Old 03-24-2008, 09:17 PM   #1
ejh25
Member#: 65267
Default Element Catch Can Install on my Built Motor
Hello all.
I have a Cusco catch can that doesn't really catch much at all.
I've decided to go with the Element Catch can to help alleviate my blow by woes.
Phil has patiently told me how to install the can two or three times now and I just haven't gotten around to it. Well I'm going to VIR this weekend and would like to have it in for the track.
I have the can mounted in the cruise control location, right beneath my strut bar. I don't have any lines hooked up.
Here are the applicable parts of my setup for a discussion:
V8 Spec C heads that have twin breather ports on each valve cover.
EJ257 case
02 WRX intake manifold.
(1) If I have it right, Phil suggests that the two forward (driver and passenger)valve cover breathers are teed to the -10AN on the can.
(2) Then the crankcase breather, which (to my understanding) is the breather hose coming off the block about half way between the center line of the block and the passenger valve cover, is run to the -12AN on the can. Do I need to tee this in with any other line?
(3) Then the two rearward valve cover breathers are connected together and teed to the breather right in the dead center of the block underneath the throttle body. These hoses aren't going to the can in any way right?
Please provide me any tips you can think of.
Thanks,
Eric
ejh25 is offline   Reply With Quote
Old 03-24-2008, 09:27 PM   #2
ejh25
Member#: 65267
These pics weren't taken specifically for this, but they should help the discussion for now:
Old 03-24-2008, 09:30 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
That all sounds right. Do what Phil says.
And regarding #3, that's how it is from the factory. Probably to equalize pressure between the heads and crankcase, as others have mentioned.
jays05 is offline   Reply With Quote
Old 03-24-2008, 09:36 PM   #4
ejh25
Member#: 65267
Another couple of points.
The rearward valve cover ports are capped off along with the breather that sits atop the block right underneath the throttle body.
The hose that goes from the Cusco can to the crankcase breather will be eliminated. That goes to a question, is that actually running to the crankcase breather?
Thanks,
Eric
Old 03-24-2008, 09:38 PM   #5
ejh25
Member#: 65267
Cool. That makes sense to me.
Old 03-25-2008, 12:00 PM   #6
greysave
Member#: 62395
2005 STI
That spot also may be a little low for the for the element competition can. I placed mine where the wiper fluid bottle used to be. I will post pictures when I get home from work.
greysave is offline   Reply With Quote
Old 03-25-2008, 12:52 PM   #7
ejh25
Member#: 65267
Interesting point. I actually thought about mounting it by the washer bottle, but I wanted to retain that reservoir. I was able to mount the top of the Element can almost flush with my strut tower bar. I think it should work.
- Eric
Old 03-25-2008, 12:53 PM   #8
ejh25
Member#: 65267
I like pictures
If you have a close up of your -12AN routing that would be appreciated.
Thanks,
Eric
Old 03-25-2008, 01:13 PM   #9
greysave
Member#: 62395
2005 STI
No problem it will be around 8 or so. I get home pretty late.
Old 03-27-2008, 11:16 AM   #10
greysave
Member#: 62395
2005 STI
Default catch can pics
Pic of the whole engine from far.
Picture of the head breather port from far.
Picture of the head breather port close.
Picture of the crank case breather port close.
It was dark out and there is a lot going on with my motor. If you need more pictures just let me know.
Old 03-27-2008, 11:45 AM   #11
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Yes you have it correct. Here is a little better picture to get you started.
Definitely get it on for the track day as it will really cut back on your oil loss/consumption. I can also look over what you did at VIR.
Thanks,
Phil
www.elementtuning.com
Old 03-27-2008, 11:48 AM   #12
Element Tuning
Member#: 54918
673 WHP Element
Thanks,
Eric
For the Element Competition Catch Can in your application:
Block off the PCV fitting going into the throttle body.
The passenger side crankcase vent will go directly to the -12 fitting on the Element Catch Can
The center crankcase breather will be connected to the two rear valve cover breathers. These two ports on the valve covers are baffled from the factory to help separate the oil as our can will do for the passenger side crankcase vent.
Thanks,
Phil
Old 06-20-2015, 09:32 PM   #13
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
I have a question. I have 2002 WRX heads with single valve cover port on each head. I run a hybrid set up. I capped off the 2.5L port under the throttle body, I have valve covers T'd going to the catchcan. For the PCV, It is still in tact, I just have a hose going from the T (where it was attached to the factory turbo inlet) going to the catch can as well. Is this right or do I have the PCV wrong? I run a single 4 inch intake to my turbo with no ports.
emsmap is offline   Reply With Quote
Old 06-22-2015, 09:12 AM   #14
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
bump for an answer
Old 06-23-2015, 09:20 AM   #15
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
bumpy
Old 06-24-2015, 10:30 AM   #16
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
answer?
Old 06-25-2015, 12:10 PM   #17
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
answer?
my take on a catch can install awdturbo04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-21-2009 02:01 PM
STI TMIC, STI Uppipe, Element Catch Can SplatZ400 Engine/Power/Exhaust 9 05-02-2008 02:27 PM
Please Help on my Catch Can Install ColesSTi Newbies & FAQs 7 10-27-2006 02:12 PM
Ebay catch can installed on 06 STI 2006STI Member's Car Gallery 28 08-27-2006 02:30 AM
Oil Catch Can Install on 04 STi SupraScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-21-2004 03:52 AM
