#1 |
Member#: 63990
Vehicle:2002 WRX Flat Grey |
So this year's project is about to get underway. The idea of the build is to really show an upgrade path for us Hybrid builders and to do so using some of the newer vendors and products on the block.
Like most guys who ended up with a hybrid motor (2.0L WRX heads mated to a STi Shortblock) I had been modding my 2.0L engine. I had just performed a TD05-16G upgrade, with STi pinks and low and behold, the main bearing went on the engine. When we took the engine apart we had found that the oil pan had been taken off the car before. So the previous owner had to have done "some kind" of work on the engine before I purchased the car. The car was one of the first cobb Stage II packages ever sold and installed on a WRX in Canada and was one of the testing beds for the packages. So that is where the hybrid road began. In went the 2.5L STi shortblock mated to my WRX heads and I added on a FMIC for good measure. Like most of us guys who have done the hybrid thing, you soon find out that the turbo you chose before doesn't really match your new goals and engine setup. Also the heads and flow characteristics aren't what you want either. So this spring I began talking to a bunch of vendors and compaines with new, or newer, products out there to piece together a build for a nice street setup. The idea was that I wanted to do a build that would be relatable to a lot of Hybrid builders out there. And I wanted to do it with companies that were not the "big" and "usual" names that you hear. Giving the newer guys an opportunity to show that their products can stack up with the best of them and get some real world coverage of a build that would showcase their products and show the gains that were achieved. Most people doing progressive upgrades have parts from multiple vendors and there really isn't a lot of good information on how they work together. Typically you get one company showing the gains of using all of their products together. Understandably because they are selling their products. First I started talking to Derek at Group-A performance who I have known through the Toronto Subaru Club and they were happy to get involved when they heard what I was wanting to do. They have an ever expanding product line that is being picked up by many of the different vendors out there. These guys have some great products that I will be using in the build. - Front/Rear endlinks - Pitch Mount - Alternator, Power Steering, Crank Pullies - Subframe locking kit Next I started talking to Brian Crower about his 2.0L valvetrain kit and decided that it was the route that I wanted to take for my heads. For the street performance I am looking for with the car, I didn't feel the extra expense of porting work was going to be worth the cost. So I am going with a drop in valvetrain upgrade: - Brian Crower 272 cams - Brian Crower Spring/Retainer kit Next I was wanting to do more work around the flow restrictions of the stock 02 WRX parts. So I started doing some research and got in contact with Justin and the guys at Grimmspeed . They have been doing some great work with their porting and coating of OEM parts to give them that extra performance while retaining the OEM quality. So the following Grimmspeed products will be finding their way into the Batmobile. - Ported/Coated Intake Manifold - Ported/Coated TGV deletes - Ported/Coated Headers & Cross-pipe - Phenolic Spacers At this point I still don't think I will be going EWG but we will see.. For emissions and other reasons I'm still on the fence here. So far the flow parts have been taken care of, so I needed to do something about the little snail that I have on there. Right now the fact that I am running the stock STi shortblock and still running my 02 WRX tranny, made it so that I didn't want to go with a huge turbo, but wanted to go with something that would be a fun street turbo. This is where I started to talk with Jerry back at Deadbolt. These were the guys that I originally bought my 16G from and have had great respect for. Jerry and I talked and it looks like the 16G will be going back to get massaged into a TD06-20G. This will also be paired up with a nice set of Power Enterprise 800cc injectors. Now that I will have everything off of the car, I wanted to address the crazy Raw Fuel Smell TSB that Subaru won't do anything about other than charge you crazy amounts of money to change out a $13 part. So I started looking around and had heard good things about Agency Power Fuel rails. So I reached out to one of my local vendors, Joe at First Force Performance . Joe is running the Agency Power fuel rails on his 2000 RS that has a swapped JDM WRX engine with lots of other goodies including a nice rotated mount turbo setup. He has been quite happy with the fuel rails in his setup and has been able to source me a nice set of these fuel rails. Ok.. now I have the Injectors, Rails, Turbo, Heads, Pullies, Porting, and Coating taken care of, I needed some more fresh air coming into the turbo. This is where I started talking to Matt at KS Technology about their 73mm MegaMAF short ram intake. This is a great product and probably one of the only alternatives out there to the Perrin product. Matt has been great and assured me that their quality is second to none and I will not be dissapointed. This BigMAF addition should make sure that we can provide the right amount of air to the new turbo. So what is the last piece of the puzzle.... TUNING!!! This is where Andy and Paul at Neetronics have stepped up and are taking care of me. Neetronics just installed their second Dyno. So now they have their existing load based dyno for tuning and simulating load and driving scenarios and then also their new DynoJet dyno for providing consistant reliable numbers to be able to accurately measure your gains. Paul pretty much can tune anything that that drives!!! The car will be at Neetronics for their Dyno Day Meet on July 5th so that I can get the baseline on the car done so we have some starting numbers to be able to compare against after the work has been completed. So these are the players/products involved and I will be updating the thread as the products arrive and the build moves forward with pictures as well as installation and product impressions. Lastly, I've been having some exciting conversations with Peter Tarach at Modified Magazine as I've been piecing the build and the concept together. Peter is quite interested to see how it all turns out. As the project draws to a conclusion it is possible that the build showcasing these great products and vendors will find its way into the magazine. For those who are not familiar with my some of my build threads and my car here are some pics of Batman's Tumbler... ![]() ![]() ![]() ![]()
#2 |
Member#: 106521
SWIC
Vehicle:I am an ancient of chaos. \\ t3hclap.com |
Holy mount balls of badass. =O
#3 |
Member#: 82989
Vehicle:2002 WRX Hybrid VF22 |
Lovin' those flares.
