Old 02-02-2008, 04:32 PM   #26
Jon [in CT]
Member#: 2992
02 WRX Sedan
tinywrex, thanks for providing an explanation of how your launch control works.
http://tinywrex.wordpress.com/2008/0...-how-it-works/
Jon [in CT] is offline   Reply With Quote
Old 02-02-2008, 04:39 PM   #27
fasterthanurwrx
Member#: 82734
Maybe we can take a look at the NO LIFT SHIFT stuff again
fasterthanurwrx is offline   Reply With Quote
Old 02-02-2008, 05:24 PM   #28
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I was just reading that, and the LC uses a fuel cut. Wouldn't that cause lean condition? I was told that an ignition cut is safer.
.one lane is offline   Reply With Quote
Old 02-02-2008, 05:46 PM   #29
rkramer
Member#: 118209
2015 WRX Limitec
it isn't lean if there is zero fuel in the chamber to ignite. ignition cut is dangerous because now you have a full charge of fuel that is going to ignite somewhere. either in your exhaust manifold, turbo, or cat.
rkramer is offline   Reply With Quote
Old 02-02-2008, 07:18 PM   #30
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
so once it's patched, do you actually see a new "map" in the ROM where you can change the settings?
I can't check, as my ECU id isn't supported yet (A4TJ111C-RT)
Hyper is offline   Reply With Quote
Old 02-02-2008, 07:25 PM   #31
vaccine
Member#: 94490
Originally Posted by Tgui View Post
Half shafts feeling lucky?
no problems yet with the 6-puck i have in place.
Plus a friend has been dragin for at least 5 years and only just busted his first half shaft. that was on a 91 RS liberty with a 5spd dogbox that has ****ty half shaft joints and shafts half the thickness. and was more probably to do with the dccd centre he has now putting 70% to the back wheels.
Load the drive train-up and she is apples.Side step the clutch with no slack taken in the drive-train and you are asking for trouble.
vaccine is offline   Reply With Quote
Old 02-02-2008, 07:35 PM   #32
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
1 picture is worth a 1000 words
xswrex is offline   Reply With Quote
Old 02-02-2008, 07:36 PM   #33
xswrex
Member#: 87255
2002 Impreza WRX
factory rev limiter code works with fuel cut, can't be that bad ehh?
Old 02-02-2008, 07:38 PM   #34
xswrex
Member#: 87255
2002 Impreza WRX
no problem, i only hope it is clear enough for everyone to understand
Old 02-02-2008, 07:48 PM   #35
xswrex
Member#: 87255
2002 Impreza WRX
Old 02-02-2008, 09:49 PM   #36
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
any chance of patching the AUDM 2002 2.0L sti?
I can forward you a copy of my rom if required.
Also, will this cause any compatability problems when tuning the patched ROM with Enginuity and reflashing my patched and tuned ROM with ecuFlash?
wrxsti.l is offline   Reply With Quote
Old 02-03-2008, 12:15 AM   #37
gaveup
Member#: 116036
2015 WRX STi
Please dear god update us when you have a 32bit for the 06-07's (pleaasseee)
Ill be your best friend (By best friend I mean send you at least $50..depending on my current funds and all)
gaveup is offline   Reply With Quote
Old 02-03-2008, 01:50 AM   #38
WeldingHank
Member#: 98645
2002 WRX Wagon
So I can't view the tables in EcuFlash version 1.29 that i run on my win2k system. But i can on version 1.34. BUT in the getting started FAQ it states that 1.34 will only work on WinXP and Vista. So why Can i run it on my win2k system, or will it not be able to flash?
OR
Can I modify the tables in 1.34 then flash them with 1.29?
WeldingHank is offline   Reply With Quote
Old 02-03-2008, 02:34 AM   #39
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
sweet! I just patched my rom w/ the launch control. Truly awesome!!
thank you xswrex!!!
Old 02-03-2008, 02:40 AM   #40
xswrex
Member#: 87255
2002 Impreza WRX
as mentioned on site, patch can be created for any 16bit ROM, any market any region. A copy of your rom will be required
No compatibility issues or problems, you can even use Enginuity (or any editor for that matter) for editing as long as you port the XML parameters.
Old 02-03-2008, 02:44 AM   #41
xswrex
Member#: 87255
2002 Impreza WRX
i cannot answer on that, i suppose ecuflash will run on a win2k system but maybe the driver for the cable does not work properly under win2k
i believe you can, the flashing process just reads the file in binary format, it reads bytes, it transmits bytes!
Old 02-03-2008, 02:48 AM   #42
xswrex
Member#: 87255
2002 Impreza WRX
thank you xswrex!!!
you are welcome!
which rom revision? A4SGE01C?
Old 02-03-2008, 03:48 AM   #43
pbrink
Member#: 117334
2002 Impreza WRX
Default Wwwwwwwwoooooooowwwwwwwww!!!!
Just installed the patch and changed my map. This is really amazing stuff Thanks a lot!! I used the A4SGE01C revision in an 02 wrx and every thing went smooth, good instructions. A little change to the speed threshold and it will be smooth consistent launches. I was using a delta rpm of 3200 and a speed threshold of 20 k/hr and was hitting the limiter after the launch. Its a little wet out and I had a little too much wheel spin but to be expected.
Thanks again.
Parker
pbrink is offline   Reply With Quote
Old 02-03-2008, 03:57 AM   #44
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
Originally Posted by xswrex View Post
you are welcome!
yup! I need to edit the speed threshold value. I was bouncing off the rev limiter when I launched lol. LC rpm delta was set at 2200.
Old 02-03-2008, 04:53 AM   #45
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
So how hard would it be to put the threshold and delta in RAM?
And then write a little utility to tweak those values from a laptop using a Tactrix cable?
Old 02-03-2008, 04:53 AM   #46
xswrex
Member#: 87255
2002 Impreza WRX
A4TF800F-USDM WRX MY05 patch is released
http://tinywrex.wordpress.com/2008/0...reza-wrx-my05/
Old 02-03-2008, 05:09 AM   #47
xswrex
Member#: 87255
2002 Impreza WRX
Not hard, just time consuming. I am sure you understand that this is not a matter of copy-paste
Old 02-03-2008, 05:11 AM   #48
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
can the A4SGE01C patch be used with any 02 ECU as long as the xml code is inserted into the proper file in ecu flash?
EDIT: Tried it, and the inital values set for the RPM Delta and speed values are not 0 upon opening the rom for the first time in ECU Flash. I would have to say it's not safe use this A4SGE01C patch on an A4SGD10C rom, even though they are both USDM MY02 revisions.
Old 02-03-2008, 05:52 AM   #49
xswrex
Member#: 87255
2002 Impreza WRX
NO NO AND NO. Why oh why dont you read the instructions!
Really so whats new man? Every patch is ROM specific, i specifically mention that. The patcher should give error messages as well as it wont patch anything unless the original isnt exactly what it expects it to be. If all is ok it will just print "x bytes patched"
As others have suggested you can use A4SGE01C ROM on any USDM MY02 because it is the version that fixes some issues, that is why i created a patch for that first. If you want a specific A4SGD10C you just have to wait!
You should not mix things up in your head!
Old 02-03-2008, 10:36 AM   #50
Rogan
Member#: 142133
3 Jeeps
And a Saab
I used the A4SGE01C patch for my usdm02. Using the tinypatcher.exe, here's what I got:
Rogan is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 04:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 11:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 05:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 07:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 09:34 PM
