Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 01-16-2008, 03:24 AM   #51
thejaredhuang
Member#: 86206
2006 WRX Wagon
This is my error if it helps:
block addr: FFFF3B80 len: 0080
[23:22:15.037] SSM2 write kernel ram block addr: FFFF3C00 len: 0080
[23:22:15.377] SSM2 write kernel ram block addr: FFFF3C80 len: 0068
[23:22:15.948] kernel get version
[23:22:15.978] readback mismatch
[23:22:15.978] reading kernel comm buffer size
[23:22:15.998] readback mismatch
[23:22:16.008] reading kernel flash buffer size
[23:22:16.038] readback mismatch
[23:22:16.038] interface close
[23:22:16.048] interface close
thejaredhuang is offline   Reply With Quote
Old 01-16-2008, 09:52 AM   #52
Tea cups
Member#: 103136
Are you using a tactrix cable? What operating system? If it is XP/Vista (only versions of windows supported by Ecuflash 1.34 BTW), then plug your tactrix cable in and go to the device manager and look under ports. Right click the tactrix (openport) cable and update driver. Select the location for the driver and choose the Ecuflash driver location (x:\openecu\ecuflash\drivers).
Tea cups is offline   Reply With Quote
Old 01-16-2008, 10:01 PM   #53
thejaredhuang
Member#: 86206
2006 WRX Wagon
XP with SP2, it should be a tactrix cable. The guy I bought it from said it was. Can you post a picture of yours?
Old 01-17-2008, 09:17 AM   #54
Tea cups
Member#: 103136
http://www.tactrix.com/images/OpenPort1.3Ssm.jpg
did you try what I suggested?
Old 01-17-2008, 11:42 AM   #55
unsakred
Member#: 115583
2006 Impreza 2.5i
San Remo Red
Tea Cups, was wondering if you could assist.
I am getting an error when i try to read from the ecu.
This is what the log displays:
18:01:48.468] kernel get version
[18:01:49.343] interface close
[18:02:04.062] Using interface OpenPort 1.3 Subaru TX46EF9xb42cb4d57c848f6101ada6c1370c8d3c0ea5a48c
[18:02:05.312] SSM2 init
[18:02:05.468] SSM2 ECU ID is 43 12 04 71 06
[18:02:05.578] Requesting Seed...
[18:02:05.656] Sending Key...
[18:02:06.328] interface close
[18:02:06.343] interface close
unsakred is offline   Reply With Quote
Old 01-17-2008, 12:05 PM   #56
Tea cups
Member#: 103136
probably one of the following:
1. your are not in test mode (diagnostic connectors not connected). To verify if you are in test mode turn the ignition to on (without attempting to read with Ecuflash) and after a few seconds the radiator fans should cycle.
2. You need to wait until prompted to turn the ignition on and then immediately hit ok.
3. You are choosing the wrong read method (should be 2005-2007 dbw wrx/sti for an 06 2.5i).
All of this is in the main ecuflash troubleshooting faq linked in this faq.
Old 01-17-2008, 12:07 PM   #57
unsakred
Member#: 115583
2006 Impreza 2.5i
San Remo Red
I didn't realize that the 2.5i needed the connectors to be connected.
Your other suggestions I was doing properly.
Old 01-17-2008, 01:54 PM   #58
thejaredhuang
Member#: 86206
2006 WRX Wagon
Yep I updated the drivers same result though. I was looking for a picture of the pins.
Old 01-20-2008, 03:02 AM   #59
thejaredhuang
Member#: 86206
2006 WRX Wagon
Tea cups, it was the cable. Thanks for the help though.
Old 01-23-2008, 08:18 PM   #60
goixiz
Member#: 99128
2005 SAAB 92x
where to get latest revision of enginuity ? and the defination files
goixiz is offline   Reply With Quote
Old 01-23-2008, 08:21 PM   #61
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Read the damned thread you just posted in. The very first post contains links for the software and the definitions.
Old 01-23-2008, 08:26 PM   #62
goixiz
Member#: 99128
2005 SAAB 92x
What if i use the latest def and flash with ecuflash 1.29 ?
Old 01-23-2008, 08:28 PM   #63
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Why are you still using 1.29?
Old 01-23-2008, 08:32 PM   #64
Tea cups
Member#: 103136
The latest definitions will only work with Ecuflash versions 1.30 or greater.
Old 01-23-2008, 08:40 PM   #65
goixiz
Member#: 99128
2005 SAAB 92x
because i have used it for a long time and it does its job.
i dont mind changing if its as reliable as the 1.29
all i use it for is upload the hex file to the ecu
Old 01-23-2008, 08:44 PM   #66
goixiz
Member#: 99128
2005 SAAB 92x
where do i get ecuflash 1.31 ?
Old 01-23-2008, 08:45 PM   #67
Tea cups
Member#: 103136
Use Ecuflash 1.34, the latest version.
Old 01-23-2008, 08:46 PM   #68
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Please tell me you're only asking that to get a rise out of me...
It's at the top of this thread, just like all the other software. The definitions are up there as well
Old 01-27-2008, 04:48 PM   #69
asdfghjklvt
Member#: 152386
2007 STi
Is the link to the lastest version of the enginuity software not working? I keep getting invalid achive error message? Did the file get corrupted?
I'm looking for the latest version of the enginuity software, can someone help?
asdfghjklvt is offline   Reply With Quote
Old 01-27-2008, 05:06 PM   #70
Tea cups
Member#: 103136
works fine for me
Old 01-27-2008, 05:47 PM   #71
asdfghjklvt
Member#: 152386
2007 STi
Strange. It worked for me after 20+ attempts. Not sure what I did differently. Some things I'll never understand.
Old 01-28-2008, 03:28 AM   #72
jibber
Member#: 6675
98 SF5 some mods
01 allroad
I too have had the corrupt file message when trying to download from Ken's site it seems hit and miss for me.
I finally found the site that Kascade put the files up on, and transferred the other files I needed from another computer.
jibber is offline   Reply With Quote
Old 01-28-2008, 12:21 PM   #73
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Great writeup, thanks so much!
Are there any repositories or collections of ecu files for our cars?
GuitsBoy is offline   Reply With Quote
Old 01-28-2008, 12:52 PM   #74
Tea cups
Member#: 103136
Some links to factory ROMs:
http://www.scoobypedia.co.uk/index.p...patibilityList
You can also find some at:
http://forums.openecu.org/
For tuned ROMs submitted by users and some you can buy (XPT), go here:
www.xpttuning.com
Old 02-03-2008, 04:32 PM   #75
TurmultTee
Member#: 83897
A Subaru
Impreza
When I try to install Enginuity there is an error
"java.io.FileNotFoundException: C;\Program Files\lib\j3dcore-ogl.dll (access is denied)"
Anyone else get this error. It seems like it's trying to read a file that dosen't exist?
TurmultTee is offline   Reply With Quote
romraider/ecuflash? weaponstroop Open Source Reflashes 8 10-21-2008 11:04 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 07:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 04:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 12:34 PM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 07:26 AM
