Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 04-29-2008, 08:27 PM   #1
KENT56
Member#: 163129
Midnite
Default Anyone Changed Spark Plug Gap!?
anyone changed it? to run higher boost... if so wuts the diameter uve changed any pics?
KENT56 is offline   Reply With Quote
Old 04-29-2008, 08:55 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You need a pic of a spark plug gap....lot of good that'll do ya. Look, we have a forum for spark plug questions, this is moving...
Old 04-30-2008, 06:31 AM   #3
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Originally Posted by KENT56 View Post
anyone changed it?... if so wuts the diameter
diameter?
Micky is offline   Reply With Quote
Old 04-30-2008, 11:25 AM   #4
KENT56
Member#: 163129
Midnite
double post
Old 04-30-2008, 11:26 AM   #5
KENT56
Member#: 163129
Midnite
"Any larger gap suggested is wrong for a turbo app. A slightly smaller gap(.026" - .028" )
is commonly used in 'colder' plugs because of increased boost and the slightly smaller gap helps reduce spark blow-out."
i found this on the forum, so i was woundering if anyone have pics how it look like
Old 04-30-2008, 11:42 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
you might want to search more... pics aren't going to do anything for you, sparkplug gaps aren't really something that are going to be well documented with a picture.
in general, unless you have a reason to change the gap, you don't want to. larger gaps can actually increase power to a point, the smaller gap will help with SOME misfire issues if you increase boost, alot.
rkramer is offline   Reply With Quote
Old 04-30-2008, 01:37 PM   #7
KENT56
Member#: 163129
Midnite
my stock boost is 13.5 im going to have 16 - 16.5 should i go with smaller gap?
Changing spark plugs on 05 turbo... tips anyone? baja_burrito Baja Forum 25 02-25-2010 11:42 AM
Anyone change spark plugs in an STi? jmanSTI Texas Impreza Club Forum -- TXIC 14 12-03-2007 12:47 AM
Has anyone checked spark plug gap on an 03 ursmother Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-09-2005 08:15 AM
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 10:49 PM
Anyone know where I can find the proper spark plug gaps? 96Lconversion New England Impreza Club Forum -- NESIC 7 06-21-2001 03:30 PM
