Old 05-02-2008, 01:04 AM   #1
tico915007
Member#: 153038
07 STI
Default Benefits of a Breathable oil cap
I feel like an idiot but here it goes.....This is a 2007 STI mods are HKS catback and Cobb Intake. Maybe someone can help, yesturday I was adding some oil to my car was missing half a quart. To make a long story short i was in a hurry and i left the oil cap sitting on my intake manifold for about 24 hours unoticed obviously. While i was driving the car i was amazed to how much it pulled it had its initial jump but instead of staying consistent after 5,000 RPM it kept pulling like a champ. Thinking i was going crazy i took my buddy for a drive and he said my car felt faster and this morning my Girlfriend asked me if i did something else to make my car faster...... I finally notice my oild cap was off check my oil lever and it was fine. My question is does running with your oil cap off release presure in the motor allowing you to inadvertly run more boost or am i going crazy..... On my car before a 2004 gto i know when people were running boost on them the got a breathable type oil cap to releave crankcase presure is this so on our car?
tico915007 is offline   Reply With Quote
Old 05-02-2008, 01:05 AM   #2
tico915007
Member#: 153038
07 STI
this is what im talking about
Old 05-02-2008, 07:20 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
n/m---
Mulder is offline   Reply With Quote
Old 05-05-2008, 12:33 PM   #4
growling_boxer
Member#: 165744
2000 LGT
2007 STi
wow. i never heard of a breathable oil cap, but i'm subscribing to see if anyone knows anything about this.
growling_boxer is offline   Reply With Quote
Old 05-06-2008, 11:53 AM   #5
magnum2066
Member#: 158586
2009 WRX
Pearl White
This to me does make sense... Kinda.
When the oil cap is on the engine is constantly creating a vacuum, which could be like saying the engine is "pulling itself", which creates a constant vacuum. You may notice on some high-powered Chevy motors that the valve covers have breathers (usually have K&N style filters on top of them.) The picture you provided with the filter that replaces the oil cap... I just don't like that idea, plus the design scares the crap out of me. (What is holding it on?!) Air filters block most of the airborne debris, but never 100% so who knows what is getting mixed up with your oil.
Anyways, removing the oil cap eliminates the vacuum in the crankcase which in turn allows the engine to move more freely. It would be like going from a shirt that is a little snug to one that is a size or two bigger.
magnum2066 is offline   Reply With Quote
Old 05-06-2008, 12:09 PM   #6
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
This is the first I've heard of the breathable oil cap. I'm interested in learning more on it and what applications can utilize it.
axelthrasher is offline   Reply With Quote
Old 05-06-2008, 03:16 PM   #7
strohausii
Member#: 26770
'02 WRX
midnight black
Wouldn't this kill the vacuum needed for the assisted brakes (or is that vacuum created from some thing/place else)?
strohausii is offline   Reply With Quote
Old 05-06-2008, 03:29 PM   #8
prometheum
Member#: 92003
04 bicycle!
we have something similar to that on our cars its plumbed to the intake...
prometheum is offline   Reply With Quote
Old 05-06-2008, 05:16 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
Yeah, and there is always a vacuum on that end (suction intake), and the PCV valve (one way check valve) on the other end of one hose.
I just remember auto-x'rs running out vacuum and the pedal getting hella heavy (then plowing into cones soon afterwards) as the stories went.
Old 05-06-2008, 08:46 PM   #10
magnum2066
Member#: 158586
2009 WRX
Pearl White
Eliminating vacuum in the crankcase has nothing to do with the brakes. Two completely different systems.
Old 05-06-2008, 08:58 PM   #11
rkramer
Member#: 118209
2015 WRX Limitec
my 1.9L ford escort had exactly that. It came factory with a line plumbed into the intact tract behind the filter, and was replaced along the way with a mini k&n style filter. (held on by hose clamps, it wasn't moving!)
rkramer is offline   Reply With Quote
Old 05-06-2008, 09:06 PM   #12
prometheum
Member#: 92003
04 bicycle!
correct the master cylinder is plumbed directly to the intake manifold on the driver's side
Old 05-06-2008, 09:12 PM   #13
flatthump
Member#: 102749
2005 impreza STi
OBP'
There is a decent amount of pressure in the crank case especially in these EJ's.
