Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-30-2008, 02:01 PM   #1
RenickMotorsports
Vendor Sales Rating: (26)
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Default BLOW OUT SALE ROUND 2! Gaskets, 2.5 Short Block, JDM TGV's, 08 SPT Catbacks!!!
OEM Gasket Super Sale!
Upper Downpipe $11.95
Exhaust Mani Pair $16.95
Lower Up-Pipe $8.99
Upper Up-Pipe $8.99
BPV/BOV $5.99
OEM 08 STi Magnetic Drain Plug $3.99
Released mid year for the 2008 STi. The OEM STi drain plug is fitted with a magnetic unit to secure metal debri, helping to prevent engine wear and potential engine failure. Fits all model Impreza's 2.5RS, WRX and STi from 93-2008, all model Legacy's and Foresters. Comes with an OEM crush washer.
JDM TGV DELETE PAIR $179.00
TGV delete fits USDM 2.5L turbo engines using side feed Injectors. Will work with 2004-UP Impreza STi, 2005-UP Legacy GT and Outback GT, and Forester XT. Will not work with 2006-UP WRX because it uses top feed style Injectors. Your check engine light will need to be 'flashed' off using engine management. Sold as pairs.
http://www.renickmotorsports.com/osc...oducts_id=1843
2.5L STi 257 Short Block. $1739.49
Complete short engine, block, crank, main bearings, rods, rod bearings, pistons, rings. This is the short block that comes in the 2004-2006 STi from the factory. Gasket set sold separately.
http://www.renickmotorsports.com/osc...oducts_id=1377
2008 WRX SPT Catback Exhaust 5 Door in stock!$330
The new stainless steel exhaust system replaces the stock WRX center pipe and rear muffler assembly with a smooth flowing, low restriction, better-sounding exhaust note, plus a 10 horsepower increase! The 2008 Impreza SPT Cat-Back Exhaust Systems are covered by the 3-Year, 36,000 mile Genuine Subaru Accessory Parts Warranty, and may be installed by the dealer. Call to pre-order your 4 door SPT!
http://www.driveperformance.subaru.c...reza_parts.asp
JDM STI PINK 565CC WRX INJECTORS SET OF 4 $355
BORLA HEADERS WRX/STI $439
T-304 Stainless Steel, an alloy superior to T-400 series knockoffs, to give you the absolute best in performance, sound and durability. Ultra-smooth mandrel bends and precision computer-controlled CNC manufacturing give you maximum flow, and power. Will fit Impreza WRX, STi, Forester XT, Legacy and Baja Turbo.
TITEK UP-PIPE
#SUB-10003 $120
SUS304 stainless and have increased rigidity through the flex joint, which also aids for a much easier install. This piece is precisely tig welded with an EGT sensor bung.
AVO WRX/STI CATBACK EXHAUST
#WRX-2002-550 $550
3" stainless steel, and designed to bolt up to the stock locations/flanges. The high-flow design is rated of 86 dB, making it a good choice for noise conscious performance-oriented customers. Comes with a 3 1/4" rolled tip.
BPM LARGE TOP MOUNT INTERCOOLER $644
UTILIZES A MUCH LARGER THAN STOCK CORE, AND FREE FLOWING SILICONE INTERCOOLER PIPING TO COOL YOUR INTAKE CHARGE. BPM'S INTERCOOLER DESIGN FEATURES LARGER CIRCULAR INLET PORTS TO PREVENT AIR FLOW RESTRICTION.
RenickMotorsports is offline
Old 04-30-2008, 02:01 PM   #2
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
BLITZ PANEL FILTERS
#59515 $26.50
Utilizing the same filter as the LM Core-type filters, the BLITZ® LM Stock Replacement Filters are designed to reduce intake restriction and provide maximum filtration without sacrificing the stock air-box.
02-07 WRX SPT INTAKE and HEATSHIELD PACKAGE PRICE $230
SPT intake only $169, SPT heatshield only $73
Carb legal in 50 states. Will not void your warranty. Fits all WRX and STi Impreza models.
STI RAD CAP $40
High pressure radiatior cap increases presure rating of cooling system from 13 lbs to 18.9 lbs. This allows for more efficient cooling under demanding conditions.
SPT TURBO SHIELD $58
The SPT Turbo Heat Shield helps to retain heat within the turbocharger, which helps to keep the heat generated by the turbocharger away from the intercooler. Fits 2006-2007 WRX, 2004-2007 STi and 2004-2007 Forester XT.
FREE Seat Belt Pads With ANY ORDER! Choose color shown below
Old 04-30-2008, 03:27 PM   #3
moosecakes
Member Sales Rating: (48)
Member#: 136098
07 35r WRX
Maxwell Power
please pm price on turbo to DP gasket and turbo to UP gasket as well as paypal info. Thanks!
moosecakes is online now
Old 04-30-2008, 05:19 PM   #4
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
PM'd you.
Old 05-08-2008, 12:01 PM   #5
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump, because porting your stock TGV's with your car out of commission isn't fun at all.
Old 05-12-2008, 02:00 PM   #6
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 05-12-2008, 06:52 PM   #7
Scubydood
Member Sales Rating: (4)
Member#: 165503
2005 Sti
JDM TGV's are $179.99 regular price at other places.
Scubydood is offline
Old 05-13-2008, 12:54 PM   #8
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Price updated! Items in stock and ready to go.
__________________
Old 05-14-2008, 02:01 AM   #9
Ski Bum
Member Sales Rating: (7)
Member#: 95393
2004 Forester XT
jasonfxt @ sf.org
I need some gaskets. Please PM price for exhaust manifold-block gaskets (2), manifold-uppipe gasket, uppipe-turbo gasket and turbo-downpipe gasket. Should be 5 total. Shipping to 95610. Thanks!
Ski Bum is offline
Old 05-14-2008, 05:05 PM   #10
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
PM'd you.
__________________
Old 05-17-2008, 01:44 PM   #11
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bumpin
__________________
Closed Thread
*WTB: STI short block, JDM 2.0 or USDM 2.5 Lam Private 'Wanted' Classifieds 5 02-14-2008 06:42 PM
*WTB: STI short block, JDM 2.0 or USDM 2.5 Lam VIC Private Classifieds 0 02-11-2008 11:38 PM
Round 2 of Whiteline Suspension Components Blow Out Sale! Many other parts too! SpeedElement Suspension/Brakes/Handling 85 11-30-2006 04:42 PM
Huge Blow Out Sale On Oem Parts For 2000-2001 Impreza 2.5 Rs spudnyo Private 'For Sale' Classifieds 5 11-04-2005 09:53 PM
2.5 short block or long block JoshP Private 'Wanted' Classifieds 6 11-01-2005 01:45 PM
