Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 04-22-2008, 02:19 AM   #1
francoej
Member#: 82447
05 STi
Default Aftermarket tweeters in stock location?
Has anyone put aftermarket tweeters in the stock location on an '05 STi? Finding woofers seems to be no problem, but I haven't seen anything on the tweeters. I'd like to upgrade the speakers, but want to keep the stock look.
francoej is offline   Reply With Quote
Old 04-22-2008, 02:26 AM   #2
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
since the tweeters are behind the door panel, u shouldnt have a problem with the "stock look". u cant even see them.
get components, that will solve ur problem exactly. unless u are not running an amp to power them.
what is ur situation. we have to knwo details on your information before we can really answer what u want
lowranger is offline   Reply With Quote
Old 04-22-2008, 02:51 AM   #3
sti xtc
Member#: 131929
04 sti
I put aftermarket tweeters there. I just used that 3m double sided foam to mount them. speakers were JL. Worked great
sti xtc is offline   Reply With Quote
Old 04-22-2008, 03:19 AM   #4
francoej
Member#: 82447
05 STi
Fair enough. I've got the stock HU and will purchase a line-out converter to run into a Performance Teknique amp (50x4 @ 4ohms, 65x4 @ 2ohms). The amp is severl years old, but paid for. My car is loud (stage 2 w/various upgraded suspension bushings) and I'd like more sound w/o distortion. I'm no audio expert, but it seems that given similar specs, the component system is preferred over the coax. I've also read that tweeter placement (direction) is important, and the coax would be aiming it at the ankles. My concern is whether aftermarket tweeters would fit in the stock location, behind the doorcard. All the pictures I've seen seem to have them mounted to the doorcard.
Old 04-22-2008, 03:51 AM   #5
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
i put infinity reference tweters in the stock location on my 04' wrx
skingfreak is offline   Reply With Quote
Old 04-22-2008, 01:35 PM   #6
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Tweeter install in the factory location is simple. I've got mine screwed in, but often use hot-glue with great results (Can I just say that I love black hot glue). I would keep the gain on the high-low converters pretty low to help keep down engine noise, especially with that amp. Good luck
Audiosavvy is offline   Reply With Quote
Old 04-22-2008, 04:54 PM   #7
Stilo
Member#: 139806
2007 PizzaHut STI-LE
UG
The stock ones are welded to a bracket, thats why i think most people do it like in this pic. You just cut a hole and install the tweet. No bracket needed.
Stilo is offline   Reply With Quote
Old 04-22-2008, 05:03 PM   #8
misterjoshua
Member#: 140599
'05 WRX Stg2
No need to cut any holes. 3M tape or hot glue works fine.
misterjoshua is offline   Reply With Quote
Old 04-22-2008, 05:11 PM   #9
Audiosavvy
Member#: 150794
Qcab dakota 4x4
they are NOT welded, and if you don't use that bracket, you won't get nearly the same sound, unless you fab one up that brings the face of the tweeter up closer to the grill, and at an angle. If it shoots straight out, the sound has to turn to even get OUT of the grill, and you will lose a lot
Old 04-22-2008, 05:44 PM   #10
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
i just super glue hahah
Old 04-22-2008, 05:51 PM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Yep, and unless you're 93 with arthritis, you should be able to twist it right off
Old 04-23-2008, 09:46 AM   #12
03RexWgn
Member#: 85929
07 Stage 2 UGM STI
I've got Focals in the front door and the tweeters fit perfectly- all with the OEM look.
03RexWgn is offline   Reply With Quote
Old 04-23-2008, 09:48 AM   #13
snorekl
Member#: 78139
2005 Saab 9-2X
Red
I just found another nit to pick with this installation - not trying to be a jerk though. Why spend the $200 on the pods and put the tweeter in the stock location???
snorekl is offline   Reply With Quote
Old 04-23-2008, 05:38 PM   #14
neushane
Member#: 61105
2009 Legacy Spec.B
i used jb weld to secure the aftermarket tweeter to the stock bracket. Worked perfect once the jb weld set.
neushane is offline   Reply With Quote
Old 04-23-2008, 06:56 PM   #15
It Hertz
Member#: 152898
2007 Impreza 2.5I
UGM
What happens when summer comes and the hot glue melts?
It Hertz is offline   Reply With Quote
Old 04-23-2008, 07:07 PM   #16
Audiosavvy
Member#: 150794
Qcab dakota 4x4
never happened in my experience, and it gets 115 here in the summer
Aftermarket Tweeters in Factory Locations? elbles Car Audio, Video & Security 36 10-06-2009 03:45 PM
t3 in stock location with stock parts? legacydreamz Normally Aspirated with bolt-on Forced Induction Powertrain 0 08-11-2009 01:21 AM
Tweeters in stock location? Mishmosh Car Audio, Video & Security 3 02-28-2004 02:26 PM
How to install Focal tweeters in stock location? newsman Car Audio, Video & Security 3 07-02-2003 11:28 AM
What speakers will fit in stock locations in WRX? boo Car Audio, Video & Security 0 04-17-2001 09:59 PM
