Old 03-05-2008, 06:50 PM   #1
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
Default Help me!!!
I am ready to drive this car off a cliff.
We have an 01 2.5RS, the engine started to have a bad misfire. I replaced plugs and wires, no improvement. Took it to a dealer, they found a cracked y-pipe, also showed codes for misfires on 2,3,4 cyls, cat sysytem efficiency below threshold (p0420), evap emission control system malfunction (p0440),
and evap system vent control low imput. We replaced the y-pipe and cats, now runs even worse. If revs go below 4000, the engine just about dies. While we were waiting for cats to come in, the shop put a straight pipe in, and the car ran fine. They installed the cats today and its bad again. Does anyone have any ideas why this would happen?
Mike
Susie's Suby is offline   Reply With Quote
Old 03-05-2008, 07:23 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
maybe o2 sensor or bad coil
novacivic is offline   Reply With Quote
Old 03-05-2008, 08:06 PM   #3
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
Is there any way to test the coils? and if they were bad, would they still work at high rpm's?
Mike
Old 03-05-2008, 08:24 PM   #4
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Do you have a digital multimeter? you can use that to check the resistance of the coils but I dont know what the spec is............and no the higher the rpm the more load is put on the ignition system...
Subyroo2.5 is offline   Reply With Quote
Old 03-05-2008, 08:56 PM   #5
subtoy
Member#: 173384
Try spraying some water on the coil,if it sparks it is no good.
Does it run bad all the time?
Could have jumped time if it runs rough all the time.
May have to do a leakdown test just to make sure cylinders are ok.
subtoy is offline   Reply With Quote
Old 03-05-2008, 09:22 PM   #6
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
It runs strong over 4000 rpm's, but wants to die below, while you are driving. It will idle about 10-15 seconds smoothly, the drop to below 500 rpms and shake. If you give it the gas it will pick up revs immediately, but then repeat the low idling and shaking. It is very frustrating.
Mike
Old 03-06-2008, 08:59 AM   #7
bobko
Member#: 64646
1995 Legacy wagon
Green
Mike
Could be a vacuum leak. If you can, try to listen under the hood while the engine is running -- a vacuum leak can often be heard as a loud hissing noise. An engine with a vacuum leak (cracked rubber hose, usually) will show exactly the symptoms you describe: smooth and normal at high revs, but stumbles and dies at idle.
You could also check the idle air control valve (IACV or IAV, depending on who you talk to). However, a vacuum leak is the first thing I'd look for and it's easy/cheap to fix.
--Bob
bobko is offline   Reply With Quote
Old 03-06-2008, 12:44 PM   #8
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
--Bob
Thanks--there *is* a hiss... Are there hoses that aren't in plain sight to check? I sprayed carb cleaner on the ones I could see, but they seemed okay.
Old 03-06-2008, 05:33 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
on an 01 RS...hmm....there is a vacuum hose to the pressure regulator and cruise control on the passenger side pointing towards the rear. there is the brake booster on the driver side, also pointing to the rear. you can also try looking at the manifold gaskets for the intake, TB, MAP....ummm. IACV too. maybe check the bolt tightness on some things. also check the hose for the gas tank pressure relief, it's right behind the alternator/PS pump. may have a purple electrical connector.
yarrgh is offline   Reply With Quote
Aaargh! Help me Neek! Help me Tom Cruise! banman Off-Topic 16 09-08-2006 01:50 AM
Help Me, Help Me, Help Me! againstdan Newbies & FAQs 9 11-11-2005 10:26 PM
I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! Asinine Off-Topic 7 03-03-2005 12:33 PM
Help Me! Help Me Please! wrxxxappeal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-10-2003 11:14 AM
Help me/Help YOu/Help ME MichiganRS General Forum Archive 7 12-15-2000 08:54 AM
