Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 02-01-2008, 04:50 PM   #76
KSTech
Member#: 143570
Originally Posted by Leonardo View Post
If the MAF sensor wasn't diferent on the STi, I could have used my K&N Typhoon from the LegGT!!!
True. MAF Sensor on the 2008 WRX and STI are the same, but they are different than the WRX/STI/LGT of earlier years - smaller, fits into a smaller hole, and a totally different mounting flange. Stock intake on 2008 WRX/STI is also now 70mm diameter (like the LGT).
KSTech is offline   Reply With Quote
Old 02-03-2008, 11:26 PM   #77
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Did't see it but is it the same drop in filter as the LegGT and samr airbox to intake tube? Trying to see what I can carry over.
Leonardo is offline   Reply With Quote
Old 02-04-2008, 10:23 AM   #78
PERRIN
NASIOC Manufacturer
Member#: 6776
The filter may be the same. I am having Jeff check this morning to be sure. Also, the intake system is different. the MAF is different on the LGT vs. the 08+ WRX. Our intake kits will be out in later February if not sooner.
Be back later with more info!
Adam.Taft@perrinperformance.com
PERRIN is online now   Reply With Quote
Old 02-04-2008, 11:15 AM   #79
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Yeah, I knew about the intake as it says above my post!
Keep us updated as I'll be happy to carry my Blitz drop-in filter.
I know even SPT has an intake and god knows what else.
Old 02-06-2008, 01:52 PM   #80
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Bump for drop-in filter test!!!
Old 02-06-2008, 06:04 PM   #81
KSTech
Member#: 143570
I'm 90% sure the 2008 WRX & STI use the same drop-in filter as the 2005+ Legacy GT. I only have the lids of the two stock intakes sitting here in front of me at the moment, but they look identical except for the MAF sensor.
Old 02-06-2008, 06:14 PM   #82
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Rallitek confirmed they do but I had a warning from another member to avoid intakes, even drop-ins as these cars run pretty lean as is. (the STi)
Old 02-07-2008, 11:47 AM   #83
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
yep, if I think of any intake, it will be SPT.
Old 02-07-2008, 12:48 PM   #84
PERRIN
NASIOC Manufacturer
Member#: 6776
Why? They have had TONS of issues on the other cars they made them for. I agree they should be one of if not THE choice for people since it is sold at the dealer. But they are NOT good choices for the STi and WRX. Ask any technician at a Subi dealer that has had to deal with CEL's after the sale and installation.
Just my two cents!
Old 02-07-2008, 02:58 PM   #85
tunerman
Member#: 157637
Hey guys, check out www.5250tuning.com. They have pictures of the 08 STI with front and rear sway bars, Robi Spec KW Suspension & competition alignment. The products are available now.
tunerman is offline   Reply With Quote
Old 02-07-2008, 10:30 PM   #86
08WRX
Member#: 163140
02 Wrx
05 outback xt
Hey there, just thought i'd add to the list of things that transfer over. I have an '08 wrx sedan 5spd, i got bored at work today and pulled my car in, out of curiosity thought the 08 trans mounts look exactly like the prior years... we had an SPT trany mount in stock and decided to try it out, and YES it is exactly the same and love the feel of the shift now!!
08WRX is offline   Reply With Quote
Old 02-11-2008, 05:28 PM   #87
samagon
Member#: 26859
of TXIC
Just my two cents!
I think I remember reading about these, but I also think I remember that they redesigned the tubing to reduce the turbulent air that was going over the MAF.
regardless, you bring up a good point, never get anything without first making sure that the product is both not going to cause issues in your car, and the part itself is quality.
Old 02-11-2008, 07:47 PM   #88
djrossco
Member#: 90583
2008 WRX STi
Obsidian Black Pearl
My contribution:
1. Titanium Shift Knob from 2005 STI short shifter fits on the 2008 STI standard shifter
2. Floor mats from 2005 STI do NOT fit 2008 STI
djrossco is offline   Reply With Quote
Old 02-13-2008, 12:24 AM   #89
askjeffro
Member#: 164018
2008 WRX 5 door
WR Blue of course!