Why not tap your oil cap with a barbed fitting and run it to a catch can? (along with the other breather lines) I think I'm going to do this.
flatthump is offline   Reply With Quote
Old 05-07-2008, 08:53 PM   #14
dangerousdan
Member#: 147003
isn't there a company that makes high boost pcv valves? I'm sure I've seen that somewhere.
dangerousdan is offline   Reply With Quote
Old 05-08-2008, 11:54 AM   #15
strohausii
Member#: 26770
'02 WRX
midnight black
Found this related link, seems like a good read for/against:
http://www.supersixmotorsports.com/pdf/PCVBypass.pdf
Old 05-08-2008, 12:11 PM   #16
tico915007
Member#: 153038
07 STI
so i wasn't going crazy potentially this could of made my car feel "faster"...... it wasnt like it was 100 hp more just felt like the car was losser almost like i was accelarating downhill all the time
Old 05-09-2008, 03:21 PM   #17
Anthony Longo
Member#: 179605
ok so this is a good thing...why wasnt i aware of this before ,,,,,,,can the effect be seen on a normaly aspirated car
Anthony Longo is offline   Reply With Quote
Old 05-09-2008, 04:35 PM   #18
magnum2066
Member#: 158586
2009 WRX
Pearl White
Yep. Even non-turbo vehicles have a vacuum while the engine is running.
Old 05-09-2008, 04:46 PM   #19
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
Ya know when i get dyno'd i'm going to do that test.
This would be interesting to see.
I have 2 oil caps i'll drill one and put a breather on it and have stock as well.
Chandy69 is offline   Reply With Quote
Old 05-14-2008, 02:59 PM   #20
tico915007
Member#: 153038
07 STI
sounds hood let us know your results
Old 05-14-2008, 04:00 PM   #21
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Ummmm... what about the vacuum helping the sealing of the rings?
Old 05-14-2008, 04:02 PM   #22
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Vawy intewesting!!
http://www.speedwaymotors.com/p/1877...Breathers.html
I found this link. Does anyone know the diameter of the oil cap hole? I would be willing to buy one for 15$ shipped and see if it does any good for a RS.
Gr3en is offline   Reply With Quote
Old 05-14-2008, 08:47 PM   #23
magnum2066
Member#: 158586
2009 WRX
Pearl White
Keep in mind that although your car feels faster, you will get no gain in HP. The only difference would be how fast you are able to rev up. Again it reduces the load on the engine, which almost has the same effect as putting on a lightweight flywheel (or pulley). You are merely freeing up more power to the wheels.
Old 05-14-2008, 08:56 PM   #24
wrx_evo_jetta
Member#: 70283
There you go!! There's part of the next Periodic Review Of Nasioc video
wrx_evo_jetta is offline   Reply With Quote
Old 05-14-2008, 11:58 PM   #25
Arctic Penguin
Member#: 119532
2006 WRX
ALL
repeat
ALL
internal combusiton engines are, for all intents, vacuum pumps and create vac as a function of their functioning
FI engines just change where they are creating vac when on boost compared to off boost operation.
They ALWAYS suck air in at one end and force it out the other end while in operation.
Arctic Penguin is offline   Reply With Quote
gauges egt,oil pressure,& boost and pod looking to spend no more than 400shipped jeremywrx15554 Private 'Wanted' Classifieds 2 06-04-2009 02:01 PM
FS: NJ CF Rad cooler, Alt cover & Hood dampers/ Prodrive oil cap & bat tie and more ktulu990 Interior/Dressup/Audio & Security 19 11-17-2008 12:01 PM
02 WRX part out - (gauges, shifter, knob, sti oil cap, morette, and more to come...) silvscorp Private 'For Sale' Classifieds 40 10-18-2005 10:22 PM
boost, no boost, more boost...***!!1!11 03twrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-05-2004 04:16 AM
Carbon fiber Belt Cover / Oil Cap / Boost Cover - On Ebay ApexR Private 'For Sale' Classifieds 15 11-11-2003 01:36 PM
