Old 03-17-2008, 09:06 PM   #1
JLow03
Member#: 34959
2003 330i ZHP
1987 325is
Default Bilsteins vs. GR2s - am I going to notice any difference
Hey guys.
I was all set to buy some Bilsteins when I got nervous after searching through the threads that I'm not going to see any difference between that and what I have now (Whitelines + GR2s). Can anyone put this issue to bed? Am I going to have a stiffer ride (which is what I want)? Or would I be better off getting some polyurethane bushings and a front sway bar to compliment the RSB and call it a day? I plan to autox the snot out of this car this summer and want to have a serious suspension. And no, I'm not doing Teins.
Your advice is appreciated.
Thanks,
JL
JLow03 is offline   Reply With Quote
Old 03-17-2008, 09:15 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Koni 5
linsavy is offline   Reply With Quote
Old 03-17-2008, 09:20 PM   #3
JLow03
Member#: 34959
2003 330i ZHP
1987 325is
Thanks, but this is for a BE. I don't think Konis make struts for the BE, but I'd gladly be proven wrong.
JL
Old 03-17-2008, 09:36 PM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Bilsteins ARE serious suspension. If you autox the snot out of any car, there's not too many mass-produced shocks that are rebuildable that are better than Bilsteins.
I would run Bil's over Teins anyday.
Huffer is offline   Reply With Quote
Old 03-18-2008, 12:28 AM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Originally Posted by JLow03 View Post
Hey guys.
Thanks,
JL
It's all in the damper settings and the ability of the suspension to retain those setting after repeated, constant use (like track days and stuff) Bilsteins are valved stiffer for both rebound and compression (I'm not sure how much stiffer TBH) than the GR2's and the monotube design (for the fronts at least, I think the rears are still regular dual like the stock stuff) is a more stouter design to keep the valve temps down and keep the valving the consistent even after some serious cycling from track use and the like.
For autox, I really don't think gr2 or bilstein will matter as much as the other more important mods, like tires, alignment, and swaybars (in order of importance). When you address the first three, then you may want to start thinking about the struts.
rougeben83 is offline   Reply With Quote
Old 03-18-2008, 02:30 AM   #6
Hiroki Tada
Member#: 8048
with heavy auto-x/tracking the gr2s lasted me 3 years. they did the job, but good predictable tires would help much more. id say to spend the money from the struts into an extra few events if you have the time.
here is my car on gr2`s and whitelines. this is the sharp right at the end of the long straight at shannonville motorsports park. about 110km/h+ or so. pretty balanced, no complaints for the money spent.
Hiroki Tada is offline   Reply With Quote
Old 03-20-2008, 12:17 PM   #7
Markus_F
Member#: 134052
2010 Legacy GT
Hey Hiroki -
Great pic, good to see a BE on the track!
- Mark
Markus_F is offline   Reply With Quote
Old 03-20-2008, 12:54 PM   #8
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
yea that looks great loaded like that...how do the whitelines ride for the street?
Kawikid20o2 is offline   Reply With Quote
Old 03-20-2008, 08:21 PM   #9
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
That does look good!
The H&R's are great for the street BTW. If I had to describe it, I'd say it rides like a truck, as you can feel more of the road, but it isn't harsh by any means, it's still smooth. Cruising on the highway is great.
legacy99black is offline   Reply With Quote
Old 03-21-2008, 12:46 PM   #10
sonicjet
Member#: 169950
I think Bilsteins are to soft. I think you will see the diff.
sonicjet is offline   Reply With Quote
Old 03-21-2008, 11:31 PM   #11
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
The bilsteins feel soft because they don't have all the extra high speed damping that you don't really need to handle well.
MCarp22 is offline   Reply With Quote
Am I going to die? (I'm not going to die!) infinite012 Off-Topic 30 02-02-2010 01:37 AM
Notice Any Difference from a LWP? iyzmi Normally Aspirated Powertrain 8 08-10-2008 12:56 AM
Am i going to go to jail PhilKaiser Off-Topic 45 09-21-2007 02:46 PM
Will I notice any differences in spectating at LSPR this year? RebelINS Mid West Subaru Owners Club Forum -- MWSOC 7 10-06-2003 10:20 AM
AM I going to get beaten to death b/n flagstaff and Albq? HamFist South West Impreza Club Forum -- SWIC 3 02-16-2002 12:09 PM
