Old 03-21-2008, 04:32 PM   #1
NexRex
Member#: 154159
2015 CWS WRX
2011 SSM beast- no longer
Default 1 colder plugs?
OK Ive read the sticky on spark plugs but am looking for some end user feedback.. about to get my stageII setup installed and tuned ,Im alreadey due for new plugs (75k) wondering if I should stick with the stockers or go to the 1 step colder plugs?
Setup
Sti up
Invadia catless DP
Magnaflow exhaust
road tuned stageII( soon)
Nothings installed yet and going to probably do my plugs this weekend. stockers or step colder? can I run the step colder for a week or so without mods until I get everything in? any help appreciated
NexRex is offline   Reply With Quote
Old 03-21-2008, 04:49 PM   #2
Chino Bling
Member#: 129743
2009 335i
Jet Black
for those mods, stock plugs should be ok.
Chino Bling is offline   Reply With Quote
Old 03-21-2008, 05:34 PM   #3
mpggomd
Member#: 74167
2011 WRX Sedan WRB
TP Stage 2, w/cust tweaks
I've been running 1-step colder double platinum for the last 30k miles or so with 0 problems...ran them in 100 degree temps and 0 degree temps. The idle is alot smoother I think and the car runs fantastic...typical stage 2 but fully tuned 17.5 psi right now.
mpggomd is offline   Reply With Quote
Old 03-21-2008, 06:25 PM   #4
subarulz!
Member#: 99061
16 WRX
CWP
When I went stg 2 in my old car with one step colder plugs, the car didn't run very smooth sometimes. It randomly misfired. With stock plugs it was much better.
subarulz! is offline   Reply With Quote
Old 03-21-2008, 06:52 PM   #5
98EJ20
Member#: 163184
98 Swapped Impreza
Red
When I custom tuned my stage 2 map and starting running more boost and more agressive timing I switched to 1 range colder. Also gapped to .028 instead of .030. Car runs strong as hell! Ran a [email protected] today.
98EJ20 is offline   Reply With Quote
Old 03-21-2008, 07:41 PM   #6
iheartmysuby
Member#: 83638
bro i run 9s
iheartmysuby is offline   Reply With Quote
Old 03-21-2008, 07:59 PM   #7
Cards2323
Member#: 142868
2014 BRZ LIMITED
I running well over 300whp with stock, some people dont like to use colded plugs, ask your tuner what he likes to tune with
Cards2323 is offline   Reply With Quote
Old 03-21-2008, 08:08 PM   #8
Mr.ShenaniGaNs
Member#: 153498
2002 ImpreZa WRX
Championship BLUE!
I have NGK iridiums in my stock WRX. runs fine. i think you'll be ok with them.
Mr.ShenaniGaNs is offline   Reply With Quote
Old 03-21-2008, 09:40 PM   #9
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
There was a test done recently, the article is in Import Tuner magazine regarding the testing results of stock copper plugs, platinum plugs, and iridium plugs. To the skeptics, the iridium plugs actually showed quite an improvement over stock or platinum plugs, so I don't see how there can be any argument against them...other than the fine tips that can tend to snap off if you're not careful. You will be fine with the 1-step colder plugs, give it a shot but stick with NGK the Denso plugs are junk.
REXtard04 is offline   Reply With Quote
Old 03-21-2008, 09:48 PM   #10
Dobbs
Member#: 28291
2015 WRX
not really pertinent to the conversation but ok
Dobbs is offline   Reply With Quote
Old 03-22-2008, 12:54 PM   #11
02 wagon NY
Member#: 169866
02 Stage 2 Wagon
Wrb M.S.P.T tuned!!!!!!
get the stock ngk you will be fine
02 wagon NY is offline   Reply With Quote
Old 03-23-2008, 04:08 AM   #12
Homerisking
Member#: 79164
2005 WRX
tHe Silver one
Why are Denso's junk? Ran Denso's in my commuter car (Acura Integra) for nearly 80K and they still look and perform brand new.
Homerisking is offline   Reply With Quote
Old 03-23-2008, 09:02 AM   #13
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Sorry, just personal experience with them, that's all. I'm sure there are plenty of people that have not had any issues with Denso plugs, but I had to replace 4 sets of them in a matter of 2 months on the Nissan I had, the electrodes kept snapping off for no reason.
creating to much interference from colder plugs? JenisonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-07-2002 07:04 PM
Where to get colder plugs overnighted mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-25-2002 05:26 PM
Colder Plugs mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-23-2002 07:51 PM
colder plug? nathan power Normally Aspirated Powertrain 2 01-14-2001 01:41 AM
where to get colder plugs for my new turbo engine? kid22 Technical Forum Archive 9 09-14-2000 12:43 AM
