Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 07-04-2008, 08:09 PM   #1
redlinedrift
Member#: 102813
Default JUN EJ20 Short Block Announced
This was just announced July 4th In Japan. Short block is being offered in 2 stages:
http://www.jdmtuningnews.com/articles/7408a.htm
EJ20 Specifications:
BASIC (441,000 yen including tax):
- New Subaru OE Block - JUN Piston kit - W-Series (92.0mm) - New Subaru Connedting rod - New Subaru Crank Shaft - New Subaru Main Bearing - P.E. Rod Bearing - Clearance Check and Cleaning - Adjusting Bearings - Adjusting Gap of Piston Rings - Assembling Block and Parts.
EX (924,000 yen including tax):
- New Subaru OE Block - JUN Custom Kit EX 2.2L - JUN Piston Kit C-Series - JUN I-Beam Connecting Rod - JUN Billet Crank Shaft - Cylinder Reinforcement by Rib - New Subaru Main Bearing - P.E. Rod Bearing - Clearance Check and Cleaning - Adjusting Bearings - Adjusting Gap of Piston Rings - Assembling Block and Parts.
NAME JUN SHORT BLOCK EJ20 VEHICLE SUBARU IMPREZA WRX ENGINE EJ20 BORExSTROKE BASIC TYPE: 92mmx75mm / EX TYPE: 92.5mmx79mm ENGINE DISP. BASIC: 1994cc / EX: 2159cc.
redlinedrift is offline   Reply With Quote
Old 07-04-2008, 10:44 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
pfff, i wouldn't pay more than 900,000 yen for that.
yarrgh is offline   Reply With Quote
Old 07-04-2008, 11:43 PM   #3
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
lol how much is that us $
25rsti is offline   Reply With Quote
Old 07-04-2008, 11:54 PM   #4
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
hahahah. so funny hahahahahaah
cquirki is offline   Reply With Quote
Old 07-05-2008, 12:39 AM   #5
sanjay
Member#: 100624
2004 WRX Wagon
924,000 yen is about $8,648.44
sanjay is offline   Reply With Quote
Old 07-05-2008, 12:41 AM   #6
dstnbmxvr6
Member#: 168106
2002 aspen white
20g8cm
thats an expensive motor but it is built by a very respectable company
dstnbmxvr6 is online now   Reply With Quote
Old 07-05-2008, 01:38 AM   #7
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
it better do whatever an ej25 can times TWO for that much!
mxpunk is offline   Reply With Quote
Old 07-05-2008, 02:42 AM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the weak dollar doesnt help much in the exchange dept. but a Jun built 2.2L stroker is pretty badass
Old 07-05-2008, 12:17 PM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
JUN's stuff is notoriously expensive anyhow... I doubt there is anything in there that the rebuilders over here cannot do for you.
jigga is offline   Reply With Quote
Old 07-07-2008, 11:36 AM   #10
MS WRX
Member#: 117780
2004 WRX
+1. Im sure JUN makes great stuff, but people pay WAAAY to much for the name.
MS WRX is offline   Reply With Quote
Old 07-07-2008, 11:54 AM   #11
white mike
Member#: 177156
I had JUNIII cams in my gsr swapped civic hatchback and let me tell you, you definately get what you pay for properly tuned that car was an animal 12.86@103mph stock bottom end and minimal bolt ons(IM/H/E) with a full interior on slicks yea it was probably a little too much cam for the stock bottom end but with a built bottom end it was quite a bit faster never tracked it sold the motor to someone who put it in a crx that went low 12s. That being said the cams weren't cheap I'll tell you that much. there are the jdm nazis out there that will pay for it b/c its a reputable jdm tuner and they think its so much better than anything built/manufactured here in the states.
white mike is offline   Reply With Quote
Old 07-07-2008, 01:18 PM   #12
acssa
Member#: 184023
Why not a Cosworth? From USA? Better and cheaper
acssa is offline   Reply With Quote
Old 07-07-2008, 03:10 PM   #13
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Why would you think Cosworth is better?
Old 07-07-2008, 05:57 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
DiY 4tW
Old 07-08-2008, 02:10 PM   #15
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Cosworth is not cheaper!
Jun includes billet crankshaft
Cosworth short block with billet CS $9000
http://www.cosworth.com/shop_item.php?productid=490
engineerx is offline   Reply With Quote
Old 07-08-2008, 02:33 PM   #16
TVA
Member#: 16464
Chapter/Region: HIIC
2008 Audi
Bad decision
I find it interesting that even with their 2.2 L stroker that goes as far as re-enforcing the deck of the block they still choose to use OEM Subaru main bearings. Maybe thats some food for thought for those of us that put together built bottom ends and spend extra money on main bearings from other companies. Apparently we still want aftermarket rod bearings though.
TVA is offline   Reply With Quote
Old 07-08-2008, 07:26 PM   #17
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
He is probably a brand whore.
jk of course, but Cosworth is a name that sells...some of their Subaru stuff is other people's repackaged goods (ie: cams, bearings, etc) so that def doesn't equal better IMO.
MJU1983 is offline   Reply With Quote
Old 07-08-2008, 08:41 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Why would you think it or any other builder isn't?
Old 07-08-2008, 09:25 PM   #19
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm not putting one builder above any other. My past builds always used local trusted builders I was just trying to understand his reasoning. You could get a kick ass short block from either but I look at it this way:
1. Jun has more experience building and blowing up and rebuilding SUBARU motors
2. If you have a problem with JUN you are SOL unless you live in Japan
3. Cosworth knows a thing or 11ty billion about race engines and they have a local shop in Torrance not far from my locale = big plus.
I call it a draw but some put more stock in a name when its been proven you can get quality short blocks without the rock star name.
JUN EJ25 Short Block redlinedrift Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-04-2008 09:12 PM
wtb ej20 short block/ long block 1niceboxer Private 'Wanted' Classifieds 0 11-07-2007 01:43 AM
Fs: Ej20 Short Block mikeg313 Private 'For Sale' Classifieds 28 11-05-2004 02:24 AM
1 ej20 short block and ej25 short block f/s 3BadHabbits Private 'For Sale' Classifieds 4 06-07-2004 05:31 PM
TN: EJ20 Short Block for Sale silverwrxtn Private 'For Sale' Classifieds 10 08-05-2003 09:54 AM
