#1 |
Member#: 173029
SCIC
Vehicle:2005 WRX Sedan Silver |
This is a do it yourself Check Engine Light (a.k.a. CEL) fix for the WRX for use after installing an aftermarket downpipe (a.k.a. DP) with either a high flow catalytic converter or no catalytic converter (a.k.a. Cat) at all and you are getting a cat efficiency code.
If you already know how to do this, or you have seen similar threads, then that's awesome, just don't reply to my thread saying, "There is already info on this out there" or "you just need to do a search and figure it out". I did both of these and figured it out myself. I just don't think that if someone wants to do this exact same mod, they have to search and piece together information from different threads. This is a specific how-to article for this exact mod only... the information has been pre-pieced together for you. Ok... the idea behind this fix is to basically confuse... well, actually, not confuse... trick is a better word... trick your car. By pulling the O2 sensor out of the direct flow of exhaust and isolating it inside its own little space confuses the car into thinking that the air coming through your new catted or catless DP is clean. This fix in this thread was performed on a Catted Helix Downpipe on my 2005 WRX sedan. Ok... so first of all, this is what you will need for this fix. 1. Two 18mm spark plug non-foulers (a.k.a. anti-foulers). I bought the "HELP!" brand (part #42002) at my local pepboys, however they can be found at many auto parts store out there. Cost: $4.50 2. A 1/2 inch drill bit. Cost: $12.50 3. Access to a power drill or drill press 4. A vise... a table vise, bench vise, workshop vise, whatever you want to call it. You just need one. ![]() Alright... here we go. Step 1. Raise the front of your car up on jacks. Remember: When putting your car up on jacks to always be on a level surface and firmly set your parking brake. Step 2. If the sensor hole in your exhaust is already unplugged, great! If it's not, Unscrew the plug from the rear sensor opening in the rear section of your new downpipe as seen below. If you didn't remove the oxygen sensor from your car during your DP installation then cut the zip ties that are holding the cable down and unplug it. Once it has been removed from the car you can wipe off all the old exhast dust from the sensor with a dry towel. Set it aside for now. ![]() Step 3. Take one of your spark plug non foulers and drill a 1/2 inch hole through it to make clearance for the O2 sensor to fit inside it. This can be done with a power drill and a vise... the metal is relatively soft. See before and after below: ![]() Step 4. What you are going to do now is screw the oxygen sensor in the non fouler you just drilled and then into the non fouler that you have not drilled... like so: ![]() ![]() Step 5. Put this setup into a vise and tighten down both connections with a 22mm wrench. Step 6. Screw this whole setup into the rear hole of your downpipe. Screw it in there pretty tight as you don't want any exhaust leaks. ![]() Step 7. Plug it back into the black female O2 sensor cable found on the drivers side. Step 8. If your wrx already threw a CEL at you, then you need to reset your ecu. To do this all you need to do is grab a 10mm socket or wrench and disconnect the negative end of your battery. Depress the brake for roughly 5-10 seconds (i have never needed to depress the brake any longer than this in order to drain the leftover charge flowing through my car) and then reconnect the battery. Enjoy your clean instrument panel! ![]() I'm not a professional auto mechanic, so If I have misinterpreted anything or explained anything incorrectly, then please PM me with any contradicting references that you have come across and I'll fix it pronto. I have always used forums for "how-to" articles and I have never made one, so I felt it was time to start giving back! I hope this is a good start.
#2 |
Member#: 139289
Vehicle:2003 WRX Wagon PSM |
nice write up, but didn't someone already have a few pages on this mod?
#3 |
Member#: 68604
Vehicle:06 STi OBP |
Nice pictures, but http://forums.nasioc.com/forums/showthread.php?t=424666
#4 |
Member#: 65864
Vehicle:Kind of stock wagon but not really at all. |
Nice. Even though there is a thread already, this is easier for a noob to follow; instead of sifting through all those pages
#5 | |
Member#: 173029
SCIC
1. It is way easier. 2. It fits better. 3. It looks a lot cleaner. 4. You don't need to weld anything. 5. The parts are cheaper. If you have a welder (like Macabre, the person who posted the referenced link above) then i guess you could do it that way, but i have access to a mig welder, and I decided to do it this way because of the above reasons. I dunno ... a lot of these DIYs are subjective, but the point is... that this one works and its cheap. |
#6 |
Member#: 152885
Vehicle:05 wagon 16g-xt E85 6speed JR tuned |
good write up. Ive been doing this mod exactly as you write it for 3 cars now with no CEL's.
