Old 01-20-2008, 05:23 PM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default Brakes/Steering/Suspension Installation/Walkthrough Thread (inc. Koni)
After seeing williayayaytya's new writeups I figure we should have a place to list all of them. I am not going to attempt to get all of them - just starting the thread so folks can add stuff.
This thread should not, repeat NOT become a place where everyone asks questions about how to install things - it is purely to compile links to the actual threads themselves.
Here goes...
Old 01-20-2008, 05:23 PM   #2
Butt Dyno
Member#: 17301
is the "dark side"
Universal: torque spec/wrench size for suspension/brakes/drivetrain
http://www.clubwrx.net/forums/showthread.php?t=80548
Suspension installations:
Camber bolts
Camber bolt install tips (sphini)
http://forums.nasioc.com/forums/show...2#post21166732
Camber bolt FAQ / tutorial (williaty)
http://forums.nasioc.com/forums/show....php?t=1590221
Springs/struts
Official Koni Insert installation thread (Jard):
http://forums.nasioc.com/forums/show....php?t=1219607
Spring installation on an STi (Rev):
http://www.iwsti.com/forums/how-inst...-pictures.html
How To: complete idiot's guide to spring installation (austinpike)
http://www.iwsti.com/forums/how-inst...tallation.html
Assembling front suspension... is this correct? (pic inside) (Hokie-wrx wagon)
http://forums.nasioc.com/forums/show...php?p=38303706
HOWTO: Saggy Butt Shim Install Tutorial (williaty)
http://forums.nasioc.com/forums/show....php?t=1471756
Paranoid Fabrications saggy butt spacer How To thread (impreza_GC8)
http://forums.nasioc.com/forums/show...3#post22870983
Koni Install on GR (2008+) Impreza (phenryiv1)
http://forums.nasioc.com/forums/show....php?t=2322600
Suspension link/arm stuff
Lateral link bushing install (williaty)
http://forums.nasioc.com/forums/show....php?t=1380974
Rear of trailing link bushing install tutorial (williaty):
http://forums.nasioc.com/forums/show....php?t=1429112
SuperPro trailing arm rear bushing install (Paranoid Fabrications):
http://forums.nasioc.com/forums/show....php?t=1293637
Trailing link install tutorial (williaty):
http://forums.nasioc.com/forums/show....php?t=1429052
control arm install (Big Sky WRX)
http://www.clubwrx.net/forums/showthread.php?t=73983
Swaybars/mounts/endlinks
A tip for installing 04 Sway mounts (SR-71WRX - applies to both OEM 04+ swaybar brackets and aftermarket ones like Cobb):
http://forums.nasioc.com/forums/showthread.php?t=755611
02/03 WRX rear sway mount upgrade (Big Sky WRX)
http://www.clubwrx.net/forums/showthread.php?t=47176
Front Sway Bar/Endlinks install 06 STi (niemkij)
http://forums.nasioc.com/forums/show....php?t=1450354
Rear swaybar install thread (GarnetWRX)
http://forums.nasioc.com/forums/show....php?t=1350673
How To: MY04/05 Whiteline Front/Rear Sway Install (Matth3w)
http://forums.nasioc.com/forums/show....php?t=1338083
Balljoints
6Gun Racing Ball Joint Extension Kit (nhluhr)
http://forums.nasioc.com/forums/show....php?t=1085638
TiC's notes on ball joints (Turn in Concepts)
http://forums.nasioc.com/forums/show....php?t=1268800
ALK
Anti-Lift Kit (ALK): How to install
http://forums.nasioc.com/forums/show....php?t=1570308
Old 01-20-2008, 05:23 PM   #3
Butt Dyno
Member#: 17301
is the "dark side"
Brake installations:
StopTech big brake kit on 2008 STi (Rallisport Direct)
http://forums.nasioc.com/forums/show....php?t=1494743
Brake rotors (kastle)
http://www.scoobymods.com/forums/showthread.php?t=476
Stainless steel brake lines (2002 WRX) (Peaty)
http://www.scoobymods.com/forums/showthread.php?t=2731
http://www.scoobymods.com/forums/showthread.php?t=1069
Stainless brake line install video (HSPN)
http://www.hspn.tv/?videoid=45&catid=14
Brake bleeding (kastle):
http://www.scoobymods.com/forums/showthread.php?t=182
How to turn the ABS pump on while bleeding (various):
http://forums.nasioc.com/forums/show...s#post20526989
http://www.iwsti.com/forums/braking/...-problems.html
What order do I bleed my brakes in? (shnibop)
http://forums.nasioc.com/forums/show....php?t=1462239
Changing your brake pads (kastle):
http://www.scoobymods.com/forums/showthread.php?t=181
Nissan 2pot rear caliper with Subaru Backing plate install (wopdeeze)
http://forums.nasioc.com/forums/show....php?t=1567707
DIY: Brembo Caliper disassembly (N8WRX)
http://forums.nasioc.com/forums/show....php?t=1600335
Old 01-20-2008, 05:23 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
Steering installations:
Steering rack bushing install video (nhluhr):
http://wrx.grapon.com/multimedia/Bushings_wmv.wmv
Old 01-28-2008, 10:54 AM   #5
noboost4u
Member#: 126442
My car is slower
than your car
You may want to add this williaty classic as well...
