#1 |
Member#: 154159
TXIC
Vehicle:2011 SS Sedan 2011 OBP FXT |
OK Ive read the sticky on spark plugs but am looking for some end user feedback.. about to get my stageII setup installed and tuned ,Im alreadey due for new plugs (75k) wondering if I should stick with the stockers or go to the 1 step colder plugs?
Setup Sti up Invadia catless DP Magnaflow exhaust road tuned stageII( soon) Nothings installed yet and going to probably do my plugs this weekend. stockers or step colder? can I run the step colder for a week or so without mods until I get everything in? any help appreciated
#2 |
Member#: 129743
TXIC
Vehicle:2004 WRX WRB |
for those mods, stock plugs should be ok.
#3 |
Member#: 74167
NESIC
Vehicle:2011 WRX Sedan WRB Cobb Stage 2 OTS |
I've been running 1-step colder double platinum for the last 30k miles or so with 0 problems...ran them in 100 degree temps and 0 degree temps. The idle is alot smoother I think and the car runs fantastic...typical stage 2 but fully tuned 17.5 psi right now.
#4 |
Member#: 99061
NWIC
Vehicle:06 wrx wagon CGM |
When I went stg 2 in my old car with one step colder plugs, the car didn't run very smooth sometimes. It randomly misfired. With stock plugs it was much better.
#5 |
Member#: 163184
Tri-State
Vehicle:98 Swapped Impreza Red |
When I custom tuned my stage 2 map and starting running more boost and more agressive timing I switched to 1 range colder. Also gapped to .028 instead of .030. Car runs strong as hell! Ran a 13.1@103 today.
#6 |
Member#: 83638
TXIC
bro i run 9s
#7 |
Member#: 142868
Tri-State
Vehicle:03 TZ518Z EWG 2005 S4 |
I running well over 300whp with stock, some people dont like to use colded plugs, ask your tuner what he likes to tune with
#8 |
Member#: 153498
RMIC
Vehicle:2002 ImpreZa WRX Championship BLUE! |
I have NGK iridiums in my stock WRX. runs fine. i think you'll be ok with them.
#9 |
Member#: 112928
Tri-State
Vehicle:2004 WRX Sedan WR Blue |
There was a test done recently, the article is in Import Tuner magazine regarding the testing results of stock copper plugs, platinum plugs, and iridium plugs. To the skeptics, the iridium plugs actually showed quite an improvement over stock or platinum plugs, so I don't see how there can be any argument against them...other than the fine tips that can tend to snap off if you're not careful. You will be fine with the 1-step colder plugs, give it a shot but stick with NGK the Denso plugs are junk.
#10 |
Member#: 28291
RMIC
Vehicle:2005 STi Tuning Subarus in RMIC |
not really pertinent to the conversation but ok
#11 |
Member#: 169866
Tri-State
Vehicle:02 Stage 2 Wagon Wrb M.S.P.T tuned!!!!!! |
get the stock ngk you will be fine
#12 | |
Member#: 79164
NWIC
Vehicle:2005 WRX tHe Silver one |
#13 |
Member#: 112928
Tri-State
Sorry, just personal experience with them, that's all. I'm sure there are plenty of people that have not had any issues with Denso plugs, but I had to replace 4 sets of them in a matter of 2 months on the Nissan I had, the electrodes kept snapping off for no reason.
| Thread Tools | |
| Display Modes | |
| creating to much interference from colder plugs? | JenisonWRX | Factory 2.0L Turbo Powertrain | 17 | 06-07-2002 07:04 PM |
| Where to get colder plugs overnighted | mrtrex | Factory 2.0L Turbo Powertrain | 1 | 02-25-2002 05:26 PM |
| Colder Plugs | mrtrex | Factory 2.0L Turbo Powertrain | 3 | 02-23-2002 07:51 PM |
| colder plug? | nathan power | Normally Aspirated Powertrain | 2 | 01-14-2001 01:41 AM |
| where to get colder plugs for my new turbo engine? | kid22 | Technical Forum Archive | 9 | 09-14-2000 12:43 AM |
