Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-18-2008, 03:45 PM   #1
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Default How-To: DIY aftermarket Downpipe CEL fix
This is a do it yourself Check Engine Light (a.k.a. CEL) fix for the WRX for use after installing an aftermarket downpipe (a.k.a. DP) with either a high flow catalytic converter or no catalytic converter (a.k.a. Cat) at all and you are getting a cat efficiency code.
If you already know how to do this, or you have seen similar threads, then that's awesome, just don't reply to my thread saying, "There is already info on this out there" or "you just need to do a search and figure it out". I did both of these and figured it out myself. I just don't think that if someone wants to do this exact same mod, they have to search and piece together information from different threads. This is a specific how-to article for this exact mod only... the information has been pre-pieced together for you.
Ok... the idea behind this fix is to basically confuse... well, actually, not confuse... trick is a better word... trick your car. By pulling the O2 sensor out of the direct flow of exhaust and isolating it inside its own little space confuses the car into thinking that the air coming through your new catted or catless DP is clean.
This fix in this thread was performed on a Catted Helix Downpipe on my 2005 WRX sedan.
Ok... so first of all, this is what you will need for this fix.
1. Two 18mm spark plug non-foulers (a.k.a. anti-foulers). I bought the "HELP!" brand (part #42002) at my local pepboys, however they can be found at many auto parts store out there. Cost: $4.50
2. A 1/2 inch drill bit. Cost: $12.50
3. Access to a power drill or drill press
4. A vise... a table vise, bench vise, workshop vise, whatever you want to call it. You just need one.
Alright... here we go.
Step 1. Raise the front of your car up on jacks. Remember: When putting your car up on jacks to always be on a level surface and firmly set your parking brake.
Step 2. If the sensor hole in your exhaust is already unplugged, great! If it's not, Unscrew the plug from the rear sensor opening in the rear section of your new downpipe as seen below. If you didn't remove the oxygen sensor from your car during your DP installation then cut the zip ties that are holding the cable down and unplug it. Once it has been removed from the car you can wipe off all the old exhast dust from the sensor with a dry towel. Set it aside for now.
Step 3. Take one of your spark plug non foulers and drill a 1/2 inch hole through it to make clearance for the O2 sensor to fit inside it. This can be done with a power drill and a vise... the metal is relatively soft. See before and after below:
Step 4. What you are going to do now is screw the oxygen sensor in the non fouler you just drilled and then into the non fouler that you have not drilled... like so:
Step 5. Put this setup into a vise and tighten down both connections with a 22mm wrench.
Step 6. Screw this whole setup into the rear hole of your downpipe. Screw it in there pretty tight as you don't want any exhaust leaks.
Step 7. Plug it back into the black female O2 sensor cable found on the drivers side.
Step 8. If your wrx already threw a CEL at you, then you need to reset your ecu. To do this all you need to do is grab a 10mm socket or wrench and disconnect the negative end of your battery. Depress the brake for roughly 5-10 seconds (i have never needed to depress the brake any longer than this in order to drain the leftover charge flowing through my car) and then reconnect the battery.
Enjoy your clean instrument panel!
I'm not a professional auto mechanic, so If I have misinterpreted anything or explained anything incorrectly, then please PM me with any contradicting references that you have come across and I'll fix it pronto.
I have always used forums for "how-to" articles and I have never made one, so I felt it was time to start giving back! I hope this is a good start.
WorldRallyX05 is offline   Reply With Quote
Old 03-18-2008, 04:13 PM   #2
hella_sti
Member#: 139289
2003 WRX Wagon
nice write up, but didn't someone already have a few pages on this mod?
hella_sti is offline   Reply With Quote
Old 03-18-2008, 04:30 PM   #3
Feign
Member#: 68604
06 STi
Feign is offline   Reply With Quote
Old 03-18-2008, 04:36 PM   #4
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
Nice. Even though there is a thread already, this is easier for a noob to follow; instead of sifting through all those pages
dave_88 is offline   Reply With Quote
Old 03-18-2008, 08:13 PM   #5
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Originally Posted by Feign View Post
Yeah, i saw that, but this fix is a lot better for a few reasons:
1. It is way easier.
2. It fits better.
3. It looks a lot cleaner.
4. You don't need to weld anything.
5. The parts are cheaper.
If you have a welder (like Macabre, the person who posted the referenced link above) then i guess you could do it that way, but i have access to a mig welder, and I decided to do it this way because of the above reasons. I dunno ... a lot of these DIYs are subjective, but the point is... that this one works and its cheap.
