Old 01-15-2008, 07:59 AM   #1
alottaboost
Member#: 158029
2016 STi Limited
Pure Red
Default Injector size question
Just a quick (possible dumb) question. If I were to get larger injectors and a fuel pump installed with my stock turbo stage 2+ setup (so it's DONE when i decide to upgrade the turbo later) are there any other tables that need changed other than the one where you input the cc of the injectors? (name of table escapes me...)
alottaboost is offline   Reply With Quote
Old 01-15-2008, 10:58 AM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
You'll have to change the latency depending on the injectors you put it. To answer your question though, if you have the right injector scalar and latency you shouldn't have to change anything else.
06rexwagon is offline   Reply With Quote
Old 01-15-2008, 11:33 AM   #3
alottaboost
Member#: 158029
2016 STi Limited
Pure Red
oh yeah, they were going to be modded stockers, so latency won't change. that's good to hear! now i can send them to witchhunter!
Old 01-15-2008, 11:37 AM   #4
06rexwagon
Member#: 114730
[email protected]
Modded stock injectors do require you to change the latency if you don't want to have terrible fuel trims at idle.
Old 01-15-2008, 11:49 AM   #5
alottaboost
Member#: 158029
2016 STi Limited
Pure Red
ahh. guess i'll get witchhunter to figure out the latency too. thanks.
Old 01-15-2008, 01:46 PM   #6
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
You should scale your tip-in as well; otherwise, everytime you hit the throttle too quickly, you'll get a rich spot and black soot out of your tail pipe.
mickeyd2005 is offline   Reply With Quote
Old 01-15-2008, 01:47 PM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I think that's pretty expensive. Not sure.
It would be cheaper to ask what other people are using and then use that as a starting point. You can adjust it yourself from there to get the correct latency for your setup.
Old 01-15-2008, 03:16 PM   #8
06rexwagon
Member#: 114730
[email protected]
^^Good point ^^
Injector Size Questions spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-11-2009 06:52 PM
Injector Size Question- FP EVOIII16g Gfunk720 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 01-28-2008 12:15 PM
Fuel Injector Size Questions C J Newbies & FAQs 10 06-13-2007 08:42 PM
Emanage Ultimate Users - Injector Sizing Question MY99 2.5GT Engine Management & Tuning 1 12-19-2006 11:46 PM
Injector size question for my application (PE1820) wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-08-2002 06:41 PM
