Old 04-17-2008, 09:52 PM   #1
rxer311
Member#: 107099
'07 STI
Default Low profile ramps
Anybody have a suggestion for ramps for my STI? I looked at the rhino ramps and my car just cleared them. Since I am putting on some RCE yellow springs I doubt I would clear them after that. Anybody know of a reasonably priced low profile ramp for our cars? even after they are lowered?
rxer311 is offline   Reply With Quote
Old 04-17-2008, 09:57 PM   #2
tacomaprime
Member#: 70572
2005 Tacoma
Not sure of a brand, but I am borrowing a set next weekend to do my swaybars and endlinks, and the guy I am borrowing them from said they came with extensions for cars that are lowered.
tacomaprime is offline   Reply With Quote
Old 04-17-2008, 09:57 PM   #3
07wrxwag
Member#: 151967
2007 wrx wagon
UGM
when i had my vw that was real low, what i did was cut 2x4's and placed them infront of the rhino ramps and it allowed me to get on them and off. Not sure if that would work with the sti since in my mind the vw was a more shorter front than the wrx/sti's have
07wrxwag is offline   Reply With Quote
Old 04-17-2008, 10:02 PM   #4
dillsky
Member#: 109485
06 Blue TR
FP18g'd
I have a set of low profile ramps i think i got from Pep Boys. They worked good till i put the front lip on. Thankfully i bought the replica lip from Mach V so it flexed a little without doing any damage. Im getting ready to install a set of GF210 lowering springs.....so i guess ill be looking for some "lower profile" ramps now
dillsky is offline   Reply With Quote
Old 04-17-2008, 10:12 PM   #5
SC2000
Member#: 162421
These aren't cheap, but will help getting super low cars off the ground to fit a jack under or whatever...
They're called Tomioka Super Slope Ramps.
$68 I believe is the going price for them...
SC2000 is offline   Reply With Quote
Old 04-17-2008, 10:21 PM   #6
dillsky
Member#: 109485
06 Blue TR
FP18g'd
Only if they raised the car up a little more....just enough to get underneathe to do an oil change, they would be perfect
Old 04-17-2008, 10:24 PM   #7
GDB FAN
Member#: 105814
You can buy pretty much the same thing from Autozone, Pep Boys, etc. for 30 bucks.
GDB FAN is offline   Reply With Quote
Old 04-17-2008, 10:34 PM   #8
SC2000
Member#: 162421
I've got Rhino ramps, and these are much lower than the Rhino ramps. I don't have a set, but I've seen pics of people who have used them. It's mainly for cars that are dropped super low and need some space to get a jack under them.
Old 04-17-2008, 10:40 PM   #9
GDB FAN
Member#: 105814
True
I couldn't tell the size from the photo. Local guy here has his wagon on Prodrive springs (IIRC) and his cleared without issue.
Old 04-17-2008, 10:57 PM   #10
leecea
Member#: 37359
You can extend this idea out further from the ramp buy just getting wider planks. Cut a couple of 24" sections of 2x12 and I'm sure you'll be OK unless you're super low. Even then you could stack a shorter section of 2x12 on top and glue or nail them together.
If you have trouble with the ramp moving, rig up something that hooks the ramp and wood together when in use.
leecea is offline   Reply With Quote
Old 04-17-2008, 11:11 PM   #11
Kai
Member#: 364
2013 STi
Kai is offline   Reply With Quote
Old 04-18-2008, 04:15 PM   #12
bsikora
Member#: 125573
2006 2.5i
ProTune by Sean S.
i have just the standard metal ramps and use a piece of wood on both saids as extenders. Works just fine and cost me $0. oh i forgot to say I am on S-techs.
Blake
bsikora is offline   Reply With Quote
Old 05-03-2008, 09:17 PM   #13
crystalgraysubydude
Member#: 150792
2007 07 OBP STI
Obsidian Black Pearl
Default These Might Work?
http://www.amazon.com/Low-Profile-Oi...=rsl_mainw_dpl
The only thing is they are unavailable at this time, but you could order a set I believe.
crystalgraysubydude is offline   Reply With Quote
Old 05-12-2008, 10:40 AM   #14
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
The Tomioka Low Down Slopes are pretty nice and light weight, just kind of expensive.
NRG makes the "slope box" and it looks a little bit higher, and it goes for around $45. The only thing is I can't tell if its sold singly or as a pair!
Another thing that concerns me about the NRG is that its completely flat..so if you're not careful, you could drive right off the edge. At least the Tomioka ones have a dip for the wheel to sit.
DeusExMachina is offline   Reply With Quote
Old 05-12-2008, 10:42 AM   #15
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I looked into getting low-profile ramps at one point, but couldn't justify the cost since I winded just using two pieces of wood. I drive up on them and I have enough room to get my jack underneath
Hank3 is offline   Reply With Quote
Old 05-12-2008, 11:09 AM   #16
Baay
Member#: 139645
07 WRX
UGM
I have a set of Tomiokas and they lift my car enough to do and oilchange, my car is on RCE yellows and konis and im not a small guy, but i can fit under enough to undoo all the bits and do and oilchange. tho i still recommend jacking the back up a bit to level out the car and get all the oil out or you will have some in the rear of the pan.
Baay is offline   Reply With Quote
Old 05-12-2008, 11:20 AM   #17
sigurd
Member#: 128721
2002 impreza WRX
psm
lol screw $60 bucks its called a ****ing 2x4
sigurd is offline   Reply With Quote
Old 05-12-2008, 12:35 PM   #18
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
My car is an '06 WRX lowered on JDM pinks... I bought those griots ramps with extensions (super nice btw) but I still just rub my front bumper on them. I tape a piece of paper towel to the bottom of my bumper on each side that rubs to protect the paint and use them.
jay25RS is offline   Reply With Quote
Old 05-12-2008, 05:56 PM   #19
SC2000
Member#: 162421
2x10's stacked on top of each other. $9 at Lowes - DONE!
Old 02-24-2010, 04:47 PM   #20
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
back from the dead.. I love my tomioka ramps.. They been out of stock for a long time thou.
Kenji815 is offline   Reply With Quote
Old 09-26-2011, 09:56 PM   #21
hillsboro
Member#: 84823
14 Evo
00 Outback
Back from the dead again. I have RCE yellows and a front lip and can't find a ramp my car will drive up on. For race ramps if you stick a yard stick out from under your tire and measure where it contacts the front of you car it tells you if you car fits. The lowest ramps they have require 6.5 inches of clearance, I have 4.5. The race ramps are the lowest I have found. Blitz ramps don't work either.
I am aware of the 2x12 ramps. Don't need advice on how to do that. Im also not looking for advice on jacks or jack stands. I
Any body seen any other ramp options?
hillsboro is offline   Reply With Quote
Old 09-27-2011, 08:15 PM   #22
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Why are you against the 2x10 ramps?
Old 09-27-2011, 08:38 PM   #23
Erik
Member#: 168774
http://www.raceramps.com/
Edit: Didn't notice the guy that bumped it was looking for something other than those
Erik is offline   Reply With Quote
Old 09-29-2011, 12:11 AM   #24
hillsboro
Member#: 84823
14 Evo
00 Outback
Was hoping for something a little easier to store.
Race Ramps would be perfect if the approach was lower.
eBay's version of Takata Low Profile Ramps Hank3 Service & Maintenance 5 10-10-2006 09:25 AM
FS: NGR low profile ramps jsalicru Private 'For Sale' Classifieds 3 04-08-2005 11:28 AM
Does anyone make a low profile ramp? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-29-2004 09:51 AM
