Old 06-24-2008, 10:24 AM   #1
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Default VF39 and VF43 directly compared!
I have been meaning to post these for a while.
SO, I have a VF43 and a VF39 here to be ported, both in great shape, so I thought these would be perfect for comparison, to discover a few things, and to my suprise, dispell a couple myths.
SO here they are
The VF43 is on the right, VF39 on the left. Think that the VF39 compressor housing looks slightly beefier? It is. Its not a huge difference, but its definately bigger. Notice that the compressor wheels look identical? Having seen so many IHIs apart, I can tell you that I would bet my life on them being the exact same wheel.
What does this mean? That they are identical turbos when it comes to the compressor section, if anything, the VF39 compressor would be slightly better.
VF43 closer pic
VF39 closer pic
Back side pics, again, VF43 on left, VF39 on right.
Identical size hot wheel outlet. Wheels look identical. I have a pic of the VF39 wheel with the housing off, I will be disassembling the VF43 today, and as long as I can get the hot housing off (many MANY VF43s are seized together and simply cannot be split) I will get pics to directly compare the two wheels to confirm if they are in fact the same hot wheel.
Side by side on their side. The angle isnt the best, but the hot sides are identical size wise. There are some VERY slight differences in shape, but not any that would make a power output difference.
Here is a closer pic of the VF39 hot side
Here is a closer pic of the VF43 hot side
So I have to say, there is no way that either of these turbos will make a measureable difference in power from one to the other.
The VF39 cracks pretty often, and in 99% of cases, it doesnt change the performance in any way.
HOWEVER
The VF43 also cracks, not as often, but it DOES crack in the same place.
I will stick my finger in and see if I can feel any thickness or shape differences inside the inlet of the hot side, to see if maybe the 43 is thicker or something in the area that typically cracks. Looking in there, it doesnt look any different.
This confirms my suspicion that the reason the 07 STI makes a decent bit more power on the stock turbo, is due to the changes in the motor itself. At least that is what I have always thought, and now believe even more firmly. From what I have seen, the 07 STI seems to make a bit more on every turbo. I could be wrong there. I just seem to have noticed that.
Anyway, this isnt meant to start an arguement as to one being more power producing than the other. I just wanted to share my findings, and I havent seen side by side pics. (maybe they are out there? I didnt see them)
Thoughts?
Defiant Autospeed is offline   Reply With Quote
Old 06-24-2008, 10:39 AM   #2
RSbullet
Member#: 177171
2006 Sti
OMFG.... THANXXXX for this.
+1234567890123456789012345678901234567890 KUDOS!
+1 for sticky.
RSbullet is offline   Reply With Quote
Old 06-24-2008, 10:46 AM   #3
03_Impreza_Al
Member#: 146606
You got them mixed in the first pic. 39 on the left and 43 on the right.
03_Impreza_Al is offline   Reply With Quote
Old 06-24-2008, 10:47 AM   #4
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Yeah I did..
Fixing it right now.
The rest of the pics are correct (were to begin with, just making sure that is clear )
Also removed the double pic
Old 06-24-2008, 10:47 AM   #5
Clark_Kent
Member#: 114299
Well if this is in fact true props to all those that have sold their VF43s for a higher price because it's a "better" turbo.
Clark_Kent is offline   Reply With Quote
Old 06-24-2008, 10:49 AM   #6
fullerton
Member#: 122030
Have a 48 laying around?
fullerton is offline   Reply With Quote
Old 06-24-2008, 10:56 AM   #7
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Well, in all fairness, the 43s probably had lower milage on them. We know that at least, the differences in the pics are true. Getting the housing off the VF43 will tell the story on the hot side wheel comparison. I will get comparison pics there as well.
Not yet, Im sure I will get my hands on one at some point. I have been doing a decent bit of porting turbos lately, so the chances of me having a 48 and either a 39 or a 43 at the same time are decent. I will get pics when I have one.
Old 06-24-2008, 12:08 PM   #8
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Old 06-24-2008, 01:39 PM   #9
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
nice information.... now im waiting for hot side/inside pics...
All4bSpinnin is offline   Reply With Quote
Old 06-24-2008, 01:43 PM   #10
ringe
Member#: 49998
2007 WRX CT Stg 2
I really can't tell in the pics but could you put a micrometer on that wastegate flapper and tell us if there is any difference between the two? Also, if there is anything else different or special about the wastegate internal dimensions or shape.
Thanks for this thread, good work.
ringe is offline   Reply With Quote
Old 06-24-2008, 02:09 PM   #11
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I will get a caliper in the holes when I get the apart. I am out the door to go do it in about 5 minutes.
