Closed Thread
Old 02-21-2008, 12:41 AM   #1
greysave
Member#: 62395
2005 STI
Default Motor Pics
Hand ported head far away pic.
cosworth head far away pic.
Hand ported head close up shot.
Cosworth head close
Axis stage 3 10 miles aftermath.
greysave is offline
Old 02-21-2008, 12:47 AM   #2
SicWRX37
Member#: 99335
2001 Nissan Frontier
Red
Cosworths look amazing. What happen with that axis head?
SicWRX37 is offline
Old 02-21-2008, 12:51 AM   #3
greysave
Member#: 62395
2005 STI
Not quite an axis head, axis valvetrain custom port job. the piston hit the valve.
greysave is offline
Old 02-21-2008, 01:06 AM   #4
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
DAMN DUDE!! That sucks sorry to see that happened. What cams where you running?
-Rene
Rene2.5RS is offline
Old 02-21-2008, 08:03 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
so, I take it the cossie heads were the ones that ate it and now you are replicating them for you rebuild?...also what cams were you on?^^
Homemade WRX is offline
Old 02-21-2008, 08:22 AM   #6
Bilyk WRX
Member#: 89058
2003 WRX 9.63/150mph
EJ257+BW S374 735whp
sorry to hear that, but why?
Bilyk WRX is offline
Old 02-21-2008, 09:29 AM   #7
modaddict
Member#: 95840
sold to a good bud
awaiting next car
You can has stock AVCS mapping? lol..
modaddict is offline
Old 02-21-2008, 10:34 AM   #8
PPhilthy
Member#: 102948
2006 STI
More details on what went so wrong...
PPhilthy is offline
Old 02-21-2008, 11:13 AM   #9
Turbo_Mike
Member#: 130276
2004 Pontiac GTO
LS1 T56 RWD
Oh man that better not be what happened...
Turbo_Mike is offline
Old 02-21-2008, 11:49 AM   #10
greysave
Member#: 62395
2005 STI
-Rene
Kelfords with 10.3mm of lift.
greysave is offline
Old 02-21-2008, 11:50 AM   #11
greysave
Member#: 62395
2005 STI
No the coswroth heads are brand new. I am about to use them now.
greysave is offline
Old 02-21-2008, 11:51 AM   #12
greysave
Member#: 62395
2005 STI
I really don't know what you are saying there, but the avcs was set by phil on a hydra. I really don't know how much advance it was running I'd have to talk to him to find that out.
greysave is offline
Old 02-21-2008, 12:12 PM   #13
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Well that makes me worried about getting my cam timing spot on. I will be running Cosworth 278/274 with a 10.7/10.00mm lift when I get my motor back.
-Rene
Old 02-21-2008, 12:21 PM   #14
PPhilthy
Member#: 102948
2006 STI
So why did this failure happen...?
PPhilthy is offline
Old 02-21-2008, 05:38 PM   #15
BallPeenHamr
Member#: 126526
2007 STi Limited
#339 UGM
Man, those cossie heads are the secks! Good choice...
BallPeenHamr is offline
Old 02-21-2008, 07:23 PM   #16
modaddict
Member#: 95840
sold to a good bud
awaiting next car
If it was phil, then I'd probably trust how he set your avcs mapping up. assuming he knew you had cams.
-Rene
you will have to change the total amount of avcs, most likely. Or a valve has a good chance of tapping a piston.
(assuming you run avcs)
Old 02-21-2008, 08:20 PM   #17
flycaster
Member#: 60142
Grey
Huh. So this is what actually happened to this motor, eh? I remember this from the Ron&Phil thread a while back...just supposedly tooling around town, decelerating from 4K, "tink", and it immediately shut down.
Did you ever determine if this was an assembly error, or an AVCS tuning error? Seems to me that it was likely one or the other...
flycaster is offline
Old 02-21-2008, 09:39 PM   #18
greysave
Member#: 62395
2005 STI
The valves hit the pistons because wrong spec pistons. I don't think there were any valve reliefs cut in these pistons.
I agree with that it could be either. But on the other hand this was my second motor this particular motor has had 3 separate failures the third one being catastrophic didn't make me feel like I wanted to mess with this builder anymore personally. Besides a car with oversized cams and oversized valvetrain should have pistons with valve reliefs right? I don't see any valve reliefs besides the ones the valves relieved them selves on.
greysave is offline
Old 02-22-2008, 01:39 AM   #19
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
06 WRX does have avcs and I bought the avcs cams from cosworth. And pointers on getting the avcs dialed in? is it possible to just zero out the avcs table during break in?
My Wiseco 100mm (0.5mm oversized) pistons are dished as well as have valve reliefs in them. I would agree that it is odd that yours do not.
-Rene
Old 02-22-2008, 02:19 AM   #20
flycaster
Member#: 60142
Grey
OK, you have my curiosity going. If you're up to it, let's do a little autopsy work here:
How did the other pistons look?
Did you hear any light "tapping" or "ticking" at any other time during that first 10 miles?
Make and model # of the pistons?
Headgasket thickness?
Was anything decked?
Old 02-22-2008, 05:16 AM   #21
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Only ONE cyl? Where are the pics of all 4?
speed_freak27 is offline
Old 02-22-2008, 05:16 AM   #22
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
double post
Old 02-22-2008, 09:33 AM   #23
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Please take a picture of your pistons.
Please also take a picture of the cylinder heads (I wanna see the valves).
Old 02-22-2008, 09:35 AM   #24
modaddict
Member#: 95840
sold to a good bud
awaiting next car
-Rene
Yes, it's possible to zero the table.
The best bet is to contact a tuner and see what amount of avcs they use for your specific pistons and cams. With those cams, for sure you won't be able to run the 30* or whatever the stock map provides.
tune her up to you hear the noises and back her off a little
Old 02-22-2008, 11:35 AM   #25
PPhilthy
Member#: 102948
2006 STI
Would you please post pics of the other three pistons and valves...? If it was wrong pistons, I would think every piston would be trashed...
So this motor was built by Ron?
PPhilthy is offline
Closed Thread
JDM Version 8 motor pics ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-17-2005 11:28 PM
wiring help for my motor *pics* ImprezaRSfan! Subaru Conversions 9 05-10-2004 10:20 PM
Blown Motor Pics Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 10-13-2003 03:09 AM
Updated BLOWN motor pics IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 09-30-2003 03:42 PM
New motor Pic brokeawd Alaskan Impreza Club Forum -- AKIC 7 05-24-2002 06:44 PM
