Old 07-06-2008, 07:50 AM   #1
my99maddog
Member#: 55515
1998 MY99
Default Do Kelford manufacture Cosworth Cams?
Can anyone confirm who manufactures Cosworth Cams? I have heard it's Kelford in NZ,
my99maddog is offline   Reply With Quote
Old 07-06-2008, 08:42 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
kelford used to but no longer.I talked to Kevin at kelford and he was not able to talk about it.
john 1badSTI is offline   Reply With Quote
Old 07-06-2008, 09:34 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
I have an engine with Kelford cams, and one with Cossie's currently in my shop. They look identical other than the logo. i will take pics tom.
MartinSTi05 is offline   Reply With Quote
Old 07-07-2008, 04:36 AM   #4
my99maddog
Member#: 55515
1998 MY99
Thanks guys, let us know the age of both sets if you can?
Kevin sold me mine recently, great service now I can't wait to get the motor finished.
Old 07-10-2008, 03:24 PM   #5
MartinSTi05
Member#: 145145
2006 wrx STi
The kelford cams are about a year old, and the Cossie's were ordered about 3 months ago.
Both Engines: the one on the right equipped with Kelfords, the one on the left with Cosworth cams.
Cosworth cams closeup:
Kelford cams closeup:
Sorry for the late response.
Hope that helps.
If kelford doesn't manufacture Cosworth cams it sure appears to me that they at the very least use the same blanks. My bet would be that Kelford indeed does manufacture Cosworths cams. The similarities are too numerous.
Old 07-10-2008, 04:55 PM   #6
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
I have the non-AVCS Cosworth 275 cams in my build and my engine guy told me at the time I bought mine that they where made by Kelford. When I swapped heads my head guy wanted to know specs of the cams like lift at .050 which wasn't stated in the included Cosworth info. I contacted Kelford about the cams I had and they had confirmed they were the same as their 199-E cams which they advertise as a 272 cam(they use a different checking height). That was then, since then Cosworth has supposedly taken over production but I bet the specs have remained the same.
Old 07-10-2008, 04:59 PM   #7
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
I heard that they are made by Kelford, but when I was doing some research I called Cosworth to try to find out more info on them...
All I got was that they are both made using similar chill casted cores.
So, I drew this conclusion - they are made using the same raw materials... but might be made by Kelford/used to be made by Kelford, or perhaps they buy the raw cores from Kelford.
axelthrasher is offline   Reply With Quote
Old 07-10-2008, 06:52 PM   #8
MartinSTi05
Member#: 145145
2006 wrx STi
http://www.briancrower.com/makes/subaru/ej257.shtml
This link shows what BC cams look like. Notice how much different they are from the Kelford/Cosworth AVCS cams. My bet is that Cosworth will tell you the cores are the same because they indeed are. Whereas they will not tell you about the machining because you can't readily see the differences/similarities in it.
Old 07-10-2008, 10:40 PM   #9
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
That link shows what FACTORY STI cams look like. I have 3 sets of BC cams in my possession right now, and they look very similar to the Cosworth and Kelford Cams I've installed in the past. If you want pictures, I'll post them tomorrow when I get back into the shop.
wrx_driver_2002 is online now   Reply With Quote
Old 07-11-2008, 01:51 AM   #10
MartinSTi05
Member#: 145145
2006 wrx STi
My bad then;-) I would have figured Crower would show an actual Picture of their cams on the site.
Old 07-24-2008, 02:35 PM   #11
ellissti6
Member#: 170034
i know this may be a bit off topic, but kelford cams are a direct drop in with no modification necessary correct? other than springs and retainers needing to change? also just wondering if anyone knows how they compare to any other good brands on the market ie jun, rigoli?
ellissti6 is offline   Reply With Quote
Old 07-24-2008, 04:36 PM   #12
my99maddog
Member#: 55515
1998 MY99
I believe they are the reference cam, many others as mentioned are made under license buy companys like Kelford.
My 264/264 were a direct replacement, but not qualified to comment further.
Old 07-24-2008, 05:58 PM   #13
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
I see why Cosworth and possibly BC went with Kelford cores at the least. Whether they are machined by Kelford is a different story.
Kelford is one of the only companies that produces reliable and quality cams for subies.
AdamBOMB_STi is offline   Reply With Quote
Kelford avcs 272 Cams Evil Imports Engine/Power/Exhaust 8 12-10-2009 11:54 AM
Kelford 280 276 cams irocnsti Engine/Power/Exhaust 33 12-04-2009 09:44 PM
Kelford 272/278 cams DemiSlayer Built Motor Discussion 0 08-06-2008 02:03 PM
VENDORS: usdm sti Kelford or Cosworth Cams IN STOCK InfamousDX Private 'Wanted' Classifieds 3 04-30-2007 08:40 PM
Cosworth Cams EJ25-Material added? (What other Cams are as well?) EjtwentyfiveSti Built Motor Discussion 5 04-16-2007 10:15 PM
Message Board Statistics All times are GMT -4. The time now is 09:13 AM.
