Old 05-03-2008, 05:38 PM   #1
speedin
Member#: 79858
Default Bugeye JDM projector removal
Ok, I am trying to remove my JDM HID projectors out of my bugeye. I ran into a snag while trying to get them out, after viewing many others posts on retro's ive found the issue.
First here is the usual projector bracket ive been seeing
Now what I want you to pay attention to is the part of the mounting bracket with a hole. Looking at the projector from the front its the bottom left mounting spot.
here is a close-up of that spot (normal version)
Ok, now that is nice and easy to remove. Now here comes my luck. This is the way mine look at that mounting point.
No hole
And how the height adjuster mounts into the bracket. From my observations its a ball-ended rod secured by that white clip. Now I tried to get the clip out, but there is very limited room and would rather not damage my JDM HID's.
So anyone have experience with this bracket? What is the method for removal?
speedin is offline   Reply With Quote
Old 05-04-2008, 04:40 AM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
what is your reasoning for removingthe projectors??? retrofitting??
jdubya301 is offline   Reply With Quote
Old 05-04-2008, 12:22 PM   #3
speedin
Member#: 79858
Down the road i'll be doing a retro. Right now im going to flatten the shield
Old 05-04-2008, 12:39 PM   #4
Handsdown
Member#: 29355
flattening the shield will put the focus farther down in the beam. you'll still have to aim it down, even farther, and now the focus will be closer than it should be to your car and make things more difficult to see when they're farthest away, which gives you the most reaction time. there's little to no benefit to just shaving off the shield unless you can then replace the material and make it step up in the other direction.
just aim them down a bit for now and use the time and energy you would use to flatten the beam to get LHD hid projectors. they're not that expensive, i'm sure you can wait until you get them.
Handsdown is offline   Reply With Quote
Old 05-04-2008, 02:58 PM   #5
speedin
Member#: 79858
And this is why I should not have said anything. This is off topic and NOT up for discussion. I have the leveling motors and if my beam rises to the left and im not blinding people right now on setting 2 then why the hell wouldnt I raise the right side up to gain visibility. I can drop it to setting 3 and not blind a lotus elise driving at me from up a hill, but then switch it to 0 and have high beams. It is only removing the block (that over here is on the other side to prevent blinding), but I have no need for the block on the right. It will not affect any drivers on the road and only improve my right hand visibility.
Now unless you can contribute to the topic, have a good day.
Old 05-04-2008, 03:29 PM   #6
Handsdown
Member#: 29355
you're gun-ho to modify the projector optically, but you won't drill a hole to get to that one mounting clip on the bracket?
sorry for discussing your projectors in the thread you made about your projectors. i was only trying to help.
Old 05-04-2008, 03:50 PM   #7
speedin
Member#: 79858
Understood, but I have already investigated that issue and am tired of seeing it.
As for the drilling that did cross my mind. But I still wonder why mine looks as it does compaired to others
Old 05-04-2008, 03:50 PM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
to get the ball out of the socket i would suggest buying a automitive interior trim panel remover.
Old 05-05-2008, 12:59 AM   #9
speedin
Member#: 79858
I got it,
Its a bit uneasy to do but just pull . . . hard. Then it pops out.
LOL, thought I was going to brake it. But I realized it must be pulled after drilling and observing the clip and prying on the clip a bit. BTW, that metal is like butter to drill through, DAMN!
Oh, and the flattened shield helped right hand visibility alot, left hand glare and visiblilty were unaffected. And drivers dont have to worry about any glare issues (love the leveling motors!!)
Old 05-05-2008, 01:45 AM   #10
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
pics of output with the flatten shields?
Old 05-05-2008, 02:09 AM   #11
speedin
Member#: 79858
Will do, right after i do the left side. Only did one side so if it got messed-up it would be just one. Maybe tomorrow
FS: Driver's Side Bugeye JDM Projector, Non-HID 4bangers4life Exterior/Styling 15 12-06-2006 04:05 PM
Bugeye JDM projectors from ebay?? blueandgold Interior & Exterior Modification 28 10-08-2006 05:16 PM
FS So Cal: Bugeye JDM Projectors Dizzy89 Exterior/Styling 4 08-14-2006 10:14 PM
Bugeye JDM projector beam pattern quesitons BuggeyEYED Newbies & FAQs 2 03-15-2006 05:01 AM
HID's into non-hid bugeye JDM projector quesiton BuggeyEYED Electrical & Lighting 20 03-07-2006 10:03 PM
