Old 02-03-2008, 09:48 AM   #51
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
Originally Posted by bchslap View Post
I used the A4SGE01C patch for my usdm02. Using the tinypatcher.exe, here's what I got:
rename it back to TinyPatcher.exe, as it says dont modify the executable filename
xswrex is offline   Reply With Quote
Old 02-03-2008, 10:05 AM   #52
Rogan
Member#: 142133
3 Jeeps
And a Saab
LOL I didn't rename the tinypatcher.exe file!
I only renamed my ROM.
Rogan is offline   Reply With Quote
Old 02-03-2008, 10:23 AM   #53
ralli02
Member#: 128687
2004 WRX Wagon
Very excited for the MY04 :-) Thanks for putting this together.
ralli02 is offline   Reply With Quote
Old 02-03-2008, 12:14 PM   #54
WeldingHank
Member#: 98645
2002 WRX Wagon
ok, so I can modify the map in Version 1.34 but it likes to crash sometimes. So, Can anyone give me a quick how-to to modify the enginuity defs so i can do it in enginuity and not worry about the program crashing.
WeldingHank is offline   Reply With Quote
Old 02-03-2008, 01:39 PM   #55
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
wait there's a ecuflash 1.34? I was using 1.33
.one lane is offline   Reply With Quote
Old 02-03-2008, 04:37 PM   #56
WeldingHank
Member#: 98645
2002 WRX Wagon
for those not running winXP or vista, you can run version 1.34 to modify the tables, then flash with 1.29 and the patch will still work. and 20k/mh is way too high for speed threshold.
Old 02-03-2008, 04:39 PM   #57
Fljason
Member#: 111054
2004 WRX Sport Wagon
Java Black Pearl
can;t seem to find the launch control for my04 usdm am i dumb or do i use the my05 wrx
Fljason is offline   Reply With Quote
Old 02-03-2008, 04:50 PM   #58
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
wow, thank you for getting this out!!
<---working on getting it setup up on Project L right now.
Justin
Old 02-03-2008, 05:04 PM   #59
Ralliart4
Member#: 135927
2002 Impreza WRX RA
wow this is some interesting stuff
Ralliart4 is offline   Reply With Quote
Old 02-03-2008, 05:25 PM   #60
Fljason
Member#: 111054
Java Black Pearl
nothing for the 520F
Old 02-03-2008, 08:10 PM   #61
Rogan
Member#: 142133
3 Jeeps
And a Saab
I keep trying, keep getting same result..
Just my luck LOL
Old 02-03-2008, 08:25 PM   #62
Nuke209
Member#: 108089
NF Performance
why not use the patch.bat file, worked for me
I tried it both Manually and the batch file, both worked.
TinyPatcher.exe (ROM FILE.Hex) (ROM.dif)
not tinypatcher or anything else, but TinyPatcher.exe
Tested the LC and it worked.
Old 02-03-2008, 08:32 PM   #63
goixiz
Member#: 99128
2005 SAAB 92x
Originally Posted by xswrex View Post
A4TF800F-USDM WRX MY05 patch is released
http://tinywrex.wordpress.com/2008/0...reza-wrx-my05/
thanks will try to install next week
goixiz is offline   Reply With Quote
Old 02-03-2008, 10:52 PM   #64
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Just my luck LOL
Rick I haven't tried it yet but it appears that you MUST have your ROM named the same as the stock ROM for it to work.
blkscooby is offline   Reply With Quote
Old 02-03-2008, 11:11 PM   #65
Rogan
Member#: 142133
3 Jeeps
And a Saab
I did it that way, too..
But I tried another method this evening, and got it to work.. sorta. then i had to modify the XML pasted portion to get it proper.
On VISTA:
1. apparently, I had to run the CMD as user, not administrator. (which is weird, on another level, but it IS a microshaft product...)
2. When it patched, and I copied the XML bit to the Impreza WRX file, I had to make a change: kph to MPH.
Reason for #2 was, that when I opened ECUFlash, and ticked the 'speed threshold' box, there was no box to put a numeric value, but the RPM box was okay. The SPEED box only had a button-looking thing in it, with "..." in the field.
After changing the xml paste to "MPH", it was fine, and allowed me to enter a speed value.
Here's what I pasted:
Code:
    <table name="LC disable speed threshold" category="tinywrex patches" address="2D2D0" type="1D" level="1" scaling="VehicleSpeed(MPH)"/>
    <table name="LC RPM delta" category="tinywrex patches" address="2D2D2" type="1D" level="1" scaling="EngineSpeed(RPM)"/>
I 'assume' this is due to the USDM not using KPH
the weird thing I see now, is, when looking at the actual Params > Misc > Rev Limit: both fields have "28" in the "ON ABOVE" and "OFF BELOW" data fields. In Enginuity, I see 7100 above, 7200 below..
Question: If I alter this "patched" rom, rename it something, and alter it more in Enginuity, will the FTL still be nestled in the HEX?
Old 02-04-2008, 12:48 AM   #66
Nuke209
Member#: 108089
NF Performance
Mine reads 7100/6900, nothing has changed.
Old 02-04-2008, 02:09 AM   #67
gaveup
Member#: 116036
2015 WRX STi
wait wait wait...You got yours to work on an 06?
explain how
gaveup is offline   Reply With Quote
Old 02-04-2008, 02:43 AM   #68
xswrex
Member#: 87255
2002 Impreza WRX
ONLY in order for the batch file to work
Old 02-04-2008, 02:53 AM   #69
xswrex
Member#: 87255
2002 Impreza WRX
Code:
hmmm, i only included XML for metric units (KMH) which is what the ecu uses natively. What you did is correct, changing the KMH with MPH. Although you could just add a line and leave the KMH as is (wont do any harm, just dont use it)
does the LC RPM Delta appear ok when you enter a value?
yes of course it will
Old 02-04-2008, 03:19 AM   #70
xswrex
Member#: 87255
2002 Impreza WRX
so patch is already 2 days on the air and no launch videos yet? come on people
Old 02-04-2008, 12:10 PM   #71
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Hey will this patch work for Bradens XPT maps? Could it be modified to do so?
Not-EWRX is offline   Reply With Quote
Old 02-04-2008, 12:16 PM   #72
paktinat
Member#: 155025
2004 WRX
^^^ +1
And if not, I;m going to have to switch back to gabedude's and tune that one up.
and lets see those videos!!!!
paktinat is offline   Reply With Quote
Old 02-04-2008, 12:19 PM   #73
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
He just needs the stock map and then Braden or I can apply the other XPT "fixes".
Gabe
gabedude is offline   Reply With Quote
Old 02-04-2008, 12:19 PM   #74
turboge
Member#: 35076
2004 507whp Wagon
I will be updating them when he has returned them. The new maps will be available once patched and completed. I've tested it on an 04 WRX and it works great.
turboge is offline   Reply With Quote
Old 02-04-2008, 12:20 PM   #75
gabedude
Member#: 10108
07 STI
07 STI.
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
