Old 01-31-2008, 06:51 PM   #1
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
Default Fixed exhaust- is it torquier?
so i got my exhaust fixed from the cat back and being loud, getting pulled over 3 times in 2 weeks. so now she's super quiet again and it also seems like it has a bit more torque. would this be from added back pressure-or just that it goes without being noisier than hell?
Meat Supply is online now   Reply With Quote
Old 01-31-2008, 07:28 PM   #2
max427
Member#: 166887
1995 Impreza L
i was running my last project car on an open header (straight 6) and as soon as i put a exhaust on the thing really woke up.. theres science behind it. having an properly tuned exhaust aids in cylinder filling, by effectively removing exhaust gases before IVO and during overlap.
max427 is offline   Reply With Quote
Old 01-31-2008, 08:06 PM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
It works because the manifold isn't tuned. Normally in a tuned system you have the header consisting of the 4 primary pipes from each exhaust port, of a particular diameter and length, and coming together into a collector area, also of a particular diameter and length.
In theory, everything that controls the actual flow behavior and tuning of the exhaust is done via the header/collector only. Everything after this is essentially meaningless, if done right.
Now on most stock setups, there really is not much for tuning. Most primary piping is not equal in length, nor is there any real collector area nor any termination of the collector piping. The whole exhaust turns into part of the "system," and it can influence the overall behavior.
http://www.superchevy.com/technical/...exh/index.html
Old 01-31-2008, 08:10 PM   #4
Meat Supply
Member#: 137902
---- among the
ah! thanks!
Old 01-31-2008, 08:10 PM   #5
max427
Member#: 166887
1995 Impreza L
sounds better than what i said. although i do dissagree that everything after a collector is meaningless, especially on a car with more than one cylinder bank. H and X pipes have been dyno proven to increase power.
Old 01-31-2008, 08:33 PM   #6
GrundleJuice
Member#: 165749
Too add...
And tubing diameter is important on n/a cars to keep the exhaust gas velocity as high as possible without being restrictive... also, changing tubing diameter can hurt, sometimes a lot. changes in velocity, from slow to fast or fast to slow will hurt performance and the more changes in velocity (changes in tubing diameter) the more it will hurt performance. I dont know any formula to determine optimum diameter but i im sure there is one. the 2.5L subaru n/a motors are best around 2.25" ID under 200HP. The guys @ TWE said if aggressive cams are used or other mods that will make power over 200hp, a larger diameter tubing will be beneficial. seems like a rough rule of thumb but probably a good one since they are just about the best when it comes to subaru exhaust.
GrundleJuice is online now   Reply With Quote
Old 01-31-2008, 08:39 PM   #7
Meat Supply
Member#: 137902
---- among the
oh yeah, my new pipes are a bit smaller than the "stock" ones that literally fell off. maybe they're better this way.
Old 01-31-2008, 08:41 PM   #8
flatthump
Member#: 102749
2005 impreza STi
OBP'
The back pressure will help keep the air fuel charge in the cylinder on the very begining of the intake stroke, instead of it flying out the exhaust valve.....during valve over lap.
flatthump is offline   Reply With Quote
Old 01-31-2008, 11:54 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
But this is what you want. You need that flow from the intake side to clear out the spent charge from the combustion chamber. This is the whole idea behind scavenging.
Backpressure is always bad. You're running a big air pump. You don't want restrictions. Restriction = inefficiency.
Old 01-31-2008, 11:58 PM   #10
imprexaRS03
Member#: 145883
2008 wrx
psm
i experienced the same thing.i definetly noticedmore torque gains
imprexaRS03 is offline   Reply With Quote
Old 02-01-2008, 12:13 AM   #11
flatthump
Member#: 102749
2005 impreza STi
OBP'
Yes the whole air pump thing....You know it's more complex than that. Engines that dont make Peak VE around 7K rpm normally show a torque increase from an engineered (Atleast to a certain extent) exhaust manifold and post exh. manifold exhaust system. You want the intake charge to 'push' some of the very last exh. gas out of the cylinder, but you dont want the air fuel charge to leave out the exhaust manifold.
Old 02-01-2008, 04:46 AM   #12
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Wait...are you talking about exhaust scavenging? Cause...it's the exhaust gases leaving the exhaust that creates the slight vacuum to pull in fresh air from the intake side accelerating the air/fuel mixture...
rougeben83 is offline   Reply With Quote
Old 02-01-2008, 10:02 PM   #13
GrundleJuice
Member#: 165749
NO... backpressure is not bad... the correct amount of BP is a very good thing. You want some pressure to increase the velocity of the exhaust gas. Having a large very UN-restrictive exhaust will not keep your exhaust gas (and pulse waves) moving quickly which creates less of a low pressure area behind the pulse wave. this low pressure area is what helps "pull" the spend exhaust gasses out and the new a/f mixture into the cylinder. Having some of the new a/f mixture pass through the cylinder is a good thing because it ensures that no, or much less spent exhaust is left in the cylinder. It might waste a tiny bit of gas, but that is very neglegeable and if you are tying to make more HP, then fuel efficiency is something you have to sacrifice to some extent. Back to the pulse wave idea... tuned length headers (not just EL, but also tuned) will be a specific length from exhaust port to collector to create a reflected pressure wave to bounce and be back at the exhaust port ready to scavenge the next time the valve opens at the RPM the header was tuned for. Just wanted to share that so no one buys a 3.5" turbo exhaust for the n/a and then wonders why they dont make any power until just about redline.
Old 02-02-2008, 11:53 AM   #14
Project GC4-RS
Member#: 128264
1997 "GC8wannabe"
Brilliant Red
have a 97 L 2.2 SOHC, Borla 4-2-1 header, new oem converter, 2.25" mid-pipe with no resonator and 3ARacing muffler with silencer in it, noticeable torque gain with the silencer in, extremely doggy with it out, not sure why
Project GC4-RS is offline   Reply With Quote
I bought this exhaust...what exhaust is it? (pics inside) mookies Newbies & FAQs 10 03-25-2010 01:13 AM
BOOST SPIKE FIXED! or is it? HELP! toekneeyo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 04-28-2006 08:51 PM
Need Help. What kind of exhaust is it!!! ProdriveRex Off-Topic 54 03-24-2004 10:38 PM
what kind of exhaust is it??? ProdriveRex Member's Car Gallery 5 03-24-2004 04:56 PM
exhaust- is it measured by i.d. or o.d.? cvcsmkr Normally Aspirated Powertrain 2 08-30-2002 12:36 AM
