Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 05-16-2008, 09:17 PM   #51
MRF582
Member#: 48219
. Always drive
the race line .
GST GC8
Blue WRX Wagon
Where did you guys get your fender flares from?
MRF582 is offline   Reply With Quote
Old 05-16-2008, 09:26 PM   #52
iheartmysuby
Member#: 83638
nice. loook good. i kinda would rather see them paint matched. but ferk. looks mean
iheartmysuby is offline   Reply With Quote
Old 05-16-2008, 10:11 PM   #53
posite
Member#: 165055
09 335i ..tuned
wrx 18g ewg fmic meth
I'm very impressed! Great job and if you do paint match them definitely post some pics!
posite is offline   Reply With Quote
Old 05-17-2008, 01:13 AM   #54
Gr8wall
Member#: 23209
wrb
Originally Posted by GST Motorsports View Post
We did indeed run those flares, we have since switched to these..
They are conciderably wider than the previous fender flares we ran and since we needed to change the geometery of the suspension we had no choice as with the new ride height being 2" or more lower than we have previously ran we needed a bigger flare to cover our nasty tires.
Mike
what rims are those?
Gr8wall is offline   Reply With Quote
Old 05-17-2008, 01:39 AM   #55
Joshb120
Member#: 179074
very nice
Joshb120 is offline   Reply With Quote
Old 05-17-2008, 11:13 PM   #56
overtheover
Member#: 139547
04 WAGON
[email protected]
Originally Posted by gold rush View Post
It splits at the rear doors so you can still use them. Thanks, I'm really happy with how it turned out.
nice! did they come like that?
i didnt see how much you paid for them
overtheover is offline   Reply With Quote
Old 05-18-2008, 01:28 PM   #57
jasonb
Member#: 1809
2006 WRX wagon, OBP
99 Jeep XJ
Very impressive. They look good. Talk about meats now!
jasonb is offline   Reply With Quote
Old 05-18-2008, 01:37 PM   #58
dontgiva
Member#: 105098
07 OBP WRX
Bangbus
thats looks bad
just get the rear over fender
dontgiva is offline   Reply With Quote
Old 05-18-2008, 01:44 PM   #59
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i like them!
distorto is offline   Reply With Quote
Old 05-18-2008, 06:36 PM   #60
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
Is that a 50 series tire it looks so fat, i would go with a lower series it wouldnt look as monster truck...
105wrx is offline   Reply With Quote
Old 05-18-2008, 10:10 PM   #61
TheAnser
Member#: 84045
2015 WRX Base 6M
LR
THAT looks bad***! Love everything about it!
TheAnser is offline   Reply With Quote
Old 05-18-2008, 10:16 PM   #62
runwrxrun
Member#: 51488
im a little curious to what coilovers are you running? Spacers? distance between strut and tire (front and rear)?
runwrxrun is offline   Reply With Quote
Old 05-19-2008, 12:40 AM   #63
gold rush
Member#: 90110
2004 wrx wagon
The tires are Hoosier 275/40/17 R6's on Work Emo Kai 17x9 44et. I have sedan control arms and lateral links and DMS 40mm coilovers, they are big so I need to run a 15mm spacer to get about 5mm of space from the coilover in the back and maybe 10mm in the front. We'll see how long the wheel bearings last... I think next time I'll get the 6gun 05 STi hub on a 5x100.
gold rush is offline   Reply With Quote
Old 05-19-2008, 01:24 AM   #64
runwrxrun
Member#: 51488
have you tried pulling the struts away from the tires with camber plates and kicking the tire out with camber bolts for more clearance? it would probably help you avoid using thick spacers and run longer on the bearings.
I'm planning to do the exact same set up but on my DD 03 sedan and with 275/40/17 street tires and same wheels
Old 05-19-2008, 02:34 AM   #65
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
are those the same team prototype flares i have?
mock-up pic
WgnWheel is offline   Reply With Quote
Old 05-19-2008, 12:07 PM   #66
gold rush
Member#: 90110
2004 wrx wagon
mock-up pic
Yeah looks like it, mine are "Wald" brand, are they for a Lexus IS300? The fronts bolted right up, but in the rear we had to cut the small door piece and glue it to the other side for a better fit. And we needed to trim the rear door a bit for shutting clearence.
Old 05-19-2008, 01:34 PM   #67
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
yep, same thing. they are reproduced molds from the wald is300.
Old 05-19-2008, 02:35 PM   #68
gold rush
Member#: 90110
2004 wrx wagon
mock-up pic
I wish I would have known about these replicas before I bought mine... 1/3rd of what I paid.
http://estore.teamprototype.com/?nav...s&product_id=6
Old 05-24-2008, 03:16 PM   #69
gold rush
Member#: 90110
2004 wrx wagon
The rear doors:
Old 05-24-2008, 04:01 PM   #70
errdizzle
Member#: 176771
2007 wrx wagon
18x9.5 +35 w/ 225/35s
did you paint them? whats the piece you cut out and glued on the other side? looks like it came like that.
errdizzle is offline   Reply With Quote
Old 05-24-2008, 05:34 PM   #71
gold rush
Member#: 90110
2004 wrx wagon
We cut, glued and sanded them then we had to paint them to cover up the work.
Old 05-25-2008, 07:29 AM   #72
Brody8877
Member#: 92355
2013 Impreza 2.0i
Ice Silver
o0o inspirational. Me likely alot!
Brody8877 is offline   Reply With Quote
Old 05-25-2008, 09:49 PM   #73
CoryTurner
Member#: 153379
2007 2.5I wagon
Urban Gray
so what u did was cut this part in red off...
and then reattach it where it's now at in this picture? then clean it up before painting?
CoryTurner is offline   Reply With Quote
Old 05-25-2008, 11:12 PM   #74
gold rush
Member#: 90110
2004 wrx wagon
Thats exactly what I did, with the help of a friend who knows bodywork. He also used some mesh tape to cover the holes left from cutting then used this glue/bondo stuff to fill it in along with the crack between glued pieces.
To be honest, the hardest part of the whole thing was putting longer studs in the rear hubs for the spscers, that was a nightmare... I ended up breaking a bolt off in the rear caliper and breaking one of the a.b.s. rings, that was a long night.
Hint*** If your ever putting long studs in the rear hubs the easiest way to get them in is to port out the hole for the abs sensor to get the long studs in from the back of the hub.
Old 05-26-2008, 12:25 AM   #75
Su||y
Member#: 169794
2007 WRX Wagon
Stage Catless
That is the tightest thing I have ever seen! Very cool!
Su||y is offline   Reply With Quote
Wagon Fender Flares? sithspawn Interior & Exterior Modification 37 02-18-2011 03:05 AM
WRX Wagon Fender Flare Boosted Wagon Interior & Exterior Modification 1 10-14-2002 11:57 AM
Wagon Fender Flares! gingerbread man Interior & Exterior Modification 14 04-01-2002 12:10 AM
wagon fender flares travmn Interior & Exterior Modification 2 01-09-2002 10:02 AM
wagon fender flares gingerbread man Interior & Exterior Modification 4 12-14-2001 06:30 PM
