#1 |
Member#: 21445
Vehicle:08 STI silver |
Anyone know the dimensions of the 08 TMIC core? How much bigger is it than the 04-07?
TIA
#2 |
Member#: 156564
Vehicle:06 STI w/ 8cm 20g 08 Black GSXR 750 |
30% according to Subaru. not sure about the dimensions
#3 |
Member#: 2992
Vehicle:02 WRX Sedan Silver |
08 STI intercooler is on the left, 07 STI intercooler is on the right. 08 STI has 3.6% more volume.
#4 |
I just did a quick count on the rows of fins in the 2008 STi intercooler.
38. Compared to 34 rows on the 04-07. I overlayed the two in photoshop and scaled them accordingly. The 2008 STi intercooler looks to be ~2in wider than previous years, or however wide 2 rows of fins are... (I'll measure and post up...). There are a few cutaways showing my older 04 intercooler so you can see where they line up/etc... ![]() -- Dave |
#5 |
The 08 TMIC core dimensions are:
width: 21 5/8" height: 7.5" depth: 3" It is definitely wider than before, but seems to have pretty much the same depth and height. Tony |
#6 |
Member#: 47646
Vehicle:0200 JDM Wagon Rally coupe |
More cooling fins/channels, and better flow?
#7 |
#8 | |
Member#: 135150
South East
Vehicle:2006 WRX Sedan Blue |
I very interested in this top mount, if the right price comes along I will definitely grab one. |
#9 |
It should fit fine as long as you add the new mount on the passenger side.....although, in looking at the new mount it doesn't bolt up to the same place so one may have to "adjust" the factory mount from the previous models to get it to fit.
Tony |
#10 |
Member#: 157526
RMIC
Vehicle:2007 WRB STI 2009 R6 W/R |
I have the 08 sti ic and im having a hard time getting it to mount. You have to use the 02-07 mounts, PLUS another mount that apears to bolt onto GBOD.... I havent had any luck getting it to work on my 04 wrx
I think if you want to run this piece you have to have the 06-07 coolant tank plus a different GBOD. Not sure yet, but I will take pictures in a bit |
#11 |
Member#: 97652
Vehicle:07 STI Limited UGM |
bump! any updates on this....
#12 | ||
Member#: 164171
SCIC
Vehicle:08 EvoX <3 Wagon rear prodrive plate frame |
![]() p.s ill try to post up pics soon! |
#13 |
Member#: 132365
Vehicle:'02 WRX '05 A4 USP |
Any update with pics on this?
#14 |
Member#: 46135
Vehicle:2002 WRX WRB |
I am trying to track the changes done with the V8 Spec C Intercooler.
I've read the FAQ and I think it refers to the rear endtank center "gap", as an improved flow modification. I am looking at miscelaneous photos of JDM V8 Sti intercoolers, and they all seem to have this center "gap" in the rear. So I'm guessing that this design improvement, first tried with the Spec C became mainstream for JDM Sti intercoolers. Where I'm getting with this, is that in a post above, I see that the 08 Sti intercooler appears to now also have this improved endtank design. Due to how the photoshop overlay was done, I am not able to confirm this however. So, my question is: Does the USDM 08 Sti intercooler look like in the diagram drawing, with a "gap" in the rear endtank, or is this endtank continuous for US? |
#15 |
Member#: 209880
Vehicle:2006 STI white |
I actually just replaced my just replaced my 2006 sti tmic intercooler with a 2008 intercooler. To answer some peoples questions from what i can tell is that the fin density is higher on the than the previous years and it is about 4 or 5 rows longer.The only thing you have to do to install the intercooler a least on a previous years sti is extend the pasenger side bracket by a inch or two It also has the center gap that Vlad was talking about. Also it is a cheap mod because I sold my stock sti tmic intecooler on ebay for more than I bought the 2008 intercooler for.
#16 |
Member#: 151518
South East
Vehicle:2005 18g'd WRX CGM |
It is normal to fab a new bracket for larger intercoolers. My father in law fabbed one up for me that is very strong I'll try to find it and post pics as I'll need to use it again of make another for the 08 sti intercooler I just picked up
#17 |
But I have the real thing now: Bolted right up... 1/2 of the passenger bracket is the same as the old STi IC bracket... there is a second bracket that bolts to it and the passenger green bracket of death, but I opted to leave both passenger brackets off... -- Dave |
#18 |
Member#: 46135
here's mine
![]() A link to my review of the installation, bracket issues and clearances is in the FAQ |
#19 |
Member#: 98961
Vehicle:2003 WRX Black |
I need to order me one of those...
What did you do about the sealing gasket between the hood and intercooler? |
#20 | |
-- Dave |
#21 |
Member#: 46135
I have one, same level of sealing as OEM, I've put it together from 2 OEM gaskets. I'll take a photo soon.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| FS:(NY) 2004-2007 STi and 2008 STi Top Mount Intercooler at GREAT PRICES!!! | iwanasubi | Engine/Power/Exhaust | 15 | 10-19-2009 03:37 AM |
| Will a stock 2008 STi Intercooler bolt up in a 2008 WRX? | Derek E | Factory 2.5L Turbo Powertrain | 10 | 10-03-2009 06:57 PM |
| Fs: WRX Intercooler core, JDM STI TGV Deletes | Win0427 | VIC Private Classifieds | 3 | 02-26-2009 04:37 PM |
| 2008 Sti Intercooler | StupidFastWagon | Texas Impreza Club Forum -- TXIC | 7 | 02-25-2008 08:55 PM |
| Stock intercooler core sizes????? | hector | General Community | 9 | 12-06-2007 03:19 PM |