Old 03-19-2008, 02:16 AM   #6
jack klompus
Member#: 152885
2014 Malibu LTZ
good write up. Ive been doing this mod exactly as you write it for 3 cars now with no CEL's.
jack klompus is offline   Reply With Quote
Old 03-19-2008, 09:45 AM   #7
Feign
Member#: 68604
06 STi
2. It fits better.
Yeah, but the anti-foulers are mentioned in there.
I'm not going to knock this thread, but I found out how to do this with a little bit of searching (back when the search sucked balls, mind you) and a little bit of brain matter to piece information together.
Old 03-19-2008, 01:21 PM   #8
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Unhappy i don't get it
How do you think i figured it out? Just the same way you said you figured it out; "with a little bit of searching and a little bit of brain matter" I'm helping out the people who constantly search for this without finding one conclusive thread. I thought i would make it easier for some people so that they wouldn't have to search all over the place and piece together threads like you said, just to figure out something as simple as this.
I don't understand what is with people... I took time out of my day to go back and take pictures of what i had done earlier that day to help people out there who had the same problem i did, and I keep getting people who are saying i didn't need to post it. Well, there are thousands and thousands of threads that aren't of use to EVERYONE out there, but there are definitely some people out there who really need them, so if this thread is of no need to you as an individual, then don't say anything unless its a complement, and move on with your day. I can guarantee you that at one point or another, sombody (hopefully more than just a somebody) will find this thread and use it just the way it was designed to be used. As a HOW-TO, not a target for criticism.
If you already know HOW TO do this, then you have no business reading it, or wasting your time commenting on it.
Sorry if this thread bothers anyone, but i made it because i couldn't find one like this when i wanted to do this same thing to my car, so i did it to help out those who are in the same situation. So, if you're not in said situation, and you're not leaving a complement (BTW, thanks for the complements from everone!) then i don't know why you're leaving a comment.
SO, that having been said, lets try and save the criticism for things a little more important than how-to threads that you already understand and have figured out for yourself.
The only criticism that i want, and that i have previously stated in the original post, is if i have misinterpreted anything or explained anything incorrectly. I know that there are other threads out there that contain similar information, that is how i figured it out for myself, but if one person pieces together all the information regarding one issue and puts it all together in one thread, that will save a lot of people a lot of time in the future.
Old 03-19-2008, 03:04 PM   #9
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Thanks!!! That is my thinking exactly.
Thank you! Nice... it's good to hear its a reliable fix.
Old 03-20-2008, 01:10 AM   #10
Feign
Member#: 68604
06 STi
I thought that was what the search function was for?
Most everyone that runs a catless downpipe is intelligent enough to discover at least one of the two fixes for this particular CEL.
Yes, thank you. I said it was a good thread, but you should not expect any nut-fluffing.
Old 03-20-2008, 03:16 AM   #11
WorldRallyX05
Member#: 173029
2005 WRX Sedan
I never expected that, nor did i say that i expected it.
Thanks for saying it was a good thread, but it doesn't mean much when you follow it up right away with "... BUT, I found out how to do this with a little bit of searching". So what... a ton of people just like you found out how to do it with a little bit of searching, including me... I don't really care that you found it with a little searching. I obviously didn't make the thread for people like you who already know how to do this, so leave it alone. You're commenting on a thread that obviously doesn't concern you sine you already know how to do it, so just drop it. I don't understand why a comment like "I found out how to do this with a little bit of searching (back when the search sucked balls, mind you) and a little bit of brain matter to piece information together" is even warranted. Are you trying to say that my thread is of no use to this community? because i assure you, it will be used. I'm not the only person who has recently done this to his/her car.
