Old 03-23-2008, 11:13 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default why is my steering still hard to turn?
ok I have done EVEYTHING I can think of to bleed air from my system in my 98 2.5rs...( I swapped out the PS pump with a JDM version)
when I have the front end jacked up the wheel turns effortlessly... (initialy I tried bleeding it with the wheels on the ground)
I take the PS reservoir cap off, turn the steering wheel slowly (probably 4 rpm) lock to lock about 3 times, then start the car and continue to turn the wheel lock to lock another 10 cycles. I let it sit for half a hour, and repeated...
the car is STILL hard to turn !!!
what the hell did am I doing wrong ???
If the belt was slipping I would hear it correct ?
there is a Connector on the JDM pump that my Impreza does not have, I just left it chillin... what is this for ??
the car worked PERFECTLY before I changed the pump
IllNastyImpreza is offline   Reply With Quote
Old 03-24-2008, 07:20 AM   #2
mikeythejew
Member#: 141672
I think your JDM pump needs to be wired to provide you power steering.
mikeythejew is offline   Reply With Quote
Old 03-24-2008, 08:57 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
How can I do that ??
switched 12v? and ground ?
its a simple 2 prong connector.
Old 03-24-2008, 10:46 AM   #4
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
I had a similar issue with mine after i installed my inlet.
I ended up having to crack the banjo bolt while turning the wheel and bleed it until i saw a steady flow and had someone re-tightened it.
Don't know why i had to do it. But, its the only thing that get all the air out of the PS line to the pump.
Wrx_Fan_0717 is offline   Reply With Quote
Old 03-24-2008, 11:57 AM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I will give it a try, thanks
Steering wheel hard to turn at idle - powers steering pump? thrdeye South East Region Forum 23 12-15-2008 09:07 AM
Argh, Why is touchup paint so hard to find? Lone Wolf 75 Mid Atlantic Impreza Club -- MAIC 13 11-08-2005 05:43 PM
I'm 27....why is my voice still changing? HamFist Off-Topic 20 11-17-2004 08:49 AM
Why is my face still swollen? obyone Off-Topic 25 04-05-2004 12:24 PM
Why is it so damn HARD to make an appointment at Irvine Subaru? wrexsta Southern California Impreza Club Forum -- SCIC 7 03-14-2003 07:47 PM
