Old 01-13-2008, 03:58 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Cleaned boost control solenoid today (02 WRX)
I was getting ready for another protune scheduled for tomorrow and was checking everything to make sure everything is in order. Upon checking vacuum lines, I have noticed oil build up inside of coupler which connects two vacuum lines. Realizing that line leads all the way to the boost solenoid, decision was made to take everything apart and inspect the boost control solenoid.
Two hoses directly connected to boost solenoid in fact had visible oil residue, which meant that there must be oil residue inside of boost solenoid.
I used MAF cleaner to flush out any oil inside of boost control solenoid and as expected brownish oily residue came out from one of the nipple.
Haven't pushed my car hard yet, but so far boost builds up smoothly and everything seems fine. You will need to remove stock intake airbox in order to take two 10mm bolts that hold boost solenoid in place.
Old 01-13-2008, 10:06 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Update:
Car seems (no way to prove) to boost smoother after cleaning out the BCS... it may be worth doing this if you find a lot of oil build up inside of turbo inlet hose.
Old 01-13-2008, 11:33 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
Just a sidenote, I've always been able to remove the BCS bolts with a small ratchet and long socket. Never had to remove the airbox.
Haelan is offline   Reply With Quote
Old 01-14-2008, 03:36 AM   #4
simprezl25
Member#: 71647
2002 Bug iD
that is a good idea, also i noticed u have one of those husky oil catch can. how is that working for you? i have the samething at the same location. but i still get oil residue aroun d the T connection.
did u leave the filter connected or left it out? i left mine out because it seemed like the engine would have a hard time sucking through the filter.
simprezl25 is offline   Reply With Quote
Old 01-14-2008, 08:40 AM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
simprezl25, I took out the filter for the same reason. Since I changed from M1 to German castrol, car is not losing much oil at all. Turbo inlet, IC and y-pipe all look pretty clean.
Old 01-14-2008, 01:38 PM   #6
simprezl25
Member#: 71647
2002 Bug iD
txl146, thats kool you did the same thing, i recently changed my oil from castrol gtx 2w 30 to castrol synthetic blend 5w 30 and i am not losing oil at all and there is non in the catch can...before with gtx it would get all milky.
i think im going to get the maf cleaner and do the solenoid and maf
take care
Old 01-14-2008, 05:50 PM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
simprezl25, good luck with it. It is a good preventive maintenance thing that costs close to nothing.
Old 01-28-2008, 10:01 AM   #8
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Originally Posted by txl146 View Post
Update:
Thanks for the tips. Do the two hoses connected to it just pull off? Anything fragile inside?
mmiller2002 is offline   Reply With Quote
Old 08-03-2013, 07:21 PM   #9
bigbach007
Member#: 169175
2002 Impreza WRX
i know this is an incredibly old thread, but i just got a wrx and the boost solenoid is not hooked up! i was wondering if you have a diagram (or could just explain to me) of where the vacuum lines go and also if it matters which way they are hooked up? I'm assuming one goes directly to the wastegate and the other goes to the throttle body or intake plenum?
bigbach007 is offline   Reply With Quote
Old 08-03-2013, 07:29 PM   #10
bigbach007
Member#: 169175
2002 Impreza WRX
Nevermind... answered my own question haha. Found a diagram on google images.
http://www.google.com/url?sa=i&rct=j...75655198388016
WTB: Factory boost control solenoid (2003 WRX) sry110 Private 'Wanted' Classifieds 3 09-24-2009 02:46 PM
FS: APS 65mm CAI, GM boost control solenoid & OEM boost control solenoid roninsoldier83 Engine/Power/Exhaust 9 10-31-2007 08:56 PM
02 boost control solenoid Scion Private 'Wanted' Classifieds 1 03-13-2007 03:35 PM
WTB: 02/03 Boost Control Solenoid. STFU STi Private 'Wanted' Classifieds 3 06-14-2006 06:56 PM
how to clean boost control solenoid?? okamikatekore Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-03-2002 07:06 AM