It's the same, and safe to use.
askjeffro is offline   Reply With Quote
Old 02-13-2008, 08:02 AM   #90
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
umm, read posts 77 and 78. Cobb and a few others have dataloged the car and notices it ran prety lean from factory. I won't touch the filter till I get the AP.
Still, need to get the STi first!
Old 02-15-2008, 04:15 PM   #91
Token`
Member#: 171839
2008 WRX Sedan
in 2 weeks invidia is comming out with an exhaust for the 08 wrx's, local shop called invidia directly.
Token` is offline   Reply With Quote
Old 02-18-2008, 03:38 PM   #92
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I was looking at the 2008 STi TMIC... I don't see why that won't fit a previous year subie... other than the passenger side bracket will definitely be different (which is fixable).
The turbo seems to be in the same spot, as does the throttlebody. I think that as long as you had all of the plumbing to go with the IC, it could swap down to a previous year subie w/o issue...
Comments?
-- Dave
AcquaCow is offline   Reply With Quote
Old 02-19-2008, 05:11 PM   #93
samagon
Member#: 26859
of TXIC
Comments?
-- Dave
I imagine it will be similar to using a 04-07 sti TMIC, there will be some fab work for the brackets, but other than that, you should be golden.
I think there will be a list of people who will want to get the take-off from the 08 sti, who have 08 wrx, for a cheap alternative to a bigger TMIC and easier access to bigger turbo options, and I would imagine for this reason that once people get modding on the 08s that the takeoff for an 08 sti will be a higher price than one for previous years, due to availability vs demand. but that is just speculation.
Old 02-19-2008, 08:06 PM   #94
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I had no issues switching from an 04 to 07 STi intercooler...
As far as I could tell, they were the same.
I really don't see any issue with me going to the 08 intercooler either, other than the passenger side mounting bracket, but I should be able to buy that from Subaru...
-- Dave
Old 02-19-2008, 09:11 PM   #95
samagon
Member#: 26859
of TXIC
-- Dave
right, the 04-07 TMIC on the sti is the same (provided it is USDM).
but using the sti tmic on a wrx required some fab work, that was what I was getting at.
as for using the 08 sti tmic on a older wrx or even an sti?
I haven't seen any dimensions on the 08 compared with the 04-07, so I can't say whether it would be worth the trial.
Old 02-19-2008, 10:47 PM   #96
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I just did a quick count on the rows of fins in the 2008 STi intercooler.
38.
Compared to 34 rows on the 04-07.
I overlayed the two in photoshop and scaled them accordingly. The 2008 STi intercooler looks to be ~2in wider than previous years, or however wide 2 rows of fins are... (I'll measure and post up...).
There are a few cutaways showing my older 04 intercooler so you can see where they line up/etc...
-- Dave
Old 02-20-2008, 12:28 AM   #97
samagon
Member#: 26859
of TXIC
38.
-- Dave
wow, that is a lot bigger, L, W, and Height!
guess I should start watching for a takeoff set, sti turbo + tmic
damn, that was fast, and I said all I was going to do power wise was DP and maybe CBE on this one..
Old 02-20-2008, 12:35 AM   #98
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
It's only wider... depth and height appeared to be the same as far as I could tell.
If you look at the top center of my chop, you'll see the top endtank of the IC is in the same location for both years...same with the bottom and right side...
The left side of the IC was just elongated a tad to fill the hoodscoop (FINALLY!).
-- Dave
Old 02-20-2008, 07:32 AM   #99
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Remember, that gap was was there to redirect cooler air down to the turbo.
Old 02-20-2008, 08:04 AM   #100
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
My turbo is wrapped and shielded... you can blow air down there all day, the turbo will never see it =)
-- Dave
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
