Old 07-25-2004, 10:30 PM   #26
Chewy
Member#: 5917
95 Impreza Type L
That blueish color
Just wondering does anyone know if RS half shafts will fit a 96 wrx wagon diff? I was told that the wagon had 4.11 and had LSD. Can anyone confirm this?
Chewy is offline   Reply With Quote
Old 07-26-2004, 02:34 PM   #27
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Little off topic, but I just looked up the price of 22011GA022 - 3.90 clutch-type LSD off XT-6. They want $3,108 plus shipping. Sweet.... I'll take 3!
linsavy is offline   Reply With Quote
Old 01-11-2005, 10:05 AM   #28
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
you can switch out LSDs without changing the gear ratio right?
HeMan1320 is offline   Reply With Quote
Old 05-21-2005, 06:04 AM   #29
Sic 2.5rs
Member#: 86715
2001 GM6 RS
Silverthorn
Originally Posted by sick1.8t
turn one of the half shafts (axel connections) and the other side should turn the same direction, if it turns the opposite direction, its a non-lsd.
this only works if you can get enough torque on the lsd to make it "lock up" so you would have to have some kind of load on the tyres. I checked this last week when I had my car on a lift.
Sic 2.5rs is offline   Reply With Quote
Old 07-11-2005, 12:05 PM   #30
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
Default Are all of the Subaru R160 VLSDs the same?
I haven't seen an answer to the anywhere from my searching - I was wondering if anyone knew whether/which of the viscous LSD units for the R160 from various US/JDM Subaru models are the same. No talking gear ratios here, but the slip torques and other LSD characteristics. Basically, I wondering if some are stiffer than others. I have a V2 Sti RA one laying around here for example, but unfortunately the splining / retainer clips don't match up with my axles .
colby is offline   Reply With Quote
Old 11-16-2006, 04:45 PM   #31
wrxtrev
Member#: 26791
1990 JUSTY!!
white and black
will a 01 legacy rear lsd bolt into my 93 LS wagon? I figure it does.. just want to check before i jump on it.. thank you
-trevor
wrxtrev is offline   Reply With Quote
Old 11-16-2006, 09:21 PM   #32
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you will need differnt axels
Old 11-16-2006, 09:28 PM   #33
wrxtrev
Member#: 26791
1990 JUSTY!!
white and black
what axles will work? i have an LS wagon w/ ABS now. Other than the axles, I need a different bracket to hold it in right? what bracket?
Old 11-17-2006, 03:46 AM   #34
Storm
Member#: 5218
96L Most Over-
Developed Beater
Just the axles. Everything else will bolt up to your 93. Do you have stubs on your diff now? (you'll have rollpins just outside the diff) If so I may trade you for some 98RS axles that are believed to work with the VLSD diffs.
Jay Storm
Old 11-17-2006, 11:39 AM   #35
kingsubi
Member#: 19239
Some of the older LSD diff used short and ong splines on the right & left axles, not different length axles (this goes for all JDM LSD diffs before version 3) as well as some NADM subarus that didn't use outie stubs). These axles are very hard to find and mine just started to go.
Anyone know if you can rebuild rear axles?? Not the universal joint at the hub but the tripod joint at the diff end??
kingsubi is offline   Reply With Quote
Old 11-17-2006, 04:03 PM   #36
wrxtrev
Member#: 26791
1990 JUSTY!!
white and black
Impreza GC8
Old 02-16-2007, 11:41 AM   #37
The Vanishing Boy
Member#: 91748
1989 GL Touring wgn
Rose Red
-> Hi, I saw the final drive for the WRX up to 2004, do you guy know about the 2006's? Thank a lot guys!
The Vanishing Boy is offline   Reply With Quote
Old 02-16-2007, 01:27 PM   #38
kheff46
Member#: 66739
2002 WRX wagon
JDM V4(98) STi has 4.444 and LSD using male axle style.
i know theres some V4's around(not sure if they got the same diff tho).
kheff46 is offline   Reply With Quote
Old 02-25-2007, 05:45 PM   #39
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
I'm with him, but I actually need to know what my center differential and rear open differential final drives are (ie if center is 1.0:1 and rear is 4.111 or w/e) I have the 2.5i 5MT non-turbo. I can't find this info in any of the stickes.
