Old 04-30-2008, 08:33 PM   #1
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
Default Help! Driver window won't roll up! Its about to rain :o
So I just rolled the window down in my 98 Legacy GT, and now it wont go back up.
The window doesn't look out of place at all. I can hear the motor when I push the button down. But I can't really hear it when I hit up. My button seems a little loose too, but not that bad.
Its about to rain, and I live in an apartment complex, with a deck and speakers in my car.
Thanks in advance, i'll reply to this thread asap if anyone has questions.
bagelicious is offline   Reply With Quote
Old 04-30-2008, 08:38 PM   #2
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
It's probably the switch, the contacts seem to wear out after a while... I had the same problem and had to replace it.
Cajual is offline   Reply With Quote
Old 04-30-2008, 08:42 PM   #3
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
Just the switch? Or the whole panel?
And, where/how much?
Old 04-30-2008, 09:00 PM   #4
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
is it all the windows?? or just yours that doesnt work....check every window, if they are all out it id check fuse
legacy1907 is offline   Reply With Quote
Old 04-30-2008, 09:02 PM   #5
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
All windows work except driver side up
Old 04-30-2008, 09:10 PM   #6
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
actuator??
Old 04-30-2008, 09:12 PM   #7
Cajual
Member#: 12900
It's the entire panel... all 4 switches are in one unit. You can get a used one on eBay, but I ordered a new one from subaruparts.com. I don't have the part # off hand, but if you take apart your door, it's probably labelled on the switch.
Old 04-30-2008, 09:19 PM   #8
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
After digging around, I've heard mention of a reset procedure for the windows (turning the ignition at certain times with the button held down) but I can't find the specifices anywhere.
Old 04-30-2008, 10:27 PM   #9
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
Well ****, all the dealerships/service centers are closed already. And its starting to rain, ****.
Is there ANY way I can get this up, just for tonight?
Old 04-30-2008, 10:30 PM   #10
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
plastic garbage bag and duct tape ftw
Old 04-30-2008, 10:45 PM   #11
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
I think i'd have a new problem on my hands then; fending off the hordes of ladies.
Old 04-30-2008, 11:18 PM   #12
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Old 05-01-2008, 12:34 AM   #13
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
At least the window didant fall down into the door like my GL turbo's did. That car got crushed shortly after that.
Chi_San is offline   Reply With Quote
Old 05-01-2008, 11:41 PM   #14
Javi_LGT
Member#: 157069
2000 LGT r.i.p. WRX
hey your gonna need to buy a new window switch anyway. so in the meantime if your motor works then find your motor harness and just plug two wires using butt connectors and touch power and ground to like a 9 volt battery. the window should go up then to go down just reverse the process it may be kinda ghetto or rigged up but it'll do untill you find a switch ok
Javi_LGT is offline   Reply With Quote
Old 05-02-2008, 02:24 AM   #15
Cajual
Member#: 12900
You could also take apart your rear door and run a couple wires with leads to that switch and put up your window. That's what I did when I was waiting for my new switch to come in the mail.
Old 05-03-2008, 01:21 AM   #16
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
I just got a new window switch, works fine now.
For anyone else with this problem:
Its called "window switch left" or master window switch". Retails for $109, i called Lithia Subaru in Oregon City and told them www.subaruparts.com had it for $83 and they pricematched it. Really quick/easy install.
Old 05-05-2008, 06:44 AM   #17
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
use pliers and a cloth (to protect window) to grab and assist the glass in an upward motion (quick fix)
then its tool time!
JoKerNZ is offline   Reply With Quote
Stupid window won't roll-up all the way. Jutboy Normally Aspirated Powertrain 3 06-07-2006 04:16 PM
Passanger and rear Windows won't roll down BigClunke Service & Maintenance 3 04-25-2006 02:38 AM
passenger side's window won't roll up/downl wistful Electrical & Lighting 1 04-23-2003 05:15 PM
Windows won't roll up or down at all! jwaters Service & Maintenance 7 11-13-2001 03:30 PM
Trouble opening driver door after window is rolled up wcbjr General Forum Archive 2 03-13-2001 11:31 AM
