Old 08-15-2007, 07:13 AM   #51
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Moving this thread to the brake supersticky and unstickying it:
http://forums.nasioc.com/forums/show....php?t=1326319
Old 09-10-2007, 09:48 PM   #52
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
UsVERSUSThem WFC #197
Great thread Very helpful in looking for pads for my car. Thanks Jamal!
SubIELove is offline   Reply With Quote
Old 10-05-2007, 01:42 PM   #53
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
what's the widest rotor that non brembo 4pots can fit?
arco is offline   Reply With Quote
Old 10-05-2007, 02:35 PM   #54
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
about 25.4 mm - (stock is 24mm)
Old 10-05-2007, 09:32 PM   #55
BIGSKYWRX
Member#: 7958
09 GH B+
^ which the DBA 4000 and 5000 run- they also squeeze a extra mm in diameter over stock- every little bit helps
BIGSKYWRX is online now   Reply With Quote
Old 10-05-2007, 10:50 PM   #56
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Default Um, maybe OT but....
....could someone point me to info on the recommended way to depress the pistons on 2 and 4 pot calipers?(like during pad installation)
tia
Carl
1 Lucky Texan is offline   Reply With Quote
Old 10-05-2007, 11:04 PM   #57
jamal
Member#: 71875
98 Legacy GT
my wheels fit
the key thing is to do it slowly and evenly. C-clamps and channel locks work well, and you can buy a tool at autozone or whatever to do it. I also tend to put an old pad between the pistons and whatever I'm using.
jamal is offline   Reply With Quote
Old 10-22-2007, 06:18 PM   #58
99Lcoupe
Member#: 75789
Default HERES a good question !!!!!!!!!!!!!
where can i find 99L phase 2 drums ...ones from raybestos (autozone) didnt fit .... do i have to get genuine subaru? or maybe they just sent me the wrong ones ..really need help they squeal like a pig!
99Lcoupe is offline   Reply With Quote
Old 11-15-2007, 10:11 AM   #59
gregr01
Member#: 49333
04 STi
java pearl black
Thank you very much for this post!
gregr01 is offline   Reply With Quote
Old 01-10-2008, 01:11 AM   #60
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Was looking back over this.
Anyone know anything about the RA-R, or 08 STi brakes? Oh and they have new group N rally brakes too, right?
Mr. DBASteve, would you happen to have a spec sheet for the 5x114.3 294x24mm rotor that's used for rally?
Also I think I'm missing some newer Legacy/Outback/08 Impreza pad shape information.
Old 01-10-2008, 02:10 AM   #61
KNS Brakes
Member#: 125739
2015 WRB WRX
-afaik - the 08 STi has diff brakes - larger rotors but still an 'oddball' size (not 332 x 32)
-RA-R spec-C 6 pots seem to have not made it here - i think we get a variation of the 04-07 stuff
-I've sold brakes to an STi to run 'gravel' 4 pot/2 pot brakes - but i failed to keep track if it was an 04 or 05+- so I am not sure if the 'wrx sized' 1 piece rotor fits over the 5 x 114 hub with only a redrill of the 5 x 100 to the 5 x 114. I think it did though.
-k
Old 01-10-2008, 02:13 PM   #62
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Yeah I got a close look at an 08 sti recently and was like "hey, those brakes are different."
You can buy the RA-R brakes through japanparts.
I'm pretty sure there's an 05+ gravel rotor. I should probably e-mail vtsc or rocketrally something.
Old 01-13-2008, 05:59 AM   #63
DBAsteve
Member#: 16839
These are some pics I took last time Subaru made came out of the Bat Cave at home.
AP Racing two piece rotors front and rear. 343mm fronts and 300mm rears. This is a tarmac kit naturally. 18" wheels.
I'll see what specs I can post up.
DBAsteve is offline   Reply With Quote
Old 01-20-2008, 10:43 AM   #64
dan_m
Member#: 82836
Steve, if I understand correctly, in order to mount rear brembos on my 2005 USDM LGT I would need rotors #2657 ( post 38 ) plus those special kartboy brackets, is that correct?
dan_m is offline   Reply With Quote
Old 01-22-2008, 06:28 PM   #65
xdrian
Member#: 104200
000 WHP BUGEYE
Street Proven Performance
the 2008 sti rotors and calipers are still the same i believe, just looked on their website.
Brake discs Front: 12.7 in./Rear: 12.3 in.
xdrian is offline   Reply With Quote
Old 01-22-2008, 06:38 PM   #66
KNS Brakes
Member#: 125739
2015 WRB WRX
The rear is no problem - you can always redrill the 5x 100 to 5 x 114
In front - I dunno if the hat portion of the 4650 fits over the 05+ hub. Although the 4000 - w/ it's angled sides (see dba steve's dwg's above) might be the ticket there.
Old 01-22-2008, 07:26 PM   #67
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Well the rotors exist for sure. Whether or not it's a separate rotor made by Subaru for group N or if it's the same as the standard rotor but drilled 5x114.3 is the question I guess. Rallispec sells the 4/2-pots for 05+ stis.
Old 01-22-2008, 08:03 PM   #68
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
Have to post in this thread to give props to all the people helping out , and specially the guy who originally made this thread
THUMBS UP
AbACUZ is offline   Reply With Quote
Old 01-23-2008, 07:47 PM   #69
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Great compilation of info.
There are several other applications for the 290x18mm rear rotor in the JDM too.
They were on late GC-GF STis with the 190mm rear hand brake and on the GG wagon STis for their brief run.
They were and are on a number of upper end B4 and GT-Bs with the 170mm hand brake from 2000 on.
ss
subysouth is offline   Reply With Quote
Old 01-24-2008, 10:01 AM   #70
BIGSKYWRX
Member#: 7958
09 GH B+
ss
did the GGB run Brembos front and FHI two pots rear or FHI 4/2 pots?
Old 01-24-2008, 10:49 AM   #71
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Subaru 16x6.5 5 spoke 2.5 RS(98-99) in America, WRX everywhere else, clear the 06-07 4 pots just fine.
STiShawn is offline   Reply With Quote
Old 01-24-2008, 12:34 PM   #72
floyd the barber
Member#: 86382
2006 Wagon
SGM
Originally Posted by STiShawn View Post
Subaru 16x7 2.5 RS(98-01) in America, WRX everywhere else, clear the 06-07 4 pots just fine.
Fixed.
floyd the barber is offline   Reply With Quote
Old 01-24-2008, 12:44 PM   #73
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Just to clarify, 00-04 Legacy's also use the 2 rubber lines rear-brake line like the +05 Legacy (all models, not just the LGT). All due in part to the rear multi-link suspension that was started in the 00-04's.
rougeben83 is offline   Reply With Quote
Old 01-24-2008, 12:53 PM   #74
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I don't think brembos came along until the v7 sti.
I should link to the rear brake redux because that has a lot of the non-us brake specs.
Also it starting to look like the 08 STi brakes are not any bigger.
Old 01-24-2008, 02:34 PM   #75
BIGSKYWRX
Member#: 7958
09 GH B+
GGB=v7 STi wagon, just curious what they got for brakes f/r, ss stated they got 290x18 (FHI two pots)
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 10:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 04:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 03:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 05:24 PM
