Notices
Old 04-13-2008, 02:15 PM   #1
OnlyInAJeep24
Member#: 112926
2008 Slvr WRX 4 Door
RIP 06 OBP TR
Default Check Engine Light Question
Ok, so I was bored and I took apart my intake, and put it back together,, Stock 2008 Subaru WRX 4 door....
I put it back together exact,,, now my Check engine light is flashing with my traction control (abs?) light is off,, and my cruise control light is flashing.. any ideas? Please. Whats wrong? Safe to drive it still? How do I fix it?
Thanks.
OnlyInAJeep24 is offline   Reply With Quote
Old 04-13-2008, 02:33 PM   #2
mikeythejew
Member#: 141672
Why did you do that for?
mikeythejew is offline   Reply With Quote
Old 04-13-2008, 03:14 PM   #3
polish_lukasz
Member#: 160452
2007 Impreza WRX STI
Obsidian Black Pearl
Thanks.
go to any AUTOZONE store give them deposit and rent OBDII auto scanner, read the code, reset the code, check IAT connection, and should be good, I had same problem with my 07STI before, but i removed stock air filter and i install Cobb Intake but i didn't connect good enough the IAT and it showed me a cel with cruse control blinking. I'm talking about this http://i50.photobucket.com/albums/f3...4/100_1763.jpg it not my pics, i just found online, so yup get the OBDII scanner and check the code, you don't have to buy it (i think it's 200$) maybe less, but you can rent it for deposit only and they will give you money back
hopefully this will help you
polish_lukasz is offline   Reply With Quote
Old 04-14-2008, 12:15 AM   #4
OnlyInAJeep24
Member#: 112926
RIP 06 OBP TR
Thanks anyways,, but i figured it out,,, All I did was double check to make sure I put it back on right,, which I did,, And I unplugged the neg on the battery for 5 min and plugged it back on,, started her up, and all was well.
And I did it because I cant afford any mods yet, payments are HUGE, and I like to get to know my car so I take things apart and put them back together so when I can afford mods I know what Im doing,, Makes it easier for me so I get my mods in quicker so I can enjoy them faster... Im impatient. lol
Old 04-14-2008, 12:29 AM   #5
polish_lukasz
Member#: 160452
that's kinda different, but if you say so, just to make sure you put EVERYTHING back like it was before you touch it!!!!
Old 04-14-2008, 10:10 AM   #6
OnlyInAJeep24
Member#: 112926
RIP 06 OBP TR
lol,, i like to put them back together with parts left out... weight reduction
(j/k)
Old 04-14-2008, 10:33 AM   #7
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
taking things apart and putting them back together is a great way to learn about how things work and how to fix them. used to do it with lawn mowers and other small things. I don't suggest doing it with your daily driver, but hey why not
Doc Holiday is offline   Reply With Quote
Old 04-14-2008, 01:38 PM   #8
OnlyInAJeep24
Member#: 112926
RIP 06 OBP TR
Thats how I got to learn my KTM 300 and XR 250 inside and out.. I like knowing how to do it, plus, I find it fun.
Old 12-08-2008, 11:33 PM   #9
08WRXNOBUMPER
Member#: 193948
Default So I just did the same thing hahaha
Yeah I just forgot to replug the senser back in and then when I remembered I had the car running and it didn't like that at all... yeah the car shut off and when I restarted it the check engine light came on and the cruise control is flashing and the traction is on.. So if I pull the negitive off the batt. for like 5min then I should just turn it all off then?
08WRXNOBUMPER is offline   Reply With Quote
Old 12-09-2008, 12:16 PM   #10
rick-l
Member#: 33868
2003 wrx
srp
The light should turn itself off after three drive cycles if you really did correct the problem
rick-l is offline   Reply With Quote
Old 12-10-2008, 12:06 AM   #11
08WRXNOBUMPER
Member#: 193948
Thanks it worked! Next time I will have to slow my ADD down a lil bit hahaha
check engine light question - 05 STi STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-16-2006 10:25 PM
2005 STi check engine light question STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-27-2006 07:40 PM
Check engine light question.... just one blunt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2004 08:04 PM
[B]Check Engine Light question regarding uppipe/downpipe[/B] Moshpit552 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2004 02:36 AM
Check engine Light Question P1443 speedrkj Tri-State Area Forum 8 02-26-2003 07:39 PM