ScubaruImpreza05 is offline   Reply With Quote
Old 02-28-2007, 07:08 PM   #40
toopercentmlk
Member#: 129970
1996 328is
schwartzII(black)
How would this affect handling? Im not used to the handling dynamics of awd cars, i've tracked with e36s and miatas with and w/o lsd but a rear lsd with slipping front, would that help the car rotate out of corners?
THe reason i ask is because I'm looking into buying a 2.5rs to build into a doubleduty street/trackable car and the 98 im considering doesnt have a rear lsd(i think).
[/hijack]
toopercentmlk is offline   Reply With Quote
Old 11-11-2007, 11:29 AM   #41
JSarv
Member#: 163445
l33t *******
[email protected]
Since I can't post a New Topic and its not covered here. I have a JDM V7 STI LSD Rear Diff New in the Box. What are the differences between this diff. and my stock 02 WRX differential? Are they similar? Could I swap the R180 V7 Differential into my 02 WRX?
The reason I ask, I have 80k on my 02 and I'm pretty sure the limited slip has seen better days, and this is a brand new unit.
JSarv is offline   Reply With Quote
Old 01-09-2008, 05:26 PM   #42
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
Hey I have a 2007 2.5i and I was planning on putting an LSD in the rear. I had looked around and it doesn't seem like Subaru made many 3.90 r160's...looks like Subaru loves the 4.11/4.44. Is there a way to put a 2002+ WRX rear lsd on the car and just swap out the ring and pinion (the ones from my open diff and put into the wrx lsd)? or is there more work then just that?
zavier is offline   Reply With Quote
Old 01-09-2008, 06:31 PM   #43
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes, you can simply swap the differential into your case or you ring and pinion into it...just be sure to set the lash properly....you'll probably want to have a tech do it if you don't have the tools.
Old 01-09-2008, 07:49 PM   #44
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
start asking for shops that will do before you buy it
its not a simple task .. pretty ugly actually
Old 01-10-2008, 12:08 AM   #45
Homemade WRX
Member#: 33782
96 bastard child
only ugly if you don't have the tools...the pinion is the biggest pain of it though
Old 01-11-2008, 12:00 AM   #46
1stGenLegacy
Member#: 59080
90 Legacy L+
Seems easier to swap the ring to the lsd and put that into the case. It avoids messing with the pinion.
1stGenLegacy is offline   Reply With Quote
Old 09-25-2008, 01:28 AM   #47
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
so does anyone know the final drive ratio of the 1995 Impreza L 5 speed?
bugeye-brawler is offline   Reply With Quote
Old 09-25-2008, 06:58 AM   #48
Storm
Member#: 5218
96L Most Over-
Developed Beater
It should be 3.90:1
Jay
Old 10-07-2008, 10:44 PM   #49
toddvero
Member#: 191193
Default Lower ratio diff gears
My research shows that there were 3.083 and 3.272 VA2 type LSD diffs produced for export on the Legacy and Outback with the 3.0L. Has anybody seen these, know where to get one, and know if they can be swapped into a US domestic T-Type LSD diff?
I'm building a custom rear end out of Subaru parts for a project car, and I need lower gearing than the 2002 WRX's 3.54 to match the bike engine I want to install.
toddvero is offline   Reply With Quote
Old 10-08-2008, 12:29 AM   #50
parkes
Member#: 166898
1994 T leg SS
ABM
Male axles?
Ive got a 99RS diff sitting in my basement, it has two holes for the axles to go into i spun the front and both sides turned, does this make it a LSD?
parkes is offline   Reply With Quote
'02 WRX 6 spd STI Conversion with r180 rear LSD & DSS (Drive Shaft Shop) Rear CVs nissaneng Transmission (AT/MT) & Driveline 16 03-17-2010 01:39 AM
Car came with intake, what AP options do I have? ST3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-02-2006 12:25 AM
4.11 Tranny with Matching Rear LSD Diff JoeT Private 'For Sale' Classifieds 17 02-10-2005 04:31 PM
Are the painted side skirts the same size as the plastic ones that my car came with? RyanRock Interior & Exterior Modification 5 05-13-2004 06:33 PM
I wish my car came with a hand gun accessory Stroke Off-Topic 9 09-05-2003 12:55 PM
