Old 02-01-2008, 09:08 PM   #1251
DS1
Vendor
Member#: 111780
Motul makes good stuff but it's pricey.
I'm testing out the Amsoil right now in my manual.
I like the Valvoline because it's inexpensive and effetive.
DS1 is offline   Reply With Quote
Old 02-04-2008, 05:24 AM   #1252
06wrxtr4me
Member#: 136959
2006 WRX TR
Protuned stage2
I am a fan of the USC as well and ran it for ~17k miles no problems. I just switched it out in favor of a 50/50 blend.
I did a ton of research on different types of fluids and compiled the results in this thread. There is even a testimonials table with links to positive and negative reviews.
06wrxtr4me is offline   Reply With Quote
Old 02-04-2008, 11:16 AM   #1253
strohausii
Member#: 26770
'02 WRX
midnight black
^ Thanks for posting that link, I'll read the other 3 pages later, but I like the part where you actually made contact with the Amsoil engineer.
strohausii is offline   Reply With Quote
Old 02-04-2008, 11:52 AM   #1254
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
I think now that all is said and done, I'm going to go with either the Valvoline synth (it gets cold here sometimes) or Amsoil 75W90.
It's starting to shift a little rough into 1st and 2nd gears these days, and I have almost 30k miles on LubroMoly 75W90
Asinine is offline   Reply With Quote
Old 02-04-2008, 03:03 PM   #1255
DS1
Vendor
Member#: 111780
06wrxtr4me- Your thread is a good read but all the research you showed was from Amsoil or Redline Oil, a little biased I think
Old 02-04-2008, 05:43 PM   #1256
shwaggin
Member#: 90017
2003 Forester 2.5X
WRC Wim-Wam Shaft
...I just looked up Castrol Hypoy C on Amazon, and it appears that lots of Subie owners are buying their cocktail supplies there. The related items even include a T70 Torx bit!
shwaggin is offline   Reply With Quote
Old 02-04-2008, 11:00 PM   #1257
06wrxtr4me
Member#: 136959
2006 WRX TR
Protuned stage2
It started as a kinduva comparo between the 2 and I had no one who ran anything abstract. I will gladly update the thread with data on other MFG's.
If you read page 2 post 22 thru 28, I have many different MFGs.
http://www.clubwrx.net/forums/showth...4288720&page=2
What other MFG's would you suggest I add?
Have any links to Motul 300 reviews?
Old 02-04-2008, 11:45 PM   #1258
stanton
Member#: 21508
'03 WRX Wagon
That Amazon page is funny.
06wrxtr4me - be careful saying certain products are equivalent just because of certain matching specs.
I have another data point. Took advantage of warm(er) weather over the weekend and change my transmission fluid. I didn't have the ingredients for the full cocktail, so tried Amsoil Severe Gear 75-90 (SVG). It's not as good as fresh cocktail, but much better than what I remember from the stock fluid. Within the gap of performance between stock and the cocktail, I would place SVG at about 65% there. A lot "freer" than stock, easier to get into gear (like reverse) when stopped, and can get into 1st while moving and double-clutching, but syncros don't grab as fast on both upshift and downshift.
stanton is offline   Reply With Quote
Old 02-05-2008, 12:08 AM   #1259
ringe
Member#: 49998
2007 WRX CT Stg 2
Originally Posted by neilschelly View Post
I'd like to ask that all the talk about other mixtures, other fluids, general non-cocktail discussion go elsewhere. Create your own thread with your own discussion and own insights about fluids. If you have actual related information to Uncle Scotty's Cocktail, post it, good or bad. But this thread has gone so far to hell in the last few pages that it's a candidate for off-topic at this point.
-N
Actually, I am glad to see someone with first-hand experience dealing with this in a professional way the way Dylan has. This whole idea of a "cocktail" is fundamentally flawed, starting with the statement, "Don't mix fluids from different manufacturers in your transmission!"
Add to that the use of fluids that don't protect your gears properly, others that have the viscosity of honey when cold and apparently seperate from the rest of the mix, and you end up with effectively 50% fluid that's supposed to be there and 50% fluid that ain't.
The guy with the 06 2.5i needs to leave well enough alone. "Chatter" is a description of clutch operation, not tranny operation last time I heard it used.
ringe is offline   Reply With Quote
Old 02-05-2008, 10:10 AM   #1260
Asinine
Member#: 55173
with paddles.
Or we could all stop arguing and buy a Toyota/Scion/Honda.
<--- was amazed at how nice those MTs feel compared to a WRX.
Old 02-05-2008, 02:14 PM   #1261
DS1
Vendor
Member#: 111780
Well said!
-Dylan
Old 02-05-2008, 03:10 PM   #1262
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Scion = Toyota...
But I agree... Nothing is more silky than a Honda gearbox. I miss mine.
Superorb is offline   Reply With Quote
Old 02-05-2008, 04:46 PM   #1263
DS1
Vendor
Member#: 111780
^^ ditto
Old 02-05-2008, 10:25 PM   #1264
skydes
Member#: 141347
2005 WRX
The stubborn Subaru 5MT just adds to the car's character right???
skydes is offline   Reply With Quote
Old 02-05-2008, 11:46 PM   #1265
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
In a negative way unfortunately.