If you really feel that this thread doesn't belong... then take it up with a moderator and quit scrutinizing my thread.
Old 03-21-2008, 12:27 AM   #12
Ioku
Member#: 164864
95 Impreza coupe
Nice write up but do you know if this would work for an N/A car to, I was thinking of gutting my cats but didn't want to get any cels so if this could work for N/A's too that would be great.
Ioku is offline   Reply With Quote
Old 03-22-2008, 10:25 PM   #13
Dex
Member#: 163775
2014 Ford Fiester ST
Murica Red
Great write up man! Much easier to follow that those other ones.
Those of you knocking it.... Shuuuuuut uuuuuup. It's simple and to the point.
Dex is offline   Reply With Quote
Old 03-22-2008, 10:54 PM   #14
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Smile
Thanks man, thats exactly what i was trying to do!... i appreciate the complement.
Old 03-23-2008, 06:15 AM   #15
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Man, don't sweat it,people criticize everything You did a great job plus it has pictures and everybody loves that when they are trying to do something themselves
kike_ej20 is offline   Reply With Quote
Old 04-02-2008, 02:29 PM   #16
07SPTWRX
Member#: 149947
2007 SPT WRX
Obsidian Black Pearl
nice - i did the same thing on my civic when i went to a cat-less system.
the only thing i think is missing, is what size non-fouler to use. I know from when i did my civic there were 3 or 4 diff sizes.
other than that - good job
07SPTWRX is offline   Reply With Quote
Old 04-02-2008, 03:54 PM   #17
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Whoops.... sorry about that, they're 18mm, I'll go add that in. Thanks!
Old 04-14-2008, 03:09 AM   #18
captureandrelease
Member#: 176014
2003 wrx wagon
Rally blue.
Thank you very much, this is very helpful. Feign is bored and is a douche.
captureandrelease is offline   Reply With Quote
Old 04-14-2008, 11:42 AM   #19
SC2000
Member#: 162421
This thread actually helped me...I wasn't sure if I wanted to go with a catless downpipe b/c of the CEL, but now it's clear that's the direction I'm going to go. Plus, I don't have a clue on how to weld.
Thanks for the write-up.
SC2000 is offline   Reply With Quote
Old 04-22-2008, 12:53 PM   #20
BriGuy
Member#: 107189
2006 Subaru STI WRB
eBay: rainbowarior
I did this fix, but it didn't really work for me. After about 3 days of driving, my check engine light came on again. When I look up the code in my accessport, it comes up as no code found. This has always been ever since I went catless. I have a turbo XS downpipe and Perrin catback on an 06 sti... any suggestions????
BriGuy is offline   Reply With Quote
Old 04-23-2008, 12:33 AM   #21
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Great write up. We need more write up with pictures.
Old 04-23-2008, 05:53 PM   #22
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Thank you to all!!!
Old 04-25-2008, 12:08 AM   #23
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Nice write up. Thanks.
flimflamman is offline   Reply With Quote
Old 04-30-2008, 02:01 AM   #24
unclben7
Member#: 43115
02 wrx
I wish I would have known about that before I bought the cel fix online which is exactly what you did, but it included the resistor as well...I would have saved a bunch of money. Good job!
unclben7 is offline   Reply With Quote
Old 04-30-2008, 02:23 PM   #25
Jus Blaze
Member#: 129428
2002 Wrx
Do you think that I would be able to pass NY inspections if I did this to all my sensors? I have a complete catless turboback.
Jus Blaze is offline   Reply With Quote
How To: DIY TGV Deletes Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 125 01-18-2016 09:00 AM
How to: DIY 3.3Ohm resistors jas0nn Interior & Exterior Modification 20 08-07-2009 12:26 PM
How To: DIY Radiator Cooling Panel StretchSTI Interior & Exterior Modification 28 10-29-2007 05:06 PM
How To: DIY Angled Licence Plate StretchSTI Interior & Exterior Modification 29 10-18-2007 05:41 PM
Scoobysport downpipe CEL fix - status? rwroth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-27-2001 12:32 PM
