Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
View Poll Results: Ramps or Jack stands?
Ramps 26 44.07%
Jack stands 33 55.93%
Voters: 59. You may not vote on this poll
Old 03-19-2008, 07:09 AM   #1
mr2aniac
Member#: 130693
Default What is safer? ramps or jack stands?
I'm having a debate with a friend who thinks ramps. I say jack stands.
mr2aniac is offline   Reply With Quote
Old 03-19-2008, 07:12 AM   #2
imprezaowner27
Member#: 131299
2006 Impreza
both if used properly
imprezaowner27 is offline   Reply With Quote
Old 03-19-2008, 08:06 AM   #3
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
^^ +1
Doc Holiday is offline   Reply With Quote
Old 03-19-2008, 08:24 AM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
I personally dont like driving up the ramps - they never stay put when you drive up them... Also cant take the wheels off with ramps...
gto7419 is offline   Reply With Quote
Old 03-19-2008, 08:56 AM   #5
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
+1
i bought a set...used them like twice.
Proper jack and stands ftw.
CC4nj is offline   Reply With Quote
Old 03-19-2008, 09:04 AM   #6
GreasyJoe
Member#: 112037
2002 WRX Wagon
Red
I also prefer stands, but not for safety but because they are easier to work around. Can also get the car higher.
I also usually feel safer puting the car on them, ramps move sometimes and I'm always afraid I'll drive off the end.
Stands can sink into soft surfaces though, and sometimes I worry abou the pin breaking. I've also seen really cheap ones that had the legs spread and bend.
I'd say they're both somewhat dangerous.
GreasyJoe is offline   Reply With Quote
Old 03-19-2008, 10:28 AM   #7
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I use ramps with the little extenders in front so the front doesn't hit. I've got a concrete driveway so no problem with sinking. Changing/rotating wheels and tires, I use a hydraulic jack and stands. (ramps used for oil changes) RP
drivin blind is offline   Reply With Quote
Old 03-19-2008, 01:26 PM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I use the ramps(plastic) a lot for the speed factor but as above some jobs you just cant do on the ramps. I feel the ramps are safer from a tipping standpoint just because they have a bigger footprint. I use them so much and the AWD on the Subarus makes driving up the really easy for me but ymmv.
So for me ramps first if you can use them for the job.
ss
subysouth is offline   Reply With Quote
Old 03-19-2008, 01:59 PM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
A buddy of mine was working on a friends LS1 and had the car on jack stands fixing the starter or replacing it when the starter jumped and the car tipped off the stand onto him. This is a guy who does all his work and very experienced. It shows that anything can happen.
blackfang is online now   Reply With Quote
Old 03-19-2008, 02:07 PM   #10
Garage Spec
Vendor
Member#: 133383
2004 Subaru GDB STI
both are reliable if used correctly.
i prefer jack stand over ramps because it feels more stable.
Garage Spec is offline   Reply With Quote
Old 03-19-2008, 05:05 PM   #11
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
stands
imprezilization is offline   Reply With Quote
Old 03-19-2008, 09:00 PM   #12
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Use a lift.
Counterfit is offline   Reply With Quote
Old 03-19-2008, 09:45 PM   #13
rkramer
Member#: 118209
2015 WRX Limitec
ramps... either are safe if used correctly, but with ramps there is less of a chance of squishing yourself. Once you are safely on the ramps the actual risk to yourself is almost non-existent. And getting it on the ramps isn't a risk to you, just the car if you don't know how to drive and overshoot.
rkramer is offline   Reply With Quote
Old 03-20-2008, 10:55 PM   #14
subySerb
Member#: 155411
that's why you disconnect the battery when working on something like that.
subySerb is offline   Reply With Quote
Old 03-21-2008, 01:14 AM   #15
DKup
Member#: 82492
2004 STi - Stage 2
WR Blue Pearl
Originally Posted by Doc Holiday View Post
^^ +1
^^ +2
DKup is offline   Reply With Quote
Old 03-21-2008, 01:50 AM   #16
cheyWRX
Member#: 147907
2007 WRX TR VF-43
...I don't like my ramps because I have to use 2x4s to drive on first because my car is too low for them.
cheyWRX is offline   Reply With Quote
Old 03-21-2008, 02:09 AM   #17
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
What are you trying to do? If the car is going to be up for a while with wheels coming off (i.e. - suspension install) then jackstands are the way to go.