Old 02-06-2008, 12:07 AM   #1266
fengrr
Member#: 169160
03 WRX
Black on WRB
Ringe, are you saying that this cocktail doesn't work as well as a stock fluid.
fengrr is offline   Reply With Quote
Old 02-06-2008, 11:38 AM   #1267
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
I think he's saying that the manufacturer recommends using a particular fluid and advises against mixing fluids. The cocktail goes against both recommendations, possibly at the cost of increased wear... especially if the large differences in viscosity/type of ingrediants could even be causing seperation which may result in uneven and limited lubrication.
So yes. In effect, at least in regards to wear, I think he is saying the cocktail is likely not as good as the stock fluid... How dare he do such a thing
jhargis is offline   Reply With Quote
Old 02-07-2008, 01:44 AM   #1268
ringe
Member#: 49998
2007 WRX CT Stg 2
Jhargis get's the cookie.
As far as "working" as well as the stock fluid, it seems that in some regards the Cocktail works better; for example, it seems to initially smooth out shift quality, and intially permit proper syncro operation.
The key word is "initially". The fact that you guys have to drop oil every third oil change is absurd, and indicative of the poor nature of this lubricant. You claim that you're saving money with this fluid, but frankly you would save even more money just using a good fluid that may not have the same seat of the pants feeling but also isn't going to wear off in a few months.
Old 02-07-2008, 07:48 AM   #1269
stanton
Member#: 21508
'03 WRX Wagon
To me, the more frequent exchange is worth it. I was frustrated enough with the stock fluid to stick with the cocktail for 3 years. I bought the car to enjoy it. I bought a 5-speed because I enjoyed shifting. If I have to change the transmission fluid more often, then I'm up for it.
I just spent $50 on Amsoil Severe Gear 75-90, and it's not good enough. I'll be going back to the cocktail, or something else that "works" better.
Old 02-07-2008, 01:43 PM   #1270
DS1
Vendor
Member#: 111780
^^ the money you spent in fluid over the last 3 years would have covered fixing what ever was wrong with your trans.
Have you tried the Valvoline 75w90 Synthetic?
-Dylan
Old 02-07-2008, 02:38 PM   #1271
strohausii
Member#: 26770
'02 WRX
midnight black
Who else is using Valvoline Synthetic?
Old 02-07-2008, 02:40 PM   #1272
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
Originally Posted by strohausii View Post
So you are familiar with DS1 Neil?
I have a healthy distrust of anything on the internet. For all I know he's just some guy looking to get some attention by making blanket statements and increase sales.
I know he's dead on with the honda tranny stuff, and jhargis has proven himself to be a great source of information from his hands on experience.
I do remember other "Experts (Cobb)" recommending MT-1 as "best of both worlds" fill back in 2002.
I think that you mean Redline MT-90. I ran MT-90 for about 10,000 miles and I perceived a great improvement over the Factory lube that I dumped at 1,000 miles from new. I am now running 1 qt. Synchromesh, 1 qt. Redline LW Shockproof and the rest of the fill up is with Redline MT-90. Amazing difference. Shifting is effortless and very smooth. I'm staying with it. Oh, I chose to stay with Redline products in the mix for two reasons. First is my past experience with their product line and secondly I felt that minimizing the different ingredients would be a safer route.
Steve Nastoff is offline   Reply With Quote
Old 02-07-2008, 06:27 PM   #1273
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
...but it wouldn't have covered his down time for the repairs.
Spenk is offline   Reply With Quote
Old 02-07-2008, 07:03 PM   #1274
ImprezaTron
Member#: 1549
04 Impreza WRX
Wingless White
Just switched to Valvoline SynPower two weeks ago. I was reluctant to go synthetic in the tranny after the general consensus on NASIOC is NO to synthetics. Even my mechanic warned me it will start grinding and recommended I add one quart synchromesh
I have been grind-free so far and shift feel has been fairly consistent. It did not eliminate the rough feel getting into 2nd and 3rd, but that probably means I'm going to be due for new synchros. Also I'm coming from using straight Castrol Hypoy C 80W-90 and I'm wondering if the mix of residual old fluid and the new Valvoline means I'm not getting the "full-effect" (I only got about 3.25 quarts put in, which seems to be the norm). As long as the shifts remain consistent, I'll be happy with the SynPower.
Basically all synthetics are NOT created equal. M1 Synthetic, which I'm guessing most of the complaints have been coming from, even says on the bottle that it has properties to be extra slippery. Also if the cocktail is working for your application and keeps you happy, stick with it.
ImprezaTron is offline   Reply With Quote
Old 02-07-2008, 08:43 PM   #1275
stanton
Member#: 21508
'03 WRX Wagon
$150 pays for a mechanic to think about looking at your car . I know it's hard to keep track of everyone here and their reasons for trying transmission fluid alternatives, but I'm one of the many who were very unhappy with normal actions of the stock transmission and fluid from day 1. There was presumably nothing "wrong" with mine. It was about preference.
Let me add that over the first 30k on the OEM fluid, my transmission developed additional vibration and noise between 1500 and 2000 RPM. What should I blame that on? Transmissions wear. The vibration got progressively more noticeable until I changed to the cocktail.
By the way the stock fluid felt at temps below 15F I can't imagine that "molasses" was doing any good for the bearings. Also the stock fluid is a compromise situation because of the almost mutually exclusive needs of the hypoid gears and synchros in the same bath, so I really don't expect there to be any perfect solutions.
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 05:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 11:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 05:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 09:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 09:36 AM