noboost4u is offline   Reply With Quote
Old 01-28-2008, 11:57 AM   #6
noboost4u
Member#: 126442
My car is slower
than your car
Old 02-17-2008, 04:49 PM   #7
niemkij
Member#: 141922
2006 Impreza Sti
niemkij is offline   Reply With Quote
Old 02-24-2008, 12:39 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
BD, thanks for doing this, I was thinking of trying to collect my HOWTOs in one place, a la Stretch's Notes, but this is even better.
However, the first tut of mine you link to is Lateral Link Bushings, not Trailing Link (you have NO idea how many times I swapped those words when writing the tuts!).
Also, grab my MAF Scaling HOWTO out of the Open Source Tuning forum, they're linking to it from romraider's forums now.
http://forums.nasioc.com/forums/show....php?t=1427448
Old 02-24-2008, 08:18 AM   #9
Butt Dyno
Member#: 17301
is the "dark side"
Doh! Fixed.
Why would that be in this thread?
Old 02-24-2008, 12:09 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
...Because I'm a dumbass and was thinking of collecting all tutorials, not just the suspension ones
Old 02-25-2008, 01:08 AM   #11
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
HSPN stainless brake line install video.
retroXvertigo is offline   Reply With Quote
Old 02-26-2008, 12:15 PM   #12
mla163
Member#: 104922
2013 BRZ
Subscribed.
Swaybars going on in two weeks and springs and shocks this summer. Thanks for doing my homework for me.
mla163 is offline   Reply With Quote
Old 03-07-2008, 09:36 AM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
control arm install
BIGSKYWRX is offline   Reply With Quote
Old 03-07-2008, 09:51 AM   #14
Butt Dyno
Member#: 17301
is the "dark side"
^^^ Good stuff! Added
Old 03-07-2008, 09:27 PM   #15
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
any on how to change your brake rotors?
SUBYDOODIE is offline   Reply With Quote
Old 03-08-2008, 05:16 PM   #16
mla163
Member#: 104922
2013 BRZ
I found this useful for F&R swaybar install.
Old 03-15-2008, 09:10 PM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Old 03-22-2008, 10:41 PM   #18
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
http://wrx.dicknogs.net/multimedia/Bushings_wmv.wmv
broken linky...
paintbing is offline   Reply With Quote
Old 03-24-2008, 05:02 PM   #19
Butt Dyno
Member#: 17301
is the "dark side"
Originally Posted by paintbing View Post
broken linky...
Fixed it. Thanks
Old 04-14-2008, 03:32 PM   #20
uj2
Member#: 158893
2006 Baja Turbo
Obsidian Black
Ditto (Baja/Legacy)...
uj2 is offline   Reply With Quote
Old 04-14-2008, 03:47 PM   #21
Butt Dyno
Member#: 17301
is the "dark side"
Sorry, I'll add this one:
The bolt sizes and torque specs may be different for your car, though.
Old 04-15-2008, 07:52 AM   #22
uj2
Member#: 158893
2006 Baja Turbo
Obsidian Black
Thanks, didn't realize that the suckers simply slide off.
Old 04-27-2008, 07:21 PM   #23
mla163
Member#: 104922
2013 BRZ
another spring install, pretty good write up
Old 04-27-2008, 07:58 PM   #24
Butt Dyno
Member#: 17301
is the "dark side"
Added, thanks!
Old 05-02-2008, 09:49 PM   #25
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Here's another ball joint thread:
I came in here looking for it, actually.
jamal is offline   Reply With Quote
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING! Butt Dyno Brakes, Steering & Suspension 5 04-09-2008 11:25 AM
ssautochrome install walkthrough? Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2006 06:46 PM
kyb agx and spring install walkthrough?? CXspeed Newbies & FAQs 4 05-09-2006 10:45 AM
Boost Gauge Install Walkthrough? Uncle Ben Electrical & Lighting 4 07-15-2003 04:31 PM