Old 06-24-2008, 03:11 PM   #12
azul89
Member#: 123491
2006 WRX TR
WR BLUE
awesome.!
azul89 is offline   Reply With Quote
Old 06-24-2008, 04:15 PM   #13
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Thanks I figured this would be usefull info, or at least interesting.
I have been nauseated all day, tossing the cookies easily once an hour, so I havent been able to get out to it yet.
This pretty much stinks :bleh:
Old 06-24-2008, 10:15 PM   #14
fastwrx25
Member#: 126441
03 bugeye
sweet! thanks for taking time to do this.
Old 06-24-2008, 10:27 PM   #15
SpADeZ_WRX
Member#: 160871
Great info!!! Deff Sticky!!
SpADeZ_WRX is offline   Reply With Quote
Old 06-24-2008, 10:30 PM   #16
grex07
Member#: 167116
2013 STi 5Dr
i thought the only difference was the 43 doesnt have boost creep issues.
grex07 is offline   Reply With Quote
Old 06-24-2008, 10:57 PM   #17
bajozzy
Member#: 137556
2011 STI Sedan
Looks like the 39 is addicted to Torco
bajozzy is offline   Reply With Quote
Old 06-24-2008, 11:48 PM   #18
slovak
Member#: 168922
Actually, the 43 dose have boost creep issues so that's why you need to get them ported out, found that out the hard way, but it did not cost me much thanks to my shop.
slovak is offline   Reply With Quote
Old 06-25-2008, 12:11 AM   #19
phillepe
Member#: 88856
2007 Sti
on 36's.....
Thanks alot dude, you are awesome! So many questions can be answered by looking at this thread.
phillepe is offline   Reply With Quote
Old 06-25-2008, 09:00 AM   #20
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Yeah if its an IHI you can count on a good chance it will creep on the 2.5. They are just not quite as good of a design as the mitsu based turbos. Even then, the mitsu turbos can creep. I am of the opinion that creep isnt as much an issue caused by that, but caused by the hot side being too small for the engine itself. Here is why I say this.
-From what I have seen, TD06s creep less than TD05s
-8CM housings creep less than 7cm. Most 8cms dont creep. It seems like maybe not most 7cms, but a lot, do creep. You definately stand FAR less chance it will creep on an 8cm housing than a 7cm.
-2.0L wrx motors dont have anywhere near the instances of creep.<which points at the turbo being more properly matched.
-the way a 16G "feels" on a 2.0L, is the way an 18G "feels" on a 2.5L This is a compressor difference obviously, but as far as "this is what it feels like it should have come with", that is a decent comparison. That tells me that they are more properly matched to those motors.
People also need to understand that porting the turbo doesnt only benefit you by reducing creep. It wildly changes the spool and response characteristics of the turbo. This isnt as much of an issue on the 2.5L as it is on the 2.0L, which needs all the help it can get in that dept, but its still a big difference between how fast a ported turbo is than a non ported turbo. Moral of the story there is that ANY stock location turbo benefits from porting. Even a TD06-20G 8cm, will perform a good bit better if properly ported.
Old 06-25-2008, 10:37 AM   #21
klanner
Member#: 182154
93 Sentra RS
Nice write up! Thanks for the info!!
klanner is offline   Reply With Quote
Old 06-25-2008, 11:55 AM   #22
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 [email protected]
good info ...thank you!
boostdog is offline   Reply With Quote
Old 06-25-2008, 05:30 PM   #23
Blu_Scobbie
Member#: 67849
2003 WRX Wagon
Great info! Glad that the fighting and misinformation can finally end!
+1 for sticky
Blu_Scobbie is online now   Reply With Quote
Old 06-25-2008, 09:12 PM   #24
Imprezha
Member#: 6818
2002 NSX
2010 Gen Cpe,2016 Outback
Thanks for the great info!
Imprezha is offline   Reply With Quote
Old 06-25-2008, 10:28 PM   #25
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
Great info!! Looking forward to seeing a comparison of a VF48 to put some facts to the speculation that is floating around
cellgeek101 is offline   Reply With Quote
FS: VF39 and VF43 wrXmon Engine/Power/Exhaust 10 01-13-2010 08:19 PM
Looking for vf39 or vf43 Turbo and sti TMIC Nictj33 NWIC Private Classifieds 5 12-02-2008 01:45 PM
FS CO: VF39 and VF43 STIBungy Engine/Power/Exhaust 4 07-27-2008 08:53 PM
WTB: VF30 or VF34 or VF39 or VF43 or FP16G and sti pinks dap7298 Private 'Wanted' Classifieds 3 07-19-2008 03:30 PM
WTB: vf39 or vf43 and STI 565 pinks Blinger Private 'Wanted' Classifieds 0 08-12-2007 03:56 AM