If you are changing your oil or installing a rear sway bar then there's nothing wrong with ramps in my opinion.
impreza_GC8 is offline   Reply With Quote
Old 03-21-2008, 04:04 AM   #18
div
Member#: 131193
wrb
Agreed.
div is offline   Reply With Quote
Old 03-21-2008, 04:15 AM   #19
ejay
Member#: 170087
2008 5 door hatch
Spark Silver
both have a place in the garage but ive never had any problems with stands... ive heard stories of them falling and im cuirous what kind where they using? b/c i could probably shake the hell out of my car trying to knock them over and it wouldnt. also what kind of floor are they on, concrete... dirt...?
ejay is offline   Reply With Quote
Old 03-21-2008, 11:43 AM   #20
Tea cups
Member#: 103136
I'm paranoid - I use ramps, then place jack stands and leave the floor jack in place as backups if I am going to be underneath the car. Oh and wheel chocks too on the opposite end.
Tea cups is offline   Reply With Quote
Old 03-21-2008, 02:47 PM   #21
flstffxe
Member#: 155358
2008 Forester
Steel Silver
+1
There are many jobs where it is just quicker to drive up a "quality" set of ramps vs. jacking and jack stands. Ramps have their place in the shop.
Quality jacks and jack stands can get a vehicle higher then what most ramps can.
Plus jacks/stands are multi functional, they can be used in place of ramps. Ramps can't always be used in place of jacks/stands. Lets see you rotate wheels on a set of ramps .
Key thing to safety is to make sure what you are working with is of quality construction. There are cheap thin sheet metal ramps/jack stands that are spot welded together at the joints that are death traps waiting to catch some one. Always make sure the working load of the ramps/jack stands you are using is greater then the weight of the vehicle you are supporting.
flstffxe is offline   Reply With Quote
Old 03-30-2008, 12:31 PM   #22
DKup
Member#: 82492
2004 STi - Stage 2
WR Blue Pearl
In my opinion jacks stands are used incorrectly. Most people wont spend the time to put the entire car in the air and support the vehicle correctly. This is why you hear of folks having the car fall on them. If the jack stand is not level and not placed on a spot on the vehicle that is both structuraly sound as well as sitting level on the top of the jack stand, then yes it will be prone to tipping over. Wheel chocks will help, but really the entire car should be supported on 4 jack stands. I have (4) 4-ton jack stands that I use for both my STi and my 69 Ford Bronco. I also have a 4-ton hydralic floor jack that gets both my vehicles up in the air as EZ as pie. The few extra seconds it takes to get the opposite end of the vehicle supported is worth it since I know I won't get squished like a bug.
Old 03-30-2008, 01:24 PM   #23
08EJ25
Member#: 174022
2008 WRX
Lightning Red
I would agree with this.
08EJ25 is offline   Reply With Quote
Old 03-30-2008, 01:36 PM   #24
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
They are apples to oranges; different tools for different jobs. The stands are more versatile but require a jack and a little bit more thought. Ramps are definately more idiot proof and less useful if you want to do suspension work.
I recycled a set of steel ramps a couple of years ago. I clearly remember thinking, "I will never ever use these".
specialev is offline   Reply With Quote
Old 03-30-2008, 06:01 PM   #25
Bad-Larry
Member#: 160787
The captors have
hurt feelings.
...and another +whatever
Bad-Larry is offline   Reply With Quote
Ramps or Jack Stands subaru_steve General Community 64 09-21-2009 01:51 AM
What is safer in the snow/ice? A/T vs. M/T ChrisRT General Community 17 11-22-2007 10:23 AM
Swaybar install- ramps or jack stands? roybfr Brakes, Steering & Suspension 15 04-21-2005 12:24 PM
What is Santa Claus or Hanukkah Harry bringing everyone for the holidays? subpreza Texas Impreza Club Forum -- TXIC 2 12-18-2001 12:11 AM
What is correct: MAF or MAS? Imprezer General Forum Archive 6 10-11-2000 11:35 AM