#4 |
Member#: 63990
So when I have the engine out of the car, I'll be taking off the fenders, hood, and front bumper and doing a little bit of tidying up. I'll be taping off everything and painting the engine bay black.
As well the firewall will be getting a treatment of adhesive heat sheild that arrived just the other day. This material will also be finding its way into my cold air box that I will be building. The cold air box will be part of some new engine bay covers that I have up my sleave ![]() ![]() I was also able to pick up a set of Power Enterprise 800cc injectors from a member of the Toronto Subaru Club that was no longer in need of them ![]() |
#5 |
Member#: 180842
Vehicle:2008 WRX STi WRB |
that is one bada$$ ride
#6 |
Member#: 63990
Also, I figured I would do a little bit of an upgrade to my custom headlights that I made...
So this nice 6K HID kit with Relay wiring harness... ![]() and these Hella 90mm projector modules.. ![]() ![]() Will be finding their way into these: ![]() |
#7 |
Member#: 139076
Vehicle:2002 stg2 wagon 03 suzuki sv650s |
nice, finally got the wrc fog covers?
#8 |
Member#: 125497
Vehicle:02 Alpine White M3 Rouge Engineering !!! |
Sex, Sex,sex,sex,sex
Titstacular |
#9 |
Member#: 63990
#10 |
Member#: 57364
Vehicle:2013 wrx swp |
i remember seeing this car in a recent subiesport magazine. nice work. wheres the bat symbol?
#11 |
Member#: 132365
Vehicle:'02 WRX EPL B5 S4 & B6 USP |
Agreed the fog covers make the car. Looking good as usual and the future seems to be bright!
#12 |
Member#: 128189
Vehicle:2000 Outback Sport Blue Rally Pearl |
As with any of your builds... subscribed.
#13 |
Member#: 92582
Vehicle:* |
What? No gold foil?
#14 |
Member#: 2452
SCIC
Vehicle:08 2.5 WRX WRB Mica |
more more more
#15 |
Member#: 109090
SWIC
Vehicle:08 IS-F WFC Mbr # 004 |
nice bro
#16 |
Member#: 106044
SCIC
Vehicle:2011 Tacoma White |
What size wheels/tires are you running sir?
#17 | |
Member#: 139076
nice work tho, i am subscribing to this thread. |
#18 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
cant wait to see what you do next, your car is one of my fav's.
#19 |
Member#: 63990
18x8.5 +20 offset... 265/35/18 tire
Please everyone.... no "You should have a wider rim comments".. been through all those conversations on my other threads... I am more of a big meat on a thinner rim kind of guy instead of a really wide rim with a tire stretched to hell. |
#20 |
Member#: 63990
#21 |
Member#: 63990
#22 |
Member#: 53971
Vehicle:#35 2.5RS Rally Car MAP-RALLY.com |
Sick car man, and I don't say that often haha.
![]() ~Mark |
#23 |
Member#: 41149
SCIC
Vehicle:04 09 FXT SSM |
While your current paint job is pretty cool, I think you should eventually get it professionally done... it doesn't really do the widebody justice to have rattlecan paint on it.
#24 |
Member#: 90572
Vehicle:2013 WRX STI 07 ninja ZX6R |
unique paint job. looks and probably feels like sandpaper
#25 |
Member#: 83638
TXIC
looks dope! excited for you, document the build for us
| Thread Tools | |
| Display Modes | |
| Pics Of the Bugeye before it goes under the knife. | smileyou | Member's Car Gallery | 21 | 12-05-2008 05:44 PM |
| Going under the knife tomorrow morning. First reply gets the ruckus | kbcr3 | Off-Topic | 81 | 01-18-2008 05:06 PM |
| Mastro Monster goes under the knife... | Opie | South East Region Forum | 48 | 01-24-2005 08:43 PM |
| OT: The Mustang goes under the knife (pics) | Patrick Olsen | New England Impreza Club Forum -- NESIC | 8 | 05-16-2001 02:33 PM |
