008, 02:26 AM   #28
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I wouldn't be so quick to claim that EcuFlash works on OS X. As best I can tell, it does, but if and only if you haven't installed any other software it doesn't like. It needs to to be the ONLY thing to have ever installed drivers or kexts that remotely touch any serial to USB conversion or any of the specific chips in the openport cable. Because I have a non-virgin computer (meaning I've installed hardware that installs drivers or kexts), EcuFlash will launch and allow editing of a ROM, but it will not recognize the openport cable. This makes it pretty useless. I was getting help from someone over on openecu.org, but the guy stopped participating in the thread so I have no idea what else to try.
If anyone knows much about the inner workings of EcuFlash, I will be happy to work with them and put as much time as is needed to try to figure out specifically what the problem is so that I can write up a "FOSS Tuning on the Mac FAQ" or the like.
Not to mention that Enginuity 0.4.1.b will only open only one ROM at a time, making it hard to compare two ROMs to each other (say current vs. stock).
FOSS tuning software support for OS X leaves a lot to be desired, thank god there's VMWare Fusion.
Old 01-02-2008, 09:22 AM   #29
Rogan
Member#: 142133
3 Jeeps
And a Saab
I can only get ecuflash to read/write ROMs (Vista) to the ecu. i cannot open/edit any maps.. weird..
Rogan is offline   Reply With Quote
Old 01-02-2008, 01:53 PM   #30
gabedude
Member#: 10108
07 STI
I have the ECUFlash source. That sounds like a MAC specific problem with the openport drivers posssibly or just ECUFlash (they are FBSD drivers, similar code as the Linux FTDI drivers). I haven't seen much interest in a Linux version, but I want something that will run enginuity's logger, program some code for rough autotune of boost, timing and fuel (like the autronics has) and slap it in some small form factor and sell it. Using Linux cuts costs dramatically as I can use really cheap hardware to make this thing.
Old 01-02-2008, 01:54 PM   #31
gabedude
Member#: 10108
07 STI
You just have a missing def for your ROM, but ECUFlash is using the correct flash procedure.
Old 01-02-2008, 02:21 PM   #32
Rogan
Member#: 142133
3 Jeeps
And a Saab
Ive tried D/L the 080b EcuFlash Standard Defs from Kens mirror, but it comes back "unexpected end of file" in the zip..
Old 01-02-2008, 02:27 PM   #33
Tea cups
Member#: 103136
Just DL and tested it -> don't have a problem here (XP).
Old 01-02-2008, 02:34 PM   #34
Rogan
Member#: 142133
3 Jeeps
And a Saab
Hmm.. Im on Vista.. Lemme try it again, saving to a different folder...
Old 01-04-2008, 07:21 PM   #35
thejaredhuang
Member#: 86206
2006 WRX Wagon
I can't get my ECUFlash to read the stock ROM from the ECU.
I have v 1.34 and I've connected the the 2 green tabs. I'm trying this on a 06 WRX Wagon. I get to FFFF3C80 len 68 and it gives me a readback mistmatch error.
Any help would be good. Thanks
thejaredhuang is offline   Reply With Quote
Old 01-04-2008, 09:16 PM   #36
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Read the Enginuity FAQ, it has a link to a troubleshooting page.
Old 01-05-2008, 03:07 AM   #37
thejaredhuang
Member#: 86206
2006 WRX Wagon
Read it, doesn't answer my questions.
Old 01-05-2008, 11:24 AM   #38
shipjumper
Member#: 6307
what I has no car...
am carless
Well, I just got my tactrix cable and I cannot wait to get started on my 05 baja terbo!
thanks for the insight tea cups...
SUBSCRIBE!
openecu.org im signed up for, but im not approved by the admin yet, so its kinda useless... im hoping to read more here....
shipjumper is offline   Reply With Quote
Old 01-05-2008, 02:25 PM   #39
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
B e a utiful. Subscribing...
flimflamman is offline   Reply With Quote
Old 01-05-2008, 03:49 PM   #40
wage0052
Member#: 127556
2006 WRX
RomRaided.
Can you explain your problem a little more? Are you able to pull logs? At what point in the reading process does it error? After connecting the green test connectors and turning the ignition to "power on" can you hear a number of fan's cycling in the engine bay?
wage0052 is offline   Reply With Quote
Old 01-05-2008, 03:52 PM   #41
thejaredhuang
Member#: 86206
2006 WRX Wagon
I can hear the fans going on periodically, as the guide says. I can't read logs.
When I try to read from the ECU on ecuflash I select 05-07 DBW and then I turn the ignition on and immediately press ok and it gets to FFFF3C80 and then it stops and says readback mismatch.
From pressing ok to the error takes around 10 seconds.
Old 01-05-2008, 05:04 PM   #42
wage0052
Member#: 127556
2006 WRX
RomRaided.
What errors are you seeing when you try to log?
Old 01-05-2008, 07:52 PM   #43
thejaredhuang
Member#: 86206
2006 WRX Wagon
I haven't tried logging yet. I'll get back to you on Tuesday.
Old 01-12-2008, 06:48 PM   #44
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
bump to make this a sticky
TROLL is offline   Reply With Quote
Old 01-12-2008, 09:03 PM   #45
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I actually PMed the mod for the forum to make it happen. I guess they didn't think I was right...
Old 01-13-2008, 10:58 AM   #46
rkramer
Member#: 118209
2015 WRX Limitec
if the fans kick on, you took too long from turning the key to clicking read.
rkramer is offline   Reply With Quote
Old 01-14-2008, 12:17 AM   #47
thejaredhuang
Member#: 86206
2006 WRX Wagon
I was responding to an earlier post to confirm that I was entering into diagnostic mode.
Anyways, I didn't drive the car for 9 days so the battery went flat and reset my ECU. I'll it again in a day or two and post with results (as I'm still expecting problems).
Can anyone post a picture of the pins on their tactrix cable? Thanks.
Old 01-14-2008, 10:33 AM   #48
Tea cups
Member#: 103136
It also can mean that you are choosing the wrong read method.
Old 01-14-2008, 06:05 PM   #49
Kosti
Member#: 118434
2003 Liberty B4
Great info m8!
Just hope when enginuity comes back online, they all support for the ADM B4 TT
Kosti is offline   Reply With Quote
Old 01-15-2008, 01:13 AM   #50
thejaredhuang
Member#: 86206
2006 WRX Wagon
Let me clarify, I only heard the fans come on when I didn't try to read with ECUFlash.
Anyone have a picture of the tactrix cable pins?
romraider/ecuflash? weaponstroop Open Source Reflashes 8 10-21-2008 11:04 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 07:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 04:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 12:34 PM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 07:26 AM
