Old 05-23-2008, 03:29 PM   #1
WarmPepsi
Member#: 80080
08 wrx
wrb
Default 2008 STI Headlight housing/HID to WRX, 2.5i?
From a non-owner, this might seem like an odd question, but are the housings interchangable? Seems like an easy way to add a nice HID system, even if you didn't use the factory bulbs.
Somebody call me a noob.
WarmPepsi is offline   Reply With Quote
Old 05-23-2008, 03:59 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Yes it's a common swap to put STi HIDs into other Imprezas, but the entire light assembly has to be changed.
Mulder is offline   Reply With Quote
Old 05-23-2008, 04:05 PM   #3
WarmPepsi
Member#: 80080
08 wrx
wrb
cost for 08 units? ( i know the evo headlamps are outragious.)
Old 05-23-2008, 04:54 PM   #4
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
Not entirely
I have '07 STi D2S bulbs, STi ballasts, Lightwerkz/STi hybrid harness, and stock '06 2.5i projectors inside my 2.5i housings.
semaj is offline   Reply With Quote
Old 05-23-2008, 05:01 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Originally Posted by semaj View Post
Not entirely
Sure you can do that, but he was asking about swapping housings so my answer was directed as a response to his question. What you have is OEM bulbs and ballasts in the H7 halogen housings, not the same thing.
Old 05-23-2008, 05:12 PM   #6
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
Yes you answered his original question, and I offered another cheaper alternative to changing entire headlights with similar results. I know my projectors aren't the same as the STi ones however.
Old 05-23-2008, 05:16 PM   #7
WarmPepsi
Member#: 80080
08 wrx
wrb
gotcha. to me, the only reason to swap them, would be the housing designed for HID. Whereas at least with a projector (even halogen), you do get a fairly good clean cutoff.
thanks guys.
Old 05-23-2008, 05:31 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Correct, you are better off with an HID housing vs. a halogen housing with HID bulbs. It is possible to get acceptable results with D2S bulbs in halogen H7 lights (I actually have this setup in my Morettes), but it still won't match the performance of true HIDs.
Old 05-23-2008, 07:31 PM   #9
Amnizu
Member#: 178854
2008 WRX, '11 BMW 1M
Red, AW
Does anyone know the part numbers for the '08 STi balists, bulbs and housings?
Amnizu is offline   Reply With Quote
Old 05-23-2008, 08:01 PM   #10
WarmPepsi
Member#: 80080
08 wrx
wrb
do you guys have a subie dealer as a vendor here on site? like a parts # request thread? I looked, but didnt find anything.
Old 05-23-2008, 08:14 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Go to www.subarugenuineparts.com
Jamie/Subie Gal is the contact person there and will hook you up with the info you need.
Old 05-23-2008, 08:16 PM   #12
WarmPepsi
Member#: 80080
08 wrx
wrb
Nice. good site you guys got here. some helpful people too.
Thanks.
Old 05-24-2008, 06:02 PM   #13
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
Which is why I will have TSX projectors when I can afford them. The D2S bulbs in my H7 projectors is temporary.
FS: (Cincinnati/NKY) STi "Pinks" Springs for 08+ WRX/2.5i CincyWRX MWSOC Private Classifieds 6 04-14-2010 12:34 PM
FS: (Cincinnati/NKY) STi "Pinks" Springs for 08+ WRX / 2.5i CincyWRX Suspension/Brakes/Handling 6 04-14-2010 12:33 PM
Are 06 WRX headlight and 06 STi headlight housings the same? Schell Interior & Exterior Modification 1 09-27-2007 07:14 PM
STi headlight housings into a WRX? geist Interior & Exterior Modification 3 10-07-2006 08:30 PM
IL: WTB 04-05 STi headlights or parts to convert my WRX lights to HIDs Ace009 Private 'Wanted' Classifieds 2 08-11-2006 12:50 PM
Message Board Statistics All times are GMT -4. The time now is 03:26 PM.