#7 | |
Member#: 68604
I'm not going to knock this thread, but I found out how to do this with a little bit of searching (back when the search sucked balls, mind you) and a little bit of brain matter to piece information together. |
#8 | |
Member#: 173029
SCIC
I don't understand what is with people... I took time out of my day to go back and take pictures of what i had done earlier that day to help people out there who had the same problem i did, and I keep getting people who are saying i didn't need to post it. Well, there are thousands and thousands of threads that aren't of use to EVERYONE out there, but there are definitely some people out there who really need them, so if this thread is of no need to you as an individual, then don't say anything unless its a complement, and move on with your day. I can guarantee you that at one point or another, sombody (hopefully more than just a somebody ) will find this thread and use it just the way it was designed to be used. As a HOW-TO, not a target for criticism.If you already know HOW TO do this, then you have no business reading it, or wasting your time commenting on it. Sorry if this thread bothers anyone, but i made it because i couldn't find one like this when i wanted to do this same thing to my car, so i did it to help out those who are in the same situation. So, if you're not in said situation, and you're not leaving a complement (BTW, thanks for the complements from everone! ) then i don't know why you're leaving a comment.SO, that having been said, lets try and save the criticism for things a little more important than how-to threads that you already understand and have figured out for yourself. The only criticism that i want, and that i have previously stated in the original post, is if i have misinterpreted anything or explained anything incorrectly. I know that there are other threads out there that contain similar information, that is how i figured it out for myself, but if one person pieces together all the information regarding one issue and puts it all together in one thread, that will save a lot of people a lot of time in the future. |
#9 | |
Member#: 173029
SCIC
Thank you! Nice... it's good to hear its a reliable fix. |
#10 | |||
Member#: 68604
#11 | |
Member#: 173029
SCIC
Thanks for saying it was a good thread, but it doesn't mean much when you follow it up right away with "... BUT, I found out how to do this with a little bit of searching". So what... a ton of people just like you found out how to do it with a little bit of searching, including me... I don't really care that you found it with a little searching. I obviously didn't make the thread for people like you who already know how to do this, so leave it alone. You're commenting on a thread that obviously doesn't concern you sine you already know how to do it, so just drop it. I don't understand why a comment like "I found out how to do this with a little bit of searching (back when the search sucked balls, mind you) and a little bit of brain matter to piece information together" is even warranted. Are you trying to say that my thread is of no use to this community? because i assure you, it will be used. I'm not the only person who has recently done this to his/her car. If you really feel that this thread doesn't belong... then take it up with a moderator and quit scrutinizing my thread. |
#12 |
Member#: 164864
Vehicle:95 Impreza coupe |
Nice write up but do you know if this would work for an N/A car to, I was thinking of gutting my cats but didn't want to get any cels so if this could work for N/A's too that would be great.
#13 |
Member#: 163775
Vehicle:1984 Sheep Dog |
Great write up man! Much easier to follow that those other ones.
Those of you knocking it.... Shuuuuuut uuuuuup. It's simple and to the point. |
#14 |
Member#: 173029
SCIC
#15 |
Member#: 145440
Vehicle:MY96 WRX GT2835-ProS EJ20G 2123cc!! |
#16 |
Member#: 149947
TXIC
Vehicle:2007 SPT WRX Obsidian Black Pearl |
nice - i did the same thing on my civic when i went to a cat-less system.
the only thing i think is missing, is what size non-fouler to use. I know from when i did my civic there were 3 or 4 diff sizes. ![]() other than that - good job ![]() |
#17 |
Member#: 173029
SCIC
Whoops.... sorry about that, they're 18mm, I'll go add that in. Thanks!
#18 |
Member#: 176014
VIC
Vehicle:2003 wrx wagon Rally blue. |
Thank you very much, this is very helpful. Feign is bored and is a douche.
#19 |
Member#: 162421
This thread actually helped me...I wasn't sure if I wanted to go with a catless downpipe b/c of the CEL, but now it's clear that's the direction I'm going to go. Plus, I don't have a clue on how to weld.
Thanks for the write-up. |
#20 |
Member#: 107189
Vehicle:2006 Subaru STI WRB eBay: rainbowarior |
I did this fix, but it didn't really work for me. After about 3 days of driving, my check engine light came on again. When I look up the code in my accessport, it comes up as no code found. This has always been ever since I went catless. I have a turbo XS downpipe and Perrin catback on an 06 sti... any suggestions????
#21 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Great write up. We need more write up with pictures.
#22 |
Member#: 173029
SCIC
Thank you to all!!!
#23 |
Member#: 147328
SCIC
Vehicle:2007 Silver WRX w/VF39 |
Nice write up. Thanks.
#24 |
Member#: 43115
Vehicle:02 wrx silver |
I wish I would have known about that before I bought the cel fix online which is exactly what you did, but it included the resistor as well...I would have saved a bunch of money. Good job!
#25 |
Member#: 129428
Vehicle:2002 Wrx |
Do you think that I would be able to pass NY inspections if I did this to all my sensors? I have a complete catless turboback.
| Thread Tools | |
| Display Modes | |
| How To: DIY TGV Deletes | Jasper | Factory 2.0L Turbo Powertrain | 112 | Yesterday 11:42 AM |
| How to: DIY 3.3Ohm resistors | jas0nn | Interior & Exterior Modification | 20 | 08-07-2009 11:26 AM |
| How To: DIY Radiator Cooling Panel | StretchSTI | Interior & Exterior Modification | 28 | 10-29-2007 04:06 PM |
| How To: DIY Angled Licence Plate | StretchSTI | Interior & Exterior Modification | 29 | 10-18-2007 04:41 PM |
| Scoobysport downpipe CEL fix - status? | rwroth | Factory 2.0L Turbo Powertrain | 0 | 12-27-2001 11:32 AM |
